Question about Amcor AL10000E Air Conditioner
Hot air i turn on the air and it start good but in few minutes hot air start coming out it never change tha temperature between 84 and 87
  • 146 Answers
You need to vent the hot air outside.
Posted on May 31, 2010
I have an air conditioner Mitsubishi MSZ-A26YV, it has stopped heating, even if it's on the heat setting [sun emblem] and is set to highest temp, only cold air comes out, otherwise it does all other...
It's not indicated to turn directly from cooling mode to heating mode. You must wait about two or three minutes before the change. After the spliter start, you must wait few minutes to get hot air.
Mar 30, 2011 | Mitsubishi MSZ-A24NA Split System Air...
97 Subaru Legacy, 142,000 miles. Temp Guage
Sounds like the Coolant is not full and has a air bubble. It is very important to have the system filled complete. That would be the first step.Good luck and have a great day.
Feb 22, 2010 | 1997 Subaru Legacy
My heater stoped blowing hot air.antifreeze level
If the blower is blowing air just fine, but you cannot control the temperature, you need to listen to air coming from the vents while turning the temperature from hot to cold. If you do n ot hear any change in airflow, then you may a temperature door in the dash broken. this is becoming a common problem on the Equinox and Pontiac Torrent,
Tech JK
Oct 13, 2009 | 2006 Chevrolet Equinox
AC cools then blows hot air, tempature needle goes up & down
Sounds like the thermostat is trying to stick,and is causing the engine to over heat,therefore condenser is not cooling the freon down enough to cool.Have the thermostat changed and the cooling system bled out,this is most likely the cause.
Aug 29, 2009 | 2005 Lincoln LS
I have a 1997 rodeo. The a/c will come on and stay on for a few minutes. Blows cold air. After a few minutes, the ac shuts off.If I shut off the a/c button for a couple of minutes and turn it back on,the...
It sounds like it is your high pressure switch located on the high side supply line of your AC. When the temperature is hot, it is harder for the condenser to cool off the freon flowing through it causing the pressure in the system to rise. Also, check to make sure that you condenser on the front of the truck is clean and free of debris. If you have an electric fan, make sure it is coming on when the AC is turned on.
Hope this helps,
Jeff
Jul 04, 2009 | Heating & Cooling
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
I can't get my Air Conditioner to come on ?
Clean the filters of the air conditioner. Also, if the unit has been running for a few years without proper maintenance you must expect lots of dust in the evaporator unit. This is usually easy to clean with compressed air.
May 21, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Wont no water to empty or drain
Either the unit is really dirty or it is low on refrigerant. A unit tha is low on refrigerant will start off cold and withing a few minutes, start warming up. If you aren't seeing any water its because of one or both causes listed.
Apr 01, 2009 | GE APN08AA Portable Air Conditioner
Cd player console
I am a volvo s40 owner myself.
Try to eject all of the CDs at once. To do so keep the eject button pressed for a few seconds. this will eject the CDs one by one.
The temperature of the air conditioner is probably changing because of the outside temperature change. eg if the temperature outside is 35C and you set the temp inside at 25C it will come out cold air. if the temperature outside drops to 30C the air will come out hotter. you will notice that between summer and winter. the same temperature set will give either cold or hot depending on the weather.
in winter if you set it at 25C it will be very hot. In summer it will be cold.
Aug 04, 2008 | 2006 Volvo S40
1994 CHEVY CAVALIER V-6 STARTS TO OVERHEAT WHEN A/C RUNNING. ALREADY CHANGED THERMOSTAT AND ADDED COOLANT, STILL RUNS HOT, SOUNDS LIKE THE COOLING FANS AREN'T COMING ON WHEN THEY ARE SUPPOSE TO. CONSTANT...
Make sure you get the air out. There may be "high spots" on the engine that you can unscrew to let the air pockets t. Close this small valve when just hot water comes out.
Unplug the radiator fan and use jumper leads to test the fan operation. Use a scan tool to check for codes. If you get a scan tool that gives live data, see that the PCM sees the actual temperature of the engine after 5 to 10 minutes of running. It should see the temp. rising to 225 degrees farenheit.
Replace engine temperature sensor if the PCM doesn't recognize the proper temperature. You ARE going to compare this to the temperature gauge!!!
If all else fails, get the PCM recalibrated or flashed at the dealership.
Jul 16, 2008 | 1999 Chevrolet Cavalier
Amcor AL10000E Air Conditioner Logo
147 people viewed this question
Top Amcor Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
