Question about Stanley Fatmax Xtreme Retractable Utility Knife
Change blades I just need a picture /instruction for blade change
    President:
  • 1,902 Answers
The gold looking circle on the side of the utility knife. Just unscrew that and it will pop open then you can change the blade. I looked everywhere and am unable to find the instruction or picture. I own one and that is why I am answering this for you. Please rate
Posted on May 31, 2010
I need a manual for CJ500 jig saw. I can't work out how to change the blade.
Ryobi has a customer support questionnaire that you can fill in to ask a question http://ryobi.custhelp.com/app/support/ask/incidents.c$enquiry_type/11
I suggest that because their database of instruction manuals seems to be having problems. I did find a picture of one of those saws and it appears that there are 2 hex screws that hold the blade in. it's the hex caps in FRONT of the top of the blade. Loosen those hex cap screws and the old blade should fall out.
Jan 16, 2015 | Saws
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
I HAVE A DW716 MITER SAW AND NEED TO CHANGE THE BLADE, BUT I'M NOT SURE EXACTLY HOW TO REMOVE THE BLADE GUARD. I KNOW THAT I NEED TO PURCHASE THE CORRECT BLADE WRENCH TO DO THE JOB. CAN YOU TELL ME THE...
Hi there
You do not need to remove the blade gaurd to change the blade. You only need to raise it enough to acces the blade screw. Unplug the saw. Raise the blade arm. Raise the guard to it's upper position. On the left side of the blade, just forward and up slightly from the blade screw is a screw for the guard bracket. Loosen, but do not remove this screw. Once it's loosened the guard can be raised farther exposing the blade screw.
pg 6 of the manual illustrates this process, here's a link so you can see the parts I am discribing,
http://servicenet.dewalt.com/Products/Detail?isId=true&productNumber=DW716&selectedType=12803#
click the pdf icon next to instruction manual, then open the file.
As for the blade wrench, this should have come with the saw, there is a slot in the base for storing the wrench, on the back left side, it slides in and out for safe keeping. If you have misplaced the wrench the DEWALT part number 608563-1
Dec 31, 2010 | Dewalt 12" Beveling Sliding Compound Miter...
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Instructions to install blade on circular saw
Once you have the right size blade it is really simple to change it.
You only really need two things.
1. locate the button that locks the spindle. It is usually located on the body of the saw. Your manual can show you a picture of it.
2. You will need a 3/8 drive socket that fits the spindle bolt.
I believe these are standard thread orientation and come off counterclockwise.
Mar 20, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
How do you change the blades on an exact saw, i
try putting a nail or screw driver through the vent holes in the blade or clamp the blade
Sep 30, 2009 | Saws
HOW TO CHANGE WIPER BLADES ON A 2004 TOYOTA HIGHLANDER
Here is a website for installing refill blades. It requires you to select your blade type from the pictures. Onse selected, there is a nice instruction to install your refill:
http://www.brandsport.com/towiwiblandi.html
I hope this helps... Good luck!
Aug 26, 2009 | 2004 Toyota Highlander
My husband has a BLACK & DECKER JS515 VARIABLE SPEED JIG SAW WITH QUICK CLAMP 3.5 AMP which i accidently broke the blade on...i cant figure out how to change the blade..any help would be greatly...
Here is a link to the instruction manual, and just under the place where it says Save These Instructions it tells you how to change the blade.
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90520882,JS515.pdf
Fitting the saw blade (figure A)
- Hold the saw blade (9) as shown, with teeth facing forward.
- Push the lever (3) downwards.
- Insert the shank of the saw blade into the blade holder (10) as far as it will go.
- Release the lever.
There is a little lever where the base of the blade fits into the holder that you depress to release the blade...You can see a picture of it in the manual.
I hope this answers your question...if so, please take a aec to rate this post...thanks.
Mar 23, 2009 | Black & Decker Single Speed Jig Saw
HOW TO CHANGE BLADES ON CONAIR HCT 426 HAIR TRIMMER
digram on how to replace my blade in my hair trimmer conair hc3180v
Feb 01, 2009 | Conair HCT-426 Hair Trimmer
RYOBI TS254 change saw blade???
should have blade lock button remove blade with proper size wrench reinstall new blade in reverse remember some of these the loosening of the blade will be clockwise so if nut dont come loose try clockwise to loosen good luck
Apr 22, 2008 | Irwin Miter Saw Laser Guide Attachment...
Stanley Fatmax Xtreme Retractable Utility Knife Logo
407 people viewed this question
Top Stanley Measuring Tools & Sensors Experts
Lawrence Oravetz
Vernon Taylor
Steve
Are you a Stanley Measuring Tool and Sensor Expert? Answer questions, earn points and help others
