Question about Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer ()
Missing T piece from primer bulb to carburator
I am missing the T piece from my fuel line. it connects the primer bulb fuel line to the carb. I have a craftsman weedwacker. where can i get one i
  • 1,305 Answers
Sears has replacement parts and so do the OSH stores. If there's no store close, check with a local lawnmower shop and I'm sure they've got lots of replacement parts.
Posted on May 31, 2010
How do i route the fuel lines to the carburator ?
Depending on which carb you have it should be the fuel line closest to the bottom on the right side of the carb that goes to the small side of the primer bulb. The long side of the primer bulb will go to the fuel tank as the return line.
Sep 12, 2014 | Poulan Garden
I changed the primer bulb and now it's not getting
sounds like you hooked the lines up backwards, when you press the primer it is supposed to squirt gas into the tank on the return line cause what it does is draw fuel through the carb and back to the tank....filter line from tank goes to fuel pump side of carb and return line on carb goes to primer bulb then opposite line on bulb to tank...... so when you press bulb it draws fuel through filter in tank through carb and back to tank ! good luck! 2StrokeJim
Jun 17, 2011 | Homelite Garden
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
I need a routing of the fuel lines from filter to, primer-in, primer-out, to carburator, out of carburator, back to tank. this is on a poulan chainsaw, 2550. Mod 952-05138. please respond.MARRY CHRISTMAS.
There are two holes in the fuel tank, it does not matter which line goes to which hole. The lines should run as follows: One line from the tank should have a filter on it, connect this line to the primer bulb and put a mark on it with a sharpie. Another line should run from the bulb to the carb, and the last should run from the carb back into the tank. After they are all in place, pump the bulb and watch the gas in the marked line. If gas is flowing from the tank through the marked line into the bulb and on to the carb you are done. If gas is flowing towards the tank in the marked line or not at all reverse the two lines on the bulb and you're done.
Dec 17, 2010 | Poulan Garden
I have a 32cc brushwaker by craftman i have intalled The fuel linee to The tank but i dont remember how to conect The libes to The primer pump and Them to The carburator
The small diameter line out of fuel tank (has filter in-tank on end) connects directly to the side of the carburetor that has the fuel pump....that is the cover without the hole in it. Other larger diameter fuel line out of tank connects to the longer nipple on the external purge/primer bulb. The bulb "pulls" fresh fuel from the fuel tank to the carb and then out of the carb to itself, where it then "pushes" any air/old fuel back into the fuel tank. The remaining larger diameter fuel line in this setup goes from the metering chamber (has cover with writing on it and a vent-hole) side of the carburetor to the smaller nipple on the purge/primer bulb. Again, on the primer bulb, the longer nipple has a line going directly from it to the tank. This is the return line. The shorter nipple on the bub has a line from it going to the metering chamber side of the carb. If the purge/primer bulb is on top of the carb...small line from carb body to small hole in tank with filter. Larger diameter line goes from the bulb on the fuel pump side of the carb to the larger hole in the fuel tank where sometimes the line is held in place with a nylon nipple connector that keeps the line from pulling out of the tank. Otherwise, the line should enter the tank for about 1/2" or so.
Nov 30, 2010 | Craftsman 25cc Gas Line Trimmer
There is a connector or something missing from the fuel overflow line from the carburetor back to the fuel tank
There is no such thing as a fuel overflow line.
If the unit has a primer bulb then there will be 2 lines in the tank ( 1 is a main fuel line distinguishable by the length of line that extends into the tank with a fuel filter on the end of it, the other is a return line from the primer bulb that terminates just inside the tank usually with a male to male conector.) The main fuel line will go to the carb and another line from the carb will go to the primer bulb. If any of these lines are discolered, fragile or broken then they should be replaced. Generally the smaller diameter line is the main fuel delivery line and the larger diameter line is the primer system.
Nov 19, 2009 | Poulan Bp406 45.4cc Backpack Leaf Blower
I had to replace the primer bulb and fuel tubing. The primer bulb just disappeared, presumably blew off. I have installed the new bulb and replaced the fuel tubing, but I need to know where the tubes...
The line with the fuel filter in the end comes out of the tank and it goes to the bottom fitting on the carburator. The other line comes out of the tank and goes to the bottom fitting on the primer bulb, and the third section goes from the top fitting on primer bulb to top fitting on carburator. Got it? lol Hope this helped and best wishes.
Aug 25, 2009 | Garden
Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
How do I install fuel lines on a poulan chain saw model 1950?From carburator to primer,from primer to fuel tank,two connections on each.
The smaller line comes from the fuel filter in the tank to the nipple on the side of the carb with the cover w/ 1large screw in the center, the other small line goes from the other nipple on the carb to the primer bulb, the larger line goes from the other nipple on the primer bulb back to the tank, and only gets pushed in about 1/2-3/4" into the tank. Hope this helps.
Feb 26, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan saw
Hi joecamp1,
My name is Dennis and I'll try to be of assistance.
1) There is a primer line kit that is of smaller diameter and it goes from the primer bulb to the tank and terminates at the fuel pick-up assembly. There is also another smaller diameter line that goes from the primer bulb to the carburetor.
2) There is also a fuel line kit that is of larger line diameter that goes from the carburetor to the fuel tank.
That's a total of three lines Tank to bulb and bulb to carburetor two lines four places to connect. and tank to carburetor that is the third line and the remaining places to connect the second place at the tank and tha last at the carburetor.
Glad to be of assistance. Please rate the solution because I can learn from your rating.
Thank you
Dennis
Nov 06, 2008 | Poulan Pro Chain Saw 46cc 20"
Craftsman 29cc 4Cycle Straight Shaft Weedwacker Gas Trimmer () Logo
199 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
