Question about Konica Minolta Office Equipment & Supplies
Konica 7065 with an error message of F341 problem
    Problem Solver:
  • 10 Answers
Hi code 34-1 is fuser temp fault to reset turn off machine hold down buttons 2and 5 and turn on release 2 and 5 a menu screen will show select 1 software switch settings you need to switch no3-1 3-2 3-3 3-4 to off then try if still fails there is a good chance a heater has blown in the exit fusing unit or its temp sensor is faulty definately a technician required hope this helps:)
Posted on Jul 11, 2010
F52-1 error code on konica 7055
Check all fans, and filters might need a good cleaning around them.
May 27, 2014 | Konica Minolta Copier Toner 7055/7065...
Error code E-22-1
Please the copier model.In Dialta model the code refere to main body main motor malfunction.
Feb 12, 2013 | Konica Minolta Copier Toner 7055/7065...
I have a Konica 7065 I need to replace the developer in it and then I will need to reset the counter
to reset counter turn off main switch hold down 2and 5 turn on release 2 and 5 a different screen will show select 3 PM count/ cycle, set off and is done
Jun 16, 2010 | Konica Minolta Office Equipment & Supplies
Konica 7065 with error code F36- 1
Sir,
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "3" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Feb 25, 2010 | Office Equipment & Supplies
I have a Konica 7065 and a dont' have the ECM password how can i find it.... Ever Vega
you can accessf the ecm but you have to know the old password to get all the information. if you don;t know you will lose all the info. press p and enter 9272 and it is under 25 mode. the password 12345678.
Jun 28, 2009 | Konica Minolta Riva Zoom 70 35mm Point and...
Error Message on copier.
Probably a thermistor problem, dirty or out of position or failed. Could be thermostat too.You will want to check that fuser out first before you reset any codes. Checking for paper, sensors, etc...
If all is clear in the fuser then:
With the power off, hold the 2 and 5 button on the panel and turn the power on. In the display you will see, there are 1-12 choices, choose 1, Software SW. You will see a display of numbers (01-0:1 03). Change the first number to 03, change the second number to 01, change the third number to 00. Press RETURN on the display. Power the unit off, then on. Codes should be reset.
If after resetting the code and powering up machine -- if code comes back then replace the above mentioned.
Jan 23, 2009 | Office Equipment & Supplies
Code F34-1 means for a Konica 7065
To reset a fuser abnormality code, perform the following:
1. Power the copier OFF.
2. Access the 25 mode (power the copier ON, while holding down on the 2 and 5 keys).
3. Touch [1: Software SW setting] on the touchscreen.
4. Touch the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
5. Select the bit number of the switch 1, using the right up-arrow.
6. Touch the [OFF (0)] key, which is displayed on the touchscreen.
7. Power the machine OFF/ON to exit the 25 mode.
good luck
Nov 24, 2008 | Office Equipment & Supplies
201 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
