Question about Toshiba Satellite A45-S250 Notebook
Brighness fn key is not working except f10 and f11 no other fn key is working
  • Toshiba Master
  • 4,924 Answers
If you are using windows 7 try this update and t will fix the issue ..
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/download.jsp?ct=DL&soid=2505315&ref=EV
or make a serach for ths utility related with the operation system that you have in use..
Toshiba Value Added Package
Posted on May 31, 2010
Help with d2d recovery for gateway Lt 20 notebook
Try tapping the Del key. Also try F11, if neither of those work, then try these combos below:
Fn+F2
Fn+F8
Fn+F10
Fn+F11
Fn+F12
Shift+F2
Shift+F8
Shift+F10
Shift+F11
Shift+F12
Remember to hit these key combos before Vista loads, only when you sure the keys were pressed, cross it off the list on move on. When you do determine the correct key combo, please post back here, it will help others with the same question.
Oct 30, 2014 | Computers & Internet
Tip
How to 'system restore' without disks or windows access.
No restore disks,<br />Windows restore point is missing,<br />Laptop will not boot fully to windows,<br />Safe mode does not work,<br />You do not have a windows disk,<br /><br />Solution:<br />Only use this tip if you are willing to loose all of your data.<br />Start laptop and tap f10 key (Sony)<br />or 'alt' and f11 for Dell<br />and some Dell 'ctrl' and f10 or f11<br />or 'fn' and f10<br />or 'fn' and f11 <br />or 'fn' and f12<br />You get the drift, and there may be others.<br />This may activate windows restore partition and bring your laptop back to the factory default system.<br />I did this again, on a laptop today where seversl parts of windows vista had dissappeared after a game was loaded.<br />f10 and 1 hour later, a new pc....well nearly.<br /><br /><br /><br /><br /><br />
on Jan 26, 2011 | Computers & Internet
How do I turn down volume?
I have an ASUS laptop and I use fn f11 for volume down, fn f12 for volume up, and fn f10 for mute.
fn is the function key and is found on the left bottom of the keyboard between the ctrl and windows keys.
Oct 29, 2014 | ASUS Computers & Internet
How to turn off the fn key
1 - Function Keys f1 through f122 - Configurable Function key fnDisable fn in the BIOSTo disable, or enable, the function key (fn) in the BIOS, do the following steps.
  1. Press the power button to turn on the computer.
  2. Press the f10 key to open the BIOS setup window.
  3. Use the right-arrow or left-arrow keys to navigate to the System Configuration option.c02035200.jpg
  4. Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the enterkey to display the Enable / Disable menu.
  5. Select the desired mode:
    • Disabled : Requires pressing fn key + f1 through f12 to use the action as indicated on the action key.For example, if Disabled , pressing fn + f11 will mute the sound as indicated on the key on this model PC. Alternatively, pressing f11 only will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
    • Enabled : Requires pressing only f1 through f12 to use the action as indicated on the action keys.For example, if Enabled , pressing f11 only will mute the sound as indicated on the key on this model PC. Alternatively, pressing fn + f11 will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
  6. Press f10 key to save the selection and restart the computer.
The function key (fn) option can be reset at any time.
May 22, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
My F2 fn key is not working neither is f10,f11,f12 and the seperate blutooth key
The laptop keyboard needs to be replaced, go to www.ebay.com Type: make and model of laptop and refine search to keyboard.
Apr 26, 2012 | ASUS Eee PC 1015PE
How do I use the F9, F10, F11 and F12 keys?
Some Gateway (desktop) computers do not have the dedicated F9, F10, F11 and F12 keys, but for a Gateway laptop, those four keys have dual functions for media control (which is the default use) or as Function keys. However, to use F-9 through F12 as Function keys, you must first press the Fn Key and then press the desired F-key. The Fn key is the second key to the right of the spacebar. To launch the Gateway Recovery process during start-up, you must press Alt+Fn+F10.
Aug 19, 2011 | Gateway Computers & Internet
The screen is very fade and i cannot work it as of this problem please help
Hi There
If you look at the keyboard there are normally second function keys on the f9 f10 and f11 keys if you press the second function key left of the space bar with fn on it and the f9 f10 or f11 key with the sun and an up arrow this might brighten the screen
Jun 29, 2011 | Computers & Internet
I can not work out how to turn the wireless conection on.advent 7070.what keys do i use
To enable the Wireless LAN Fn + F2
usually the wifi function key has the universal antenna symbol with radio waves emanating from it.
The manual says the other hotkeys are:
Fn + F2 - Wireless LAN
Fn + F3 - Standby
Fn + F4 - External display
Fn + F7 - Reduce brightness
Fn + F8 - Increase brightness
Fn + F9 - Play / pause media
Fn + F10 - Stop media
Fn + F11 - Media previous chapter
Fn + F12 - Media Next Chapter
Fn + scroll - Scroll Lock
Jan 14, 2010 | Advent Netbook
How do you turn the screen where it will be lighter
Laptops usually do not have dial buttons like normal monitors where you can manually change the brightness with a flick of a switch. However, to replace this, brightness control is usually put onto the keyboard. Try this:
1. Look at your keyboard and look for keys that look like they are marked to perform brightness/contrast control. These are usually symbols written in the F9, F10 and F11 keys but may vary for different manufacturers
2. These keys are usually accessed using another key (the Fn Key). Therefore, while pressing the Fn Key, click on the F9/F10/F11 buttons to play with the brightness control settings
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | Computers & Internet
If i hold the fn button down my keyboard works,
It would appear that you have number lock turned on. Try turning it off by pressing and holding Fn key and then F10/F11/F12 key (can't remember which one is for number lock). That should release your keyboard back to normal.
Dec 05, 2009 | Toshiba Satellite A135 Notebook
Toshiba Satellite A45-S250 Notebook Logo
148 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
