Question about Sears GC-922 MP3 Player
It fall down from 1.5 meters and now it can not on
    Problem Solver:
  • 7 Answers
The fell must have caused a disconnection of one of the cables connected to the logic board. Power supplying cables most probably. You need to get it opened check forums for disassembly instructions or take it to the nearest disassembly expert with the proper tools to get examined and to get any disconnected cables welded back in place.
Posted on May 31, 2010
Where is the alternator on a 2003 fxdwg
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12.5 volts or better after charging.
3. Hook up battery positive cable, then with your multimeter on the milliamp scale connect one lead to the negative battery post and the other lead to the ground cable. Meter should read 3 milliamps or less, 10 milliamps with a radio, 15 milliamps with radio and CB. If your meter reads higher you need to isolate the circuit by pulling fuses and circuit breakers one at a time and observe meter for drop in aprerage then get out your test light and track down the short in that circuit.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v while cranking replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor.
17. For a free wiring diagram please visit the website below and good luck.Harley Davidson Wiring Diagrams and Schematics
Stator Repair 1 of 9 Removing Inspection Cover on Outer Primary Cover
Jul 12, 2013 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Check engine light
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Jun 28, 2013 | 2003 Harley Davidson FLHTCUI Electra Glide...
Homelite carb schematics
The fuel pump side goes: carb body, diaghram, gasket, cover.
The metering side ( side with the needle) goes: carb body, gasket, diaghram, cover. On the diaghram, the side with the larger disc and the holes around it and the nub in the center goes down toward the needle lever.
Any adjustment needles can be set at 1 and 1/2 turns out to start. Turn out to richen. If it falls on its face and bogs when you throttle up then its lean and needs to be richened up.
Oct 06, 2012 | Homelite Mighty Lite Blowervac
96 tercel keeps draining the battery. Alt. is new and fuse and breakers are good
Your going to need a volt/ohm meter for testing this prob. You need to put the meter on amperage mode and turn off all devices in car and close all doors and make sure key is off! Disconnect the negative battery cable and use the meter to hook from the battery negative cable to the other end of the cable, basically the meter is completing the circuit. Once you turn the meter on the vehicle will have to power down cause your meter connection will have woke up several modules, wait bout 5 min with the meter on, if the meter is 10 ohm scale a good reading should be around 0.025 to 0.001, if it's anything higher then pull fuses 1 by 1 until the draw falls into proper range, that will help you narrow down what circuit the draw is related to. Quick check, make sure the trunk light and or glove box lights are actually turning off, most common prob for current draw..
Jun 10, 2012 | Toyota Cars & Trucks
When the my 2011 street glide is ignition switch is on Access the way tail light and the dash lights stay on, and when your listening to the radio it just wear the battery down.. Is there a easy way to...
Hi Aburg22, perform the following tests:
Jun 10, 2011 | 2011 Harley Davidson FLHX Street Glide
Im laying 160mm sewage drainage i have 2 fixed points which i have 100mm fall the drain run is 10 meters long is that enough fall
The rule of thumb for drain fall is ¼" per foot for 2" or smaller and 1/8" per foot for 3" or larger. If for whatever reason you cannot get this then just remember that you need to keep the solids suspended the length of the run to keep the drain from plugging over time.
Feb 09, 2011 | Plumbing
I have a swr meter and i would like to no how to ues it
Goto channels 1 20 and 40 and do the following.... this a generic calibrate all swr meters have different buttons different style of meters etc...
set meter too the set/cal/fwd position. key mic adjust the meters needle to cal spot should have an arrow or red line etc. then change switch to swr/rev too show your reflected swr.
ch 1 is longer wavelength than ch 40.
if ch 1 is good swr and ch40 is high swr-- then make antenna shorter
if ch 40 is good swr and ch 1 is high swr-- then make antenna longer.
then try to get a good balance between the lowest freq and the highest freq./ch.
-- anymhz(dot)com ---- Radio Shop
Dec 06, 2010 | Radio Communications
2000 heritage softail....new battery losing charge as i ride....then wont turn over after shutting down...even 1-2 mile of riding ???
May 21, 2010 | 2000 Harley Davidson FLSTC Heritage...
Sears GC-922  MP3 Player Logo
37 people viewed this question
Top Sears Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sears Audio Player and Recorder Expert? Answer questions, earn points and help others
