Question about Kenmore Elite HE4 Electric Dryer
No current but light is on in dryer but not on dials.
Was running but not heating. now not running at all but the light is still on inside of the dryer.
  • 10,319 Answers
Your dryer is 220 volts. that will have two 110 lines going into it
one of the lines is for the motor & heating grid only
The other line runs the rest
Posted on May 31, 2010
If the dryer inside light comes on can the thermal fuse ok
No relations at all......
Light comes on means there is power and your door is open.
Thermal fuse failure means there is no heat. No current going through your heating circuit. Most models and brands will still turn the drum without heat. But there are some models thermal fuse will completely shut the power to heating circuit and drum motor. Like KENMORE certain dryers made by Whirlpool corporation
Jul 22, 2014 | GE GTDP180EDWW Electric Dryers
My dryer lights up like its working, with NO error code... just the 0:00 on the timer. The start/pause light blinks, the lint filter light blinks, and the wrinkle light stays lit. Ive vacuumed and cleaned...
there are many things to be checked if you can try this is the solution.but cant do if not getting it properly. because the problem is very minor because the power light is coming.you can call the tecnician the cost will not more than his service charge.
the procedure is here you can check if you can
, over temp protection activating due to insufficient ventillation or motor is defective and heating up excessively.normally if both drum support wheels are worn or defective,plus if veld strip on drum is worn, motor will overwork and fail.
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
thanks mam
Aug 14, 2008 | Bosch Dryers
Why does my Zanussi td4212w tumble dryer work but no heat?
check continueiy in the ellement and the thermostat
check the thermo with out 1 wire on........cheers
Jul 18, 2014 | Zanussi Dryers
Heat is not always coming on in dryer. Roper dryer from Lowes
There are numerous temperature sensors on the dryer. Some are near the drum, some could be near the lint filter if it is located inside the dryer door. Try changing these first as they are an in expensive fix. It could also be the heating coils themselves. Highly unlikely it would be the dial, unless the dial was accidentally turned in the wrong direction.
Apr 26, 2010 | Roper REX4634KQ Electric Dryer
Heating Element
Jun 27, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Timer won't shut off.
probably bad timer.. motor or gears on inside are bad
Jun 13, 2008 | Hotpoint NVL333EY Electric Dryer
Dryer not drying clothes
Jun 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Whirlpool dryer with no heat
Is the igniter glowing yellow? Look inside the pilot access hole and see if it lights up. If it lights up then goes off, it may be the thermal fuse. Once this blows, it has to be replaced. There are pictures all over the internet on the location of this part.
Good luck.
Apr 16, 2008 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
77 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
