Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I pulled the emergency rope on my door opener. How to fix the chain back on the pully?
    President:
  • 3,197 Answers
Pull straight down on the rope and release. Then bring the two halves of the trolley together either by moving the door by hand or running the motor.
Posted on Jun 01, 2010
Imam trying to reset the down limits on my genie silent max 1000 but it goes a few inches then stops I press again same thing... it will open but reverse semms jameed
You need to pull the emergency release and allow the door to rest on the floor. Next loosen the tensioner bolt on the chain and rotate the chain around the drive sprocket at the motor until the carrier ( the part the emergency release locks into) engages into the arm that pulls the door. Once the emergency release latches back into the carrier you can tighten the tensioner bolt on the chain.
Feb 26, 2017 | Building Materials
My garage door will not open. I pulled on the emergency rope to see if that would help but it did not.
Your torsion spring is probably broken. After you pull on the emergency rope, press the remote, that should move the chain and emergency lock out of the way, then you and 1 or 2 other people may be able to lift the door up if you really need to get the vehicle out. It depends if it is a single or double door or wood or metal, how heavy it will be. This can be dangerous and it could fall down on you. Check your torsion spring above the top of the door when closed, if there are two pieces then it is broken (on a single door.) A double door will have two springs, one on each side. One may be broken. You will need to get all the springs replaced, it counterbalances the door. If you have a garage door with arms on it, then the compression/extension spring is probably broken. If you are mechanically inclined, you can replace them, it is dangerous, be sure to watch a UTUBE video on it.
Dec 21, 2014 | Building Materials
Have i/3hp motor runs but door won't open think it's off the track, how do I get it back on track
It may be that your torsion spring is broken. Look at the spring about the door opening. It is horizontal, and should be in one piece about 30" long. Sometimes 6" breaks off and then the spring will not counterbalance the door and the motor will not be able to move it. If the spring is ok, then release the emergency pull rope, red handle. Now move the door up and down by hand and see if it is jamming somewhere. Be careful not to stand directly under the door with the emergency cord released.
Dec 07, 2014 | Building Materials
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
I Have a Liftmaster Professional Formula 1 garage door opener. When we press button on wall or garage door opener, we hear the motor going but the garage door doesn't do anything. Do I need a new opener?
There is a rope or string hanging down that releases the dog that hooks the door to the chain...if someone pulled that the door will not open. You need to pull down and back on the srting to relaese the dog and then push the door up to catch the chain...then the door will work again...
heatman101
Aug 14, 2010 | liftmaster Chamberlain Garage Door Opener...
Lawnmower rope pull start, has rewound back into housing and locked? How can I get it to release so that I can reconnect it to the lawnmower handle?
You will have to take the top off.It has 3 bolts on the sides of the motor.Pull top off,hopefull you just have pull rope out to fix.The rope on the pully has a spring in the bottom of the pully.Do not pull out pully,you will have a hard time gettig it back in.
Aug 29, 2009 | Craftsman Garden
Garage door opener won't work
you should have installed a emergency key release !, it,s a cylinder that you put a key into and pull out a cable thats attached to your emergency release inside the garage , right now you would have been in already , but since you never installed one lets deal with the problem at hand , answer me this : do you have power inside the garage ,are you certain that the breaker is on ,did you have any recent power failures ?, because the circuit board on your machine could be fried from a close lightning stike , and i,ve seen it a thousand times , also your capacitor on your machine may be shot ! is your door wood or steel? if its wood drill out a 3 inch hole saw hole on the top panel either to the left or right of the center wooden cross member , now get a flashlight and look for a emergency relese rope , after you have located it,make yourself a coathanger with a hook at the end ,tug at the rope until your able to pull at the handle thats attached to the rope once you are able to release the door from the carriage assembly keep pressure on the handle and have someone else lift the door and when you want to fix the hole you made just simply glue the circle cutout back in place , good luck and do what i say to get in , please leave a nice rating if i was able to help you ,sincerely glenn
Apr 11, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
288 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
