Question about Bosch Nexxt 300 Series WFMC2201UC
Mildew I cannot remove the mildew from the rubber piece where you load the washer. How can I get it clean?
  • 1,305 Answers
Take straight bleach on a white rag or towel and while wearing rubber gloves, wipe the surface until clean.
then run the towel thru a cycle with other whites ...
Posted on May 31, 2010
How do I get rid of small pieces of mildew that appears after washing. Cleaned everything on washer I can see. Ran the cleaning cycle 3x, sanitizing cycle 1x
Mix vinegar and bleach put in spray bottle,wear rubber gloves,spray on the mildew,scrub it,then run a rinse cycle.
Jul 15, 2015 | Kenmore Washing Machines
Tip
Front Loader Mildew & Odor
This advice is for preventing or getting rid off that awful mildew smell associated with front loader style washing machines.
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
on Apr 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.5 washer has developed mildew around the inside lip of the rubber surround. It has always had a terrible odor. I have used bleach to kill the mildew and now leave the door open. What do you...
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Aug 02, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer Odors of Mildew
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Neptune MAH5500BWW front-load washer. The first load of clothes sometimes has a mildew odor. How do I prevent this?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Dec 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Hi--I love my Whirlpool Duet washer, but how do I clean the door gasket and get rid of the mildew and mildew odor?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((())))
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Mildew in the tub. clothes now smell.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Jun 23, 2009 | Kenmore HE2 Plus Front Load Washer
Washer smell
Apr 06, 2009 | Kenmore 24032\24036 Top Load Washer
Mildew
allow the drum to air dry ,thats by leaving the door partially open.You will see a huge difference.And yes ,all the time.
May 26, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
Bosch Nexxt 300 Series WFMC2201UC Logo
170 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
