Looking for fan condenser relay for buick 1996
When i turn on the a/c my fan condenser doesn't run
    Guru:
  • 587 Answers
When you turn on your A/C does the compressor come on? Unless you have a heat pump or you have a newer A/C that has a control board in it you won't have a fan relay. The fan is powered by the contactor, when it is energized the fan and compressor will both come on. If the compressor comes on and the fan motor doesn't. Disconnect all the power. Try spinning the fan blade,if it spins freely the bearings are ok, if it doesn't stiff or drags even a little, then the bearings are bad and the motor needs replaced. Then check the capacitor, if it has a bulge or is swollen then the capacitor is bad and needs replaced. You sometimes can take it to your parts store and some of them will check it for you. Last with the power back on and the unit calling for cooling check the volts to the motor terminals if you have 230 volts and the capacitor is good, then the motor is bad and needs replaced, if you don't then you need to check the fuses at the disconnect or breaker.
Posted on Jun 01, 2010
Condenser fan on heat pump does not turn off
If it is just the condenser fan that means you have a fan relay that has welded shut. Turn power off to your unit and trace the wires from your condenser fan back into the control panel at the unit. You'll have 3 wires going to it. 2 go to the run capacitor and one goes to the fan relay. The one that goes to the fan relay is the part that needs to be replaced. If you have no fan relay and it goes to the main contractor, half of your main contractor is welded shut and will need to be replaced.
Sep 18, 2014 | Carrier 52PQ-515---3 Premier Series Heat...
Condenser fan not engaging
Possibly low on refrigerant. When system is low on freon, it does not build up enough high side pressure to engage the condenser fan . When pressure is high enough. a high side pressure switch kicks on the cond. fan to maintain high side pressure. Have the system evacuated and recharged to proper level.
Feb 01, 2014 | 1996 Mercedes-Benz C-Class
I have a 1996 Buick Century...Having codes P1651, 1652, and 1655 come up...can clear the codes and will drive for about 4 days...then either have to clear codes again OR have to figure out where these...
fan 1 and 2 relay, and the 1655 is evap purge solenoid, the fan relays going bad can cause the car to run hot or overheat, check for broken vacuum lines and replace the purge solenoid if needed.
Oct 16, 2012 | 1996 Buick Century
1996 buick skylark fan operatiion - How to test it?
Take out the temperture sensor switch and put it into very hot water to see if it works. Plug the hole with something to stop losing water. If the fan doesn't work put some voltage on the motor and try that. If that doesn't work it is the fan motor. If it does then it is a faulty switch.
Oct 26, 2011 | 1996 Buick Skylark
I have a GE Gss22iFRE CC side by side. The strip between the 2 doors is very warm to the touch. I have vacuumed the rear panel and removed the rear panel and vacuumed. The fan blade will move freely by...
most likely you have a bad computer board,if the condenser fan runs slowly or not at all i've been changing the computer board and it runs fine.everything on this machine runs through the board,unplug it,remove the cover to the computer board on the back of the machine and look at the board,if you look at it you'll see black relays,if your board doesn't have all 7 relays on it you don't have the newest board in your fridge and this is your problem,part number WR55X10942 and it's around 150 dollars.look at j1 pin 2,if there's a yellow or white wire in pin 2 cut it,you'll see this on the instructions,get any kind of a fan and blow it onto the back of the machine to keep the compressor cool and change out the computer board as soon as possible or you'll cook the compressor,i've had costumers run a fan in the back until i could get to them till the next day and it works great but change out the coil tomorrow,you can check the condenser fan motor with a meter but most likely it's gonna be the computer board.hope this helps you out,salde
Sep 16, 2011 | GE Refrigerators
After Eng is turn off A/C & heater fan keeps runing dranig
The fan runs off a module incorporated inside the blower fan motor. The motor assembly will need to be replaced for its all electronic inside
Jun 22, 2010 | 1996 Buick Park Avenue
1996 Buick Riviera Cooling fan won't shut off. we
COOLING FAN IS CONTROLLED BY COOLANT TEMPERATURE SENSOR (CTS). REMOVE THE CONNECTOR FROM IT AND IT SHOULD STOP THE FAN.
OR JUST REMOVE BATTERYGROUND CABLE.
ITEMS TO CHECK OUT :
CTS,RELAY,CIRCUIT FOR SHORTS.
NOT LIKELY BUT IS A POSSIBILITY, THR ECU.
Jun 09, 2010 | 1996 Buick Riviera
2003 dodge ram 1500 w/ 5.7L hemi
you may want to check the fan for the AC condenser under the hood of the car. Your AC condenser should have a separate fan similar to that of the radiator. See if it turns on while the AC is on. If it does not, you may want to swap the relay of the two fans. If swapping the fan relay would start the AC fan then have the relay replaced. If it does not turn on then have the fan tested. Check the wires. If the fan is Ok you may have to check out the condenser if it needs cleaning.
Sep 07, 2009 | 1996 GMC Jimmy
1990 BUICK CENTURY RAD.COOLING FAN RUNS ANYTIME KEY IS ON.
If you have changed out the relay, and disconnected the temp cooling sensor, make sure you have replaced the correct relay; I believe there is one bank of four relays located by the passenger side head lamp. If the fan is running continuously, then I would say the relay is stuck in the closed position, resulting in completing the electrical circuit, powering the fan. Have the new relay tested. You can find a wiring schematic in the Hanes manual for your make and model.
May 08, 2009 | 1990 Buick Century
Both cooling fans will not come on
Did you try jumping the cooling fans with direct power to see if they worked and the fan motor isnt burned out?You can turn the a/c on while running the car and it should turn the fans on even if the car isnt heated up.
Mar 29, 2009 | 1996 Buick Regal Olympic Gold
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
