Question about Denon AVR 3808Ci Receiver
Circuit fault protection goes in every minute
Circuit fault protection goes off about every minute
    President:
  • Denon Master
  • 1,114 Answers
The most common problem found on FixYa for Audio Videocircuit fault protection goes in every minute - 2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Jun 03, 2010
Power went off and then tv will not start. It is fitted with a surge protector
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Sep 10, 2009 | LG 42LC2D 42 in. LCD HDTV
Tv worked fine one minute and then when turned back on no picture or sound. Indicator light at eye came on for a second then went off. Whats the problem?
If the led goes off , and TV turns down completely, then the power supply unit is failing. In that case the PSU board must be tested and eventually replaced.
If the led stays on , or is blinking then the TV is on protect mode.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Aug 17, 2009 | Hitachi 50UX57B 50" Rear Projection...
Clicking with no Sound
The TV is on protect mode. This happens when an internal fault is detected. When a fault is detected the protection circuit prevents the TV from starting , the clicking sound is the protection switch that keeps turning off the TV.
Sometimes protection is triggered by an incorrect voltage, or electrostatic charges accumulating on the TV PSU capacitors. In that case the problem is temporary, and will disappear leaving tv unplugged for some times. More often, when tv goes on protect there is an internal fault that must be fixed.
Jul 12, 2009 | Vizio GV46L 46 in. LCD Television
Power switch wont turn on,keeps clicking
The fault is not a relay, the clicking sound is just the protection circuit that prevents the TV from starting because a fault had been detected.
May 21, 2009 | Samsung Televison & Video
Dell E173FP Screen blinking red, green, blue, white
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
When the Monitor goes on protection there are only two possible causes.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
Apr 16, 2009 | Dell E173FP 17" LCD Monitor
Sony KV-HR 29" TV GOES ON STANDBY MODE AFTER 10 TIMES BLINKING
Mar 08, 2009 | Sony KV-29LS60 29" TV
When i turn it on it goes fft fft fft then shut off
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
If you want to repair at your own expenses, just locate any good qualified repairer..
Feb 24, 2009 | Proscan PS35660 TV
Timer light blinking
Aug 21, 2008 | Mitsubishi WS-65819 TV
Samsung crt monitor
  • Video cable.
  • Motherboard.
Common faults that can occurr are a blown capacitor on power board, faulty convergence, fault on alignment circuits, flyback problem , or a fault on Digital board.
Jul 12, 2008 | LG Flatron Ez T710BH 17" CRT Monitor
Denon AVR 3808Ci Receiver Logo
94 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
