Question about Frigidaire Affinity ATF7000ES Front Load Washer
Error code E10 what is it - Frigidaire Affinity ATF7000ES Front Load Washer
    President:
  • 1,382 Answers
When error code E10 appears just take the cold water off the inlet tube to the washing machine, then clean the screen using light force air then replace the hose .Finally turn the water back on.This should solve the problem. If not the door latch needs adjusting or tightening up. It's probably something really simple like a loose screw.
Thank you !!
Posted on May 31, 2010
3 Suggested Answers
SOURCE: error code E10 on frigidaire
I have the same problem.  I'm going to search the frigidaire web sight
Posted on Aug 07, 2008
SOURCE: e10 error code
1 beep and E10 is listed as the dispenser door is open. Try reclosing your soap dispenser door tight.
Posted on May 21, 2009
I have a Canon SX 30is. When I press the power button, I get an E10 error message, and then the camera never turns on. How do I fix this?
Unfortunately, canon tends to use the same error codes across models...particularly the E10 error code which indicates a JPEG IC error. Basically, the image processor has just given up. I don't know of a way to fix it other than to completely dissect the camera and replace the entire board. Definitely not the news I wanted to deliver but I've seen that error on three separate cameras, and opening up the firmware files for each indicated E10 as being the same error. Any chance its still under warranty?
Sorry to be the bearer of bad news, but I hope that helps!
Oct 23, 2013 | Canon PowerShot SX30 IS Digital Camera
Error code
The E10 error code indicates the control does not see a proper fill. Here are a few things you can easily check. Always unplug or de-energize electrical equipment before removing covers or attempting service. Be careful and wear appropriate hand protection when working around sharp metal parts.
Apr 22, 2012 | Smeg WDI12 Front Load Washer / Dryer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
I keep getting an E1 Error code on my Whirlpool Duet dryer. Technician came and didn't fix it. Any suggestions?
Aug 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer-error code e-1?
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E10 error code. I have to keep hitting the start
hi
it is water pump error ,,please check it thank u,,
please rate it
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
E10 error code
Jan 18, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Jan 10, 2009 | Frigidaire ATF6000ES Front Load Washer
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Washing Machines Logo
567 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
