Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Drain light on
Not cooling
    President:
  • 1,902 Answers
You have a blocked drain line you will need to unblock it with either forced air
Posted on May 31, 2010
I have a Daikin mini split system. It is leaking water from the inside unit inside my house. Why?
Dirty? Check your filters, shine a light inside to see blower wheel. Drain plugged? Wetvac on the drain outside.
Otherwise it's a cracked drain pan, bad fitting, drain is trapped multiple times, possible it's low on refrigerant.
Jul 20, 2017 | Heating & Cooling
I HAVE A BEKO CELLING AC, THE "DRAIN" GREEN LIGHT BLINKS, THE OUTPUT AIR IS NOT COOL JUST NORMAL AIR.
Sounds like the float switch is tripped. You need to vacuum drain line with a shop vac. Your outdoor unit must not be running.
Jun 09, 2017 | Heating & Cooling
Lg lsc27931sb refrigerator won't cool or freez3
Sounds like the auto defrost drain in the freezer is blocked with ice and the water is draining down into the refrig box. Usual cure is to remove inside panels in the freezer to expose the cooling coils area. Then use a hairdryer to melt the ice. Plenty of rags for this. Next you must clear the ice blockage in the drain. Make a loop of #12 or #10 copper wire (bare) about 18 in long. Hold it with a pair of pliers while you heat it with the hairdryer. It will slowly melt the ice in the drain hole. Pour hot water through the drain until it come out on the drip pan below. Now you need to see why the ice forms. Just above where the drain hole is under the coils should be a calrod heater that is powered by the defrost timer to melt the ice. It sometimes gets out of position. Another possibility is the failure of the defrost timer. If you can rotate it manually see if it initiates a defrost cycle. If so and does work, check wirinf connectors at the timer. If OK replace timer.
Dec 11, 2014 | LG Refrigerators
Red light coming on ; tank is filling up. I drain
Fortunately, from what you have described, the unit is working as it should. But, the frequency that it's occurring is what I think you're concerned about.
If you are operating the Dehumidifier Mode along with the Cooling Mode, this will generate more water in the tank and require more frequent draining. Running the Dehumidifier and the AC (Cool) at the same time is not recommended. It reduces the cooling capacity of the AC Mode and generates heat in the room. And, as you already know, more water.
Hope this helps you and thanks for choosing FixYa.
Aug 03, 2011 | Haier CPRD12XC7 Air Conditioner
Danby dpac 10071 air conditioner is not cooling. a red light is on next to an icon with a full cup. Does anyone know how to make it cool?
That indicates that the water collection bucket is full and needs to be drained. Once the unit is turned OFF, unplugged and drained, the unit will start up and start cooling again. The drain hole is on the rear of the unit, just above floor level. You can either drain it in a shallow sided pan capable of holding 1 quart of water. Or roll it to a floor drain or outside to drain it.
Jul 29, 2011 | Danby DPAC10061 Air Conditioner
How to clean drain tube at the bottom of the refrigerator?
Sub zero drains dont usually cause a cooling problem. You could be having that drip because its not cooling enough. Check to make sure both doors close completely, check light switches-do the lights turn off? You will have two or three fans on this unit, one by the compressor, one in the freezer, and possibly one in the fresh food section.
If you have further questions, visit my website and send me a question. www.FixMyFridge.net
Mar 17, 2010 | Sub-Zero Bottom Freezer Refrigerator
How do you remove the water pump on a 2006 monte carlo
  1. Drain the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  2. Loosen the water pump pulley bolts.
  3. Remove the drive belt.
  4. Remove the water pump pulley bolts and pulley.
  5. Remove the water pump bolts.
  6. Remove the water pump and gasket.
  7. Clean the water pump mating surfaces
    1. Position a NEW water pump gasket and the water pump to the engine front cover. Notice: Refer to Fastener Notice.
    2. Install the water pump bolts. Tighten the bolts to 10 Nm (89 inch lbs.) .
  1. Install the water pump pulley and bolts.
  2. Install the drive belt.
  3. Tighten the water pump pulley bolts. Tighten the bolts to 25 Nm (18 ft. lbs.) .
  4. Fill the cooling system. Refer to Draining and Filling Cooling System (LS4 Static Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9 Static Fill) Draining and Filling Cooling System (9C1, 9C3 Static Fill) Draining and Filling Cooling System (LS4 GE 47716 Fill) Draining and Filling Cooling System (LZE, LZ4, LZ9, 9C1, 9C3 GE 4771 Fill).
  5. Inspect for leaks.
Hope this helps
Oct 01, 2009 | 2006 Chevrolet Monte Carlo
The purge light is blinking on the honeywell box on my ac box in house.its been draining alot of water from the pipe that leads out side.been doing this 4-5 days.is this normal?
If the ac is cooling you will get a lot of water out of the drain as much as 17 gallons a day. The purge light blinks on some of the Honeywell board when all zones call for cool or heat. Russ
Jul 18, 2009 | Heating & Cooling
Refrigerator side stops cooling
Drain stopped up.
Take out the bottom drawer in the freezer, look at the back wall and you should get a partial view of the bottom of the cooling coils. Directly below these coils is the drain area. You may need a light to see the drain hole. If this area is covered with ice then a hair dryer will help clear this so you can see the drain hole.
I have some O2 tubing that I put down the drain to clear any cloggs. Also, I seal the top of the drain hole around the O2 tubing with tape and use the air from my lungs to clear the drain tube. Pour a little water down this drain hole to make sure it’s clear.
Dec 17, 2008 | Frigidaire FRS26R4A Side by Side...
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
62 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
