Question about Bosch HBL5650UC Electric Double Oven
"E005 communication error" when power turned on.
HBL 565OUC Brand new; have tried flipping circuit breaker on/off two-three times with same result.
3 Suggested Answers
SOURCE: E005 Communication error
Got this error this morning and it cleared when I turned off the circuit breaker and turned it back on.
Oven is now working
Posted on Mar 14, 2009
  • 327 Answers
SOURCE: We just plugged in our oven and it has E005
1. Turn the clock selector knob to OFF
2. Tweak the oven control by turning the clock selector knob slightly to the left (counter clockwise).
This may stop the popping message.
Thanks
Posted on May 31, 2010
FPET305KF8
Hello Bree, thank you for allowing me to assist you!
Let's try resetting your wall oven by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your appliance on. Now set the time and try turning on the oven. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, a communication error with the EOC (electronic oven control), faulty door latch assembly or element(s). Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Dec 16, 2013 | Frigidaire 27 in. Electric Gallery Pro...
The oven won't heat to bake. It looks like it should work. It was able to self clean a few days ago but will not bake now. Help
Good Morning John, thank you for allowing me to assist you!
Let's try resetting your wall oven by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit on. Now set the time and turn on your oven. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, a communication error with the EOC (electronic oven control), or faulty power supply. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Best regards!
Oct 23, 2013 | Frigidaire FEB30S6FC Stainless Steel...
When trying the clean mode on the oven, it locked up, did not clean, and is not stuck in lock mode. How do I reset it? Turning off curcuit breaker did not help.
Hi Jim, thank you for your post! Once you have the flipped the circuit breaker it is important to wait roughly ten to fifteen minutes. If resetting the power does not correct the issue, you range could be experiencing a communication error with the EOC (electronic oven control), faulty door lock assembly, or could have wiring failure. In that case, a certified technician would generally replace the faulty part after proper diagnosis.
Aug 22, 2013 | Electrolux ICON Designer E30SO75ESS Oven
Frigidaire single electric oven will not power up and the screen shows an upside down and a period....or an eight with top cut off. This happened after I cleaned the oven.
Hello Veretta, thank you for your inquiry! Let's try resetting the wall oven by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit back on. Now set the time and try turning on the oven. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, a communication error with the EOC (electronic oven control), or faulty door latch assembly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the appliance.
Aug 15, 2013 | Frigidaire Ovens
We cleaned my kenmore elite oven. now it won't work. when i try and turn it on i get an F23 error. do you know how to get the oven/stove working again?
Error code F 23 indicates the control detected a problem with the communication link or can be generated as a result of irregularities in the power supply or usage.
  • The error code F23 can often be resolved by removing power to the appliance for a minute and then restoring the power.
  • By unplugging the appliance it allows the control to receive a fresh supply of power. This in turn will clear the controls memory of any irregularities it may have received from the power supply. Once refreshed the error should no longer be displayed.
  1. Unplug the unit or turn the circuit breaker off for 60 seconds.
  2. Restore the power to the appliance by plugging it back in or turning the circuit breaker back on.
  3. Check to see if the error code is still displayed on the range.
  4. Run the appliance in the cycle that initially caused the error or attempt to turn on broiler.
If the error code is displayed, then service is needed. The unit should be inspected by a qualified appliance repair technician.
Should you choose to use Sears, the number to schedule a repair tech is: Sears Repair Department 1-800-469-4663.
Nov 23, 2010 | Kenmore Ovens
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
Oven is now working
Mar 12, 2009 | Thermador M271ES Electric Single Oven
GE JT912-30 single wall oven "help" with F7 - F0 error
I have a double oven GE Profile. The error message FO appeared. I shut off the circuit breaker for 30 minutes or more and the oven works but without warning FO reappears. FO message means there is short in the clear Off touch button. The only solution replace the complete panel. My cost delivered $328. Ouch!
Jan 19, 2009 | GE Profile JKP56 Electric Double Oven
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Thermador MEM301- E005 Error
turn off the circuit breaker and turn it on again 30 seconds later... this oven is a total waste of money...never buying another one of these again.
Dec 16, 2007 | Ovens
Bosch HBL5650UC Electric Double Oven Logo
600 people viewed this question
Top Bosch Ovens Experts
ashburton
Oloyede Monsuru
Are you a Bosch Oven Expert? Answer questions, earn points and help others
