Question about Belkin N Wireless Router wireless router
Keep getting kicked off
If I have cable hooked it works fine but wireless will kick me off after awhile and I then need to hit repair to make it work...
Hooked to neighbors wireless and worked for 5 hrs till I disconnected...
  • 1,305 Answers
When sharing internet connection, it's all about sequence when turning it on... Sequence in regard to what's turned on first, second etc... Here's the solution:
1. Turn everything off... modem, router...computers etc..
2. Turn on the wireless router FIRST and let it boot up.
3. Then turn on the modem and let it cycle up...
This allows your modem to lock onto the wifi router.
4. Turn everything else back on...
You should be good to go without drop outs...
If the power goes out, simply follow this sequence...
It's all about the sequence!!
Posted on May 31, 2010
Testimonial: "This works...Stayed on hours without interruption...Thanks"
    President:
  • 1,768 Answers
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP adresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Truck will not start how can i tell if its a starter or selonoid
does it spin real fast without clanging and grinding against the flywheel? if so then its probably the solenoid bad. do you have to hit the starter with a hammer then it works? it is probably bad brushes or a worn motor. eather way i think you can only get a new starter and solenoid together not sold seperate. check for bad battery cables (loose).
May 30, 2011 | 1996 Chevrolet K1500
Trying to hook my Wii up wirelessly,
sounds to me like you need to reset your ip addresss or reset the modem and reload the informtion for the user to connect to the wii again
Apr 27, 2010 | Zoom X6 (5590) DSL Modem (55900003)
My D-link 615 won't power up. Was working fine,
you try the factory reset button , but if you are getting no power at all to the router - power adapter may be broken or the router
Mar 08, 2010 | D-Link Computers & Internet
Hooked up the amp, lights up, fans kick on and run fine, speakers hooked up proper, no sound? hooked up speakers to another amp and they work fine. Fuses are all good too. Thoughts?
could be bad rca cables or no output from the radio rca outputs. the sub control may be turned off on the radio (ive seen that alot at my work). if all that is fine, the amplifier may be bad. the rca cables may be plugged into the "out" section of the amp. gotta look at all the small obvious things first. good luck.
Dec 18, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Tansmission kicks in gear hard
change the fluid and filter to ensure oil flow inside the transmission, if the problem persists, check and adjust the kickdown cable, hope this helps, let me know.
Nov 19, 2009 | 1999 Ford Windstar
"kick starter will not turn motor over" i let a freind ride my 1999 380 exc last night and he told me while he was riding the kick starter hit him in the leg then heard a vibrating sound,i'm thinking more...
this is due to the mechanism inside the gearbox, try draining the gearbox oil and takeing the side case off and putting the mechanism back in the correct place but be very careful of the kick start spring that it doesnt hit you wen it comes off, the spring will need to be twisted round twice then hooked back on the locator when putting back together
Mar 02, 2009 | KTM EXC 380 Motorcycles
Belkin N Wireless Router  wireless router Logo
217 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
