Question about Whirlpool Washing Machines
F 21 - Whirlpool Washing Machines
    President:
  • 1,382 Answers
When F21 error code appears press PAUSE/CANCEL two times to clear the display.
Also check for the following issues
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Thank you !!
Posted on May 31, 2010
Testimonial: "Thankyou for the advice! V."
Need repair manual for Komatsu D31EX-21,D31PX-21,D37EX-21,D37PX-21,D39EX-21,D39PX-21 Dozer Bulldozer
Downlaod Komatsu D31EX-21,D31PX-21,D37EX-21,D37PX-21,D39EX-21,D39PX-21 Dozer Bulldozer Service Repair Manual
https://sellfy.com/p/fmBE
Nov 23, 2015 | Cars & Trucks
Tip
Hi there.... I have tried the above, but nothing happens after I have clicked on...
Hi! I have noticed a lot of people have this problem that they actually forget there Sony Ericsson mobiles' Phone Lock Code. If you want to recover your phone lock code please go through the following procedure. This procedure will tell you your mobile's lock code without flashing and resetting of any kind!..
I have also have a Nokia version of this tutorial here: Nokia
Follow these steps;
  • Open this link, select your phone and download the software. (PLEASE CLICK HERE)
  • Follow the onscreen instructions to install the software.
  • Once installed, turn off the mobile and remove thebattery. Now reinsert the battery and insert the cable (DCU-60 thatcomes with the box) while holding the 'c' or '@' button on your mobile.
  • Your computer will detect a new device and install it.
  • Once installed please unplug your mobile, remove the battery. Now reinsert it.
  • Download xs++ from here
  • Extract this file and run XS++.exe
  • In XS++, click Connect.
  • Hold 'C' or '@' key on your phone and then insert the USB cable.
  • u can get some information about your phone when it's connected
  • click or tick GDFS at the bottom.
  • Then click Phone Lock, it will show you the code on right hand side. Note that code.
  • click Settings at the bottom, then Disconnect.
  • unplug the USB cable, remove then reinsert the battery.
  • You are done, enter 0000 or the Noted one (In the 3rd last step)
    If I was Helpful, Kindly Do Rate!
    Regards,
    Waqar.
    on May 16, 2011 | Sony Ericsson Walkman W810i Cellular Phone
    Find the y and x intercept of this equation 3x-6y=-21
    To get the y-intercept of a line you set x=0. So 3(0)-6y=-21. Solve for y: y=(-21/-6)=7/2.
    For the x-intercept, set y=0 in the definition of the function, then you solve for x.
    3x-6(0)=-21. or 3x=-21 and x= -21/3=-7
    Oct 31, 2011 | MathRescue Word Problems Of Algebra Lite
    3u/u^2-14u+49-21/u^2-14u+49
    Solution is
    3u/u^2 - 14u + 49 - 21/u^2 - 14u + 49
    =3/u - 14u + 49 - 21/u^2 - 14u + 49
    =- 21/u^2 + 3/u -14u-14u +49+49
    =- 21/u^2 + 3/u -28u + 98
    Jul 28, 2011 | Computers & Internet
    Cisco VPN doesnt get connected through DI-524UP router. Worked fine until recently for both the laptops we use. Log indicates Receive: Purging stale cached fragment(s). Direct connected on the Motorola...
    Cisco VPN
    Upgrade your router to the latest firmware. You can download firmware at http://www.dlink.com.au/tech/ .
    Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
    Configuring PC running VPN Client Software:
    Step 1 Disable all Firewall Software (ZoneAlarm, Windows XP Firewall, etc.).
    Step 2 Change IP Address to be outside of the routers DHCP Pool (i.e. 192.168.0.99). By default the DHCP pool is 192.168.0.100 - 192.168.0.199.
    Step 3 Configure Cisco VPN Client - Connection Properties.
    Step 4 Check Enable Transparent Tunneling.
    Step 5 Allow IPSec over UDP ( NAT/PAT).
    Configuring Router using the Web-based configuration:
    Step 1 Open the Web Configuration Page by entering 192.168.0.1 into your web browser. Enter username (admin) and your password (blank by default).
    Step 2 Check the Status tab and make sure that you are running the latest version of firmware. If not, upgrade firmware before proceeding.
    Step 3 Click on the Miscellaneous button on the Tools tab. Enable both PPTP and IPSec.
    Step 4 Click Apply.
    Step 5 Click on the Virtual Servers button on the Advanced tab.
    Step 6 Enable IPSec from the list and configure as follows:
    Private IP: IP Address of the PC running Cisco VPN Client
    Protocol: UDP
    Private Port: 500
    Public Port: 500
    Schedule: Always.
    Step 7 Click Apply and then Continue.
    Step 8 Enable PPTP from the list and configure as follows:
    Protocol: TCP
    Private Port: 1723
    Public Port: 1723
    Schedule: Always.
    Step 9 Click Apply and then Continue.
    http://www.dlink.com.au/tech/default.asp?model=DI-524UP
    Nov 16, 2009 | D-Link AirPlusG DI-524UP Wireless Router
    Same Problem Again - Mega Raid.... Unknown Error
    Hi
    The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
    However, the extract posted in your suggests network problems.
    Any number of physical to driver and configuration issues can result in network problems.
    Try the basic checks;
    1. Change or try a known patch cable
    2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
    3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
    4. Can you try another switch
    5. Check and load correct or latest manufacture's drivers
    Reply with more info.
    Mike
    Jan 23, 2008 | Dell PowerEdge 1800 Server
    Washing Machines Logo
    26 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
