Question about Sony Ericsson T630
PIN code when i try to recieve files through blue tooth i need to enter a pass key/PIN code..what do i do??
IF "0000" NOT WORKING REMMEMBER THE LOCK CODE. ONLY 3 CHANCE FOR TRIAL.
PHONE WILL ASK FOR "PUC" CODE IT IS AVAILABLE WITH SIMCARD PROVIDER. THEY WILL GIVE 8 DIGIT PUC NUMBER IT WILL RESET THE PIN TO "0000"
Posted on May 10, 2008
    Guru:
  • 1,463 Answers
Enter either 0000 or any four number code your choice .but the other phone will the same code and access the file throught bluethooth and save .
riz.
Posted on Apr 08, 2008
SOURCE:
I dont have data cable of nokia 1209 then, how i connect my mobile to my pc ?
you could connect using your bluetooth, just turn on your bluetooth and connect.
Jul 15, 2011 | Cell Phones
What is my pass key for H350
motorola uses two pin pairing codes for their blue tooth devices they are as follows,0000,or 1234 there are two other codes for blue tooth devices as well they are as follows 1111,or 9999 glad to be of assistance.
Feb 26, 2011 | Motorola Mobility H350 Wireless Headset
What is the pass key for 9xxPlantronics bluetooth to register to PS3?
most blue tooth manufactures of blue tooth devices use a factory 4 digit pin pairing code now the most common one is as follows but there is a possibility that i could be one of the others i will put them in order from most common to least commmon try them in that order they are 0000,1234,9999,or 1111 i hope this helps
Feb 26, 2011 | Plantronics - Bluetooth Headset Plus Base...
9xxPlantronics pass key to register bluetooth for PS3
to use the pass code for your blue tooth device you must first put the device into discovery mode then most blue tooth manufactures use a factory 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999. i hope this helps
HTC evo will not pair w my jabra stone, says incorrect pass code, how do I re enter the pass code?
By putting the blue tooth device in discovery mode it will reset it then your will have to enter the manufactures factory pin pairing code,Most blue tooth manufactures use a 4 digit pin pairing code,they are as follows0000,1234,1111,or 9999 this should be the code you are looking for i hope this helps
Feb 22, 2011 | Jabra BT350 Bluetooth Headset Headset
Camera phone bluetooth
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
Hope this can be of any assistance. Thanks!
Mar 19, 2009 | Cell Phones
Blue tooth
you have to switch on the blue tooth of your mobile phone, switch on your laptop blue tooth also,
now open the blue tooth software on laptop there is a search option , it will detect your mobile phone and will ask for a pass key enter 1234 or any key you like but it be the same on both (laptop and mobile)
after that you send files
Oct 02, 2008 | Toshiba Computers & Internet
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Dec 19, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Bluetooth
Pairing: Press and hold until you see a solid blue light (approximately 8 sec) then release. Search with your blue tooth phone for a bluetooth device and if finds samsung wep-150. enter pass key or pin: 0000
May 08, 2007 | Samsung WEP-150 Wireless Headset
Sony Ericsson T630 Logo
79 people viewed this question
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
