Question about Samsung Refrigerators
Right Side temp is going high, evaporator frosted
I have a Samsung RS263BBWP since 2006, since a month ago, temperature is starting going up to 60F on the right side, freezer is working perfect. After 2 days reading on the internet I decided to open the fridge side (right side) and found the evaporator frosted, so I checked the defrost temp sensor, but it was fine, then I executed a manual defrost and did it fine (so the heater is ok), I did the self test, and no error indicated on the panel, so I though it was the main PCB unit busted, so I replace it by a new one, and still the same issue. I check the fan and looks like is operating at normal speed (at least keep things cool when is not frosted).
What else can I do or check to find out the original source of the issue? Thanks in advance! Denis
  • 10,319 Answers
Did you change the orfice tube? The screen may well plugged up causing this
Posted on May 31, 2010
  • Denis Santana May 31, 2010
    What is and where is located?
    Thanks!
Above set point temperature
Any excesive door opening will cause frosting. The high temp experienced may have been during a defrost cycle, or because the defrost hadn't cleared all the ice and you were getting a lack of air over the evaporator.
Apr 20, 2014 | Frigidaire Freezers
Srs618dp model samsung noisy and lose temperature
I have a Samsung srs618dp side by side fridge. I have just turned it on after 5 months and it seems to be working however every 30 seconds it keeps beeping, very annoying. There is no ice build up.
Apr 06, 2013 | Samsung RS2630SH Side by Side Refrigerator
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Jan 28, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
Samsung RSH!NHSW fridge freezer Freezer fine. Fridge icing up. temperature between 8 and 10. Will not go lower. In cool place. Why?
We've just had exactly the same problem on our RSH1DBRS. After a recommendation from a friend of ours, we bought a DIY kit from Appliance DIY Repairs. It's a very simple repair, and ours is working just great. We had Comet out to it a month ago, but whatever they did never worked, and it went wrong again within a week. So it looks like the DIY idea worked!!!!!
Feb 07, 2011 | Samsung Refrigerators
Bought a brand new LG bottom freezer fridge a couple of months ago. I like the refridgerator part to be cold, so we keep the fridge temp on 6 (1-7 are temp choices. 7 being the coldest). We had the freezer...
If designed as most combination units, one of the two controls influences the temperature directly, the other only determines how much of the generated cold air is allowed to enter the other compartment. The typical arrangement is that setting the freezer temperature determines how often often the compressor runs; the other diverts a portion of the cold air into the refrigerator side.
Using the common thermometer for cold temperatures (~$5 US), adjust the freezer temperature for 0 to -5 degrees F (the often recommended temp.), then the other control for the desired refrigerator temperature, suggested as 35-45 F. This is the most common practice.
If you cannot balance them the way you want, reverse the procedure, setting for refrigerator temp., then freezer.
Dec 13, 2010 | LG LBN22515 Bottom Freezer Refrigerator
2 months ago or so, found puddle of water in front of our freezer; about 1 month ago ice cream in freezer became soft. High temp alarm went off a week ago--I've checked the temperature intermittenly and...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Aug 22, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
My side by side fridge has stopped chilling down, the power is Ok, and moter seems to be working, but no cold inside. A few months ago the freezer side stopped, but as i did not use it , i just left well...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Air conditioner in 1999 mercury tracer won't work. It's not the compressor nor does it have a leak. what could be the problem?
the tracer is the same as the ESCORT, right?? TRY THIS--I WORK ON PLENTY OF ESCORTS--LOOK UNDER THE AIR CLEANER/CONE ASSEMBLY--THERE WILL BE A BLACK METAL BOX(FULL OF RELAYS) ONE OF WHICH IS THE A/C RELAY--TRY TAPPING ON IT WITH A LONG SCREWDRIVER OR SOMETHING SIMILAR WHILE U HAVE THE A/C ON. IF THE A/C SUDDENLY STARTS WORKING U NEED TO GET A NEW RELAY BOX(I THINK ITS CALLED A GEM MODULE) i do have a question- does the blower motor work?? how do u know the compressor is good??do you have 12 volts going to it??? this relay box is pretty common to go bad--u have to remove the air cleaner in order to get to it.get back to me.
Sep 07, 2009 | 1999 Mercury Tracer
Refrigerators Logo
124 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
