Question about Mastercool 67680 Evaporative Cooler Air Conditioner
We have a blinking drain light on our evaporative cooler control pad. What does this mean? Should we push the drain button?
4 Suggested Answers
SOURCE: AC pad not fully getting saturated with water
1. Make sure the pump is getting plenty of water.
2. Make sure the pump is working.
3. Check the pvc pipe with drip holes are not plug. (above the pads )
4. Check the pads directional arrow that should be facing up. When pads are initially installed you can see arrows on the pads. The arrows should be in the up direction. That will allow the pads to get saturated more efficiently.
I hope these steps help you.
Jerry,
Posted on May 08, 2009
jeffbvegas1
  • 520 Answers
SOURCE: need replacement pads for mastercool mrc55wa
These pads are available in different sizes and styles at home improvement stores like LOWES or HOME DEPOT (in season)
Posted on Sep 18, 2009
  • 59 Answers
SOURCE: I need to know what type of pads is required for
need model #
Posted on Apr 22, 2010
What is a flashing 4
What brand is it. If its an evaporative cooler like breezair or braemar it means it is not draining the water. If so check the drain pipe and the drain valve
Sep 11, 2014 | Hunter Heating & Cooling
Information needed: Celsius WF-604 Air Cooler - Their are 2 Push Button Switches on the cooler the: The Cool Push Button Switch and the Swing Push Button Switch. This creates a total of 4 sets of...
The on/off COOL switch controls the moving pad (on rollers), when ON the pad rollers rotate and pull the pads around in a circle. Pad picks up water at the bottom and evaporates water at it rises, thus it is an evaporation cooler.
The on/off SWING switch controls the oscillating louvers which can be stationary or moving left and right. It directs the air flow from straight ahead to the sides.
Either can be on or off.
The Speed controls switch, which you did not mention, determines how fast the fan blades will spin.
Aug 21, 2011 | Heating & Cooling
Have lost instructions to Emerson universal jumbo remote
Using Code Search:
1. Turn on the device you want to program into the remote.
2. Point your remote control at the device
3. Press and hold the "Code Search" button for about 3 seconds until the light on the remote stays on.
4. Press the button on the remote for the device you want to program. Push the "TV" button to program the TV, press the "DVD" button to program the DVD player, etc. The light on the remote control will blink and stay on.
5. Slowly press and release the power button repeatedly until the device turns off. Each time you push the power button the light should blink once.
6. Press "Enter" to save the code into the remote and the light will turn off.
Program a Manual Code:
1. First turn on the device that you want to program such as your TV or DVD player.
2. Point your remote control at the device.
3. Press the button on the remote that corresponds to the device. If you want to program the TV, press the TV button.
4. Press the "Code Search" button for about 3 seconds until the light stays on.
5. Enter the code for your device using the number pad. The light will blink each time you push a button. If the code works, the light will turn off. If the light flashes, that means the code did not work. There may be multiple codes for a device. If a code does not work, start from the beginning by holding down code search until the light stays on and use a new code.
6. Press the power button to test if your device turns off. It it does not turn off, repeat the process with a new code.
Retrieving the Code for your Device:
If you used the code search function to program your device and want to know the code for future reference, you can retrieve the code from the remote. To do this:
1. Press and hold the Code Search for 3 seconds until the light stays on.
2. Press the device button for the code you want to retrieve. Press TV to get the TV code, etc. The light will blink once and stay on.
3. Press the number buttons from 0 to 9. When the light blinks once, that signals the first number of the code.
4. Repeat for the 2nd and 3rd digits of the code. The light will turn off after you retrieve the 3rd digit.
Programming the Sleep Setting:
1. Press and hold the "SLEEP" button until the light stays on.
2. Use the number pad to enter 2 digits for how many minutes to use for the timer (01 to 99 minutes). The light will turn off and start timing.
3. Make sure the remote is pointing at your device.
4. To cancel the sleep timer, press the power button once or hold down the sleep button until the light flashes once.
Here is a list of the Emerson Universal Codes:
http://www.jumboremotecontrol.com/remote_control_code_list.html
Here is a copy of your manual: http://www.jumboremotecontrol.com/innovage_jumbo_remote_manual.PDF
Mar 08, 2011 | Televison & Video
I have an evaporative cooler: vulcan bonaire. the only control buttons which appear to be useful are: on/off, cool in the 'appliance' window, and cool in the 'mode' window. i have a feeling that this is...
Hi and welcome to FixYa. The principle of operation of an evaporative cooler is to provide cooler air via evaporation. The evaporation process is achieved by water being pumped over very porous pads with air is drawn through the pads. Most all evaporative coolers unless connected with a centralized heat / cool system only have an on / off & cool function. "On" is fan only (air circulation while using outside air being drawn into the home) and "cool" turns on the pump to pump water over the pads for evaporative cooling. Hopefully I did not confuse you with my answer.
Happy New Year and thanks for choosing FixYa,
Kelly
Jan 01, 2011 | Heating & Cooling
Ive got a mildewy smell coming from my evaporative cooler how do i get rid of it?
This unit needs to be serviced. Try replacing the pads with the sponge like pads.Drain the old water and clean up the pan and pump area. Go down to a pool supply store and buy some chlorine tablets and add to the water. In fact, they make these tablets just for the evaporator units. There are 3 states to water, solid, liquid and gas,
. This will get rid of the smell.
Sincerely, shastalaker7
Oct 28, 2009 | Mastercool 67471 Evaporative Cooler Air...
We have a Mastercool II & it was installed ~ 3
The pads you need are at least 8 inches thick. If you have the contractor model, then the pads will be 12 inches thick.
Find a distributor in your town that sells cooler parts, if they dont have them, some of the big home improvement stores carry the pads for your cooler.
Make sure you are using a bleedoff or a dump pump to eliminate the hard water out of the cooler. If you keep those pads clean, they wiil last for many years.
Jul 20, 2009 | Mastercool 67680 Evaporative Cooler Air...
True TBB-2 Cooler issue
BY to I take it yu mean top area inside cooler. If that is the case and yu are sure the drain is clear it could possibly be one of the following.
1: rusted/ corrodid evaporator drain pan
2: coil in cooler partially frozen
Jun 28, 2008 | True TBB-2 Beverage Cooler
Mastercool 67680 Evaporative Cooler Air Conditioner Logo
93 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
Boyet Soriano
Boyet Soriano
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
