Question about Maytag Dishwashers
Dishwasher is not draining correctly in the air vent on top of sink. Recently had a new garbage disposal installed and this is the first time using the dishwasher since installation of disposal.
  • Maytag Master
  • 2,605 Answers
Hi and welcome to Fixya, I'd suggest you start by checking the drain spout of the disposer where they ( the installer ) connected the drain hose from the dishwasher and make sure they've knocked out the plug in the spout. **Turn off the power or unplug the disposer/garberator before performing any service** If the plug is not punched out, with the aid of a long screw driver and a hammer, or a firm smack with the palm of your hand you should be able to knock out the plug. Then reach in the disposer and remove the plug you`ve just knocked out, reconnect the drain hose for your dishwasher and you should be good to go. Thank you for visiting "fixya". Please take a moment to rate the solution provided here for you. Hope that help`s. Good luck. macmarkus :)
Posted on May 31, 2010
  • Mark MacDonald
    Mark MacDonald Jun 07, 2010
    Hello again,
    I was hoping to get some feedback or an update on your status with the issue you had come to "fixya" for help on.. What did you find ? Did the problem get resolved ? Did we provide any assistance that was/is useful ? Please reply one way or the other as a gesture if nothing else. Myself and the other experts here put in a lot of effort and care in providing assistance which for the most part is free and voluntary, however we can be much more helpful if given some type of feedback thus knowing when we've helped and when we have not. Either way I do hope you found the problem and where able to solve it.
    Thanks again for using "fixya".
    Macmarkus :)
Dishwasher not draining completely after new garbage disposal installed
If you hooked up the drain to the disposal directly there is no vent in the line. Use the air vent on the sink to connect the dishwasher drain hose. If there is no air vent, then you'll have to install one in the sink.
Jan 26, 2014 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
My dishwasher is not draining completely. There seems to be more water left than last time I used it. Also, I tried to used the cancel/drain feature, with no success. Please give me some suggestions!
Hi and welcome to FixYa, I am Kelly
The drainage problems are caused by particulate in the drain.
There are 3 areas that cause restrictions with larger food particulate
1. The Air-Gap (if equipped) but the most common blockage point,
2. The sink connection. This is usually a garbage disposal connection. If the user is not properly rinsing long enough while the garbage disposal is in use the garbage disposal / dishwasher connection port is blocked with garbage disposal debris.
3. The bottom of the dishwasher sump area under the lower wash arm. If this area is blocked the user will complain of dirty dishes post cycle, It also causes drainage problems, If the user says dishes are not getting clean and it is not draining properly this will be the LAST area to check. Do 1 and 2 first.
I have had multiple call backs on some units... I have learned to call a brief moment before stopping by and inspect the DIRTY dishes in the dishwasher, the sump, air-gap and sink connection. Most of the time I find that the user is placing dishes with large food particulate in the dishwasher or... they are not letting the water run long enough when using the garbage disposal so the garbage disposal port clogs. These are the same folks that have things like pump impellers and pump housings that get broken due to their daily routine habits.
You wil have to clean all of the drain connections for the dishwasher pump outlet all the way to the sink connection. The Air-Gap is the most common area for blockages so pull off the cover.. unscrew the inner top nut NOTING the installed position BEFORE removal and clean out the Air-Gap (if you have one) Otherwise remove the drain hose at each connection and remove the debris. It is OK ot reconnect each connection after your done cleaning. This will solve about 85% of dishwasher drain problems. The last 15% the lower wash arm and support has to be removed to inspect for pump impeller damage or motor pump housing damage.
FYI the 2nd most common reason for drain problems is the actual sink port connection being clogged. Just clean the drain hose connection ports and the air-gap.
I think once you get all of your drain connections cleaned that your dishwasher will operate normally.
Thanks for choosing FixYa,
Kelly
Jun 17, 2011 | Whirlpool Dishwashers
We bought a new dishwasher because the old one wasn't draining all the way. Same problem with the new one?
The pump is a motor which runs in one direction to spray water in the dishwasher to clean and the opposite direction to drain the water. The problem could be from a clog or kink in the drain hose. Several years ago the drain line would connect to the sink garbage disposal. If the garbage disposal is not draining or the dishwasher connection to the garbage disposal is restricted or clogged the dishwasher will not drain. Under the sink, look at the garbage disposal to see if a rubber hose is connected at the side of the disposal unit. If a hose is connected to the side of the disposal, remove the hose clamp and check for any restrictions from garbage in the inlet or hose. You can use a screwdriver to clean the fitting to the garbage disposal and a wire hanger to free any restrictions in the hose. If the dishwasher does not connect to the garbage disposal it should connect to the sink trap. This is more common with new dishwashers because they have built-in disposals. Disconnect the drain hose from the sink trap and the dishwasher and look for a clog at the sink connection. The dishwasher inlet should have an angled piece of plastic or metal facing downward to prevent the waste from the dishwasher from spraying up into the sink. Do not get to aggressive with the cleaning in order to prevent breaking the angled piece of plastic or metal. Look for any kinks in the hose and try to run water through the hose, but do not use the sink which you removed the drain line from or it could leak under the cabinet. If you see a bad kink replace the hose with a new one. I hope this works and you find the problem without a great deal of time or trouble.
Nov 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
In trying to free my gabirator of goop the whole garbiraror came away from the top under the sink attachment. what to do please
If I understand correctly, your garbage disposal came loose from the sink basket.
The darker blue arrows point to the connector disc.
The connector disc rotates freely when garbage disposal is not connected to sink basket.
The trick is to lift the disposal into place with one hand.
Push up hard while keeping disposal lined up with sink basket.
Then use other hand to rotate connector until it catches on sink basket.
Before starting:
Disconnect the tubular drain pipes because these pipes will have to be re-sealed.
The electric wire and dishwasher hose can stay connected
If you are disabled or impaired, use a car jack or bottle jack to lift the disposal ... but go slow and don't lift the whole sink.
Now to reconnect the tubular drain pipes.
Disassemble these pipes.
Clean the pipes and washers.
If washers are rubber, buy new ones.
If washers are plastic, re-use old ones after they are cleaned.
I use rectoseal on all tubular washers when installing pipes under the sink.
Coat the washers with plenty of rectoseal and the tubular drain pipes will seal first-time with no leaks.
Nov 11, 2010 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Water is coming out of air flow gap. I installed a new air-flow gap and all new lines from air flow gap to sink (except the line from dishwasher to air flow gap) and i still have water coming out the air...
The leak in an air gap is usually caused by a clogged sink discharge line. Most of the time this is connected to the garbage disposal and there is food particulate in the drain hole where the dishwasher drain from the air gap to the garbage disposal connects.
Pull the sink connection hose off and clean the hole thoroughly. You can try testing the dishwasher/ air gap by placing the disconnected hose into a bucket during the pump out period. It should not leak. After this test...reconnect the hose to the sink connection.
If it is NOT connected to the garbage disposal then remove the hose and clean out the hole where the connection is made. This is a common problem and easily resolved by the user.
Thanks for using FixYa.
Kelly .
May 18, 2010 | GE Nautilus 24" Built-in Dishwasher
Just replaced our disposal and now our dishwasher will not drain. Any suggestions?
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher will not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Dec 20, 2009 | Whirlpool Dishwashers
After isntallation my dishwasher doesn't drain correctly. What could be the cause of that? Is that possible that conected incorrectly? or may be have to program it?
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly. If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher. Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
Jun 15, 2009 | Dishwashers
Dishwasher draining into kitchen sink!
Is the water coming out the holes of the airgap "vent". If so, you have an obstruction from the hose that goes from the "vent" to the garbage disposer and is causing the drain water to back up. __________________
Jan 12, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwasher does not drain completely, has standing water after every complete cycle.
  • Some water, usually one to two cups, remaining in the bottom of the tub is normal. However, if water is covering the bottom of the tub, the dishwasher is not draining properly.
  • Check for paper or large objects covering or blocking the sump area in the rear of the tub.
  • Make sure that the right type and amount of detergent is used: Using the wrong type or too much detergent can cause sudsing that can prevent the dishwasher from draining. Only detergent specifically designed for automatic dishwashers such as Electrasol®, Cascade® or Cascade Complete® should be used. If you find suds in the dishwasher.
  • Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects.
    Please consult the Owner's Manual. Download a free copy of the Owners Manual and/or Installation Instructions. In the Installation Instructions, will be the procedure for removal of the drain plug. You may also check with the installer.
  • Be sure the kitchen sink drain is not clogged. The dishwasher typically drains into the kitchen sink drain or a garbage disposer. If the dishwasher drains into a garbage disposer, run the disposer to clear the drain system. Do not put hands into the garbage disposer. Serious injury could result. You should always turn on your garbage disposer prior to running the dishwasher to clean out any food or debris within the drain system.
  • Check drain hose where it connects below the sink for blockage or a kink in the hose. New dishwashers come with a white corrugated drain hose, which should be used. Re-using old, worn out drain hoses may promote kinking and blockage. If it is neccessary to extend the length of the corrugated drain hose, be sure the total length does not exceed 120 inches and the extention used is not kinked or crushed. See your dishwasher installation instructions for details.
  • Check the air gap if one is installed. It could be clogged. An air gap (not part of the dishwasher) is usually located on top of the sink. Some state or local plumbing codes require the use of an air gap between the built-in dishwasher and the drain system of the home. This plumbing device is used to prevent the possibility of back flow into the dishwasher in the event of a clogged drain system. This item is not a part of the dishwasher and, therefore, the dishwasher warranty does not cover costs related to cleaning or repairing a drain air gap.
  • Typical air gaps are easy to inspect and clean. Be sure the dishwasher latch is in the OFF position or unlatched prior to removal of the drain air gap cover. Simply lift off the cover (usually chrome, could plastic) and unscrew or unsnap (depending on type of air gap) the plastic cap below. Remove any material that may have accumulated and replace the plastic cap and chrome cover. This simple procedure should be followed any time the dishwasher fails to drain properly.
    View a short video about cleaning the air gap:
    Play Video
    Sometimes perceived "no drain" problems are not "no drain" problems at all, but back flow of water from the sink or some other device into the dishwasher:
  • If you notice dirty water building up over time in the bottom of the dishwasher and do not have an air gap, make sure you have a high drain loop. A high drain loop is created when the drain hose is makes a loop at least 18 inches above the floor. Usually this is accomplished by attaching the drain hose to the underside of the countertop. Without a high drain loop or air gap, dirty water from the sink can flow into the dishwasher. The high drain loop prevents back flow of water from the drain into the dishwasher if an air gap is not installed. View a short video about a high drain loop:
    Play Video
May 08, 2008 | Dishwashers
Dish washer
The drain in to the garbage diposal is clogged.  Remove the drain hose from the dishwasher and clean the hose.  Also check the inlet to the garbage disposer and clena it.
Oct 28, 2007 | Dishwashers
Dishwashers Logo
110 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
