Medion laptop brand new, powered up once only (windows 7) but wont startup windows since 2nd power on. I have tried using ''Application & Support disc'' but still no joy. The Medion Hellpdesk never calls back ! What can I do ?
    Scholar:
  • 33 Answers
Hi there, since your laptop is brand new, it is not really a major problem. You can try this method:
1. Pull or take the battery out from the laptop
2. Remove the AC adapter
3. Hold down the power button for 30 seconds
4. Put the AC adapter only
5. Turn on the laptop
6. And last put back the battery in.
Hope this helps, God bless
http://podnutz-hdlaptoprepairvideos.blogspot.com/
Posted on May 31, 2010
Monitor wont connect to medion computer
u could try using a VGA connection or HDMI connector to connect asuming its windows switch off youre LCD monitor on the key board of youre laptop try downloading drivers for youre monitor to make windows aware of new hard ware thanks
Apr 05, 2014 | Medion Computers & Internet
My nexus 7 tablet wont leave the startup screen. I tried a hard reboot but it stays on that screen and wont turn off
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down CLEAR CACHE & reboot
Nov 03, 2013 | Google Nexus 7
Hi i have a samsung np350v5c laptop, it's all ok
There will be a power application which came pre-installed on the OS. Easiest way to stop it starting is Start-Run- MSCONFIG and choose startup items tab, unselect all options and reboot. Confirm the problem is gone and then reselect startup options one by one (with a reboot inbetween) until you find the troublesome item, leave that unselected
Aug 10, 2013 | Samsung Np350v5c 15.6-Inch Laptop Silver...
My computer freezes
Not much info. If you supply the OS you are using it would be helpful. What were you doing when it is freezing? Without any info I would guess you have two many running programs, a Virus, Malware, etc. Try these two Freeware programs to clean-up your machine. 1, MALWAREBYTES: http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install UNCHECK the TRIAL PRO version, you want the freeware version, Run a FULL scan, delete ALL results, reboot. 2, download CCLEANER : http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools. The Cleaner will remove the junk from your machine, in the TOOLS section, STARTUP section, Disable ALL unnecessary startup programs, the will speedup start and running of the Laptop. Run a FULL scan with your up-to-date Anti Virus, delete ALL results. I don't know your Windows Version so here are some tips for speeding up Windows 7, you can apply some to other versions: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 If you supply the Medion model and the OS you are using and a bit more info, we could help further.
Mar 21, 2013 | Medion Computers & Internet
I have been given a medion scanner August 2002 and hoped to scan some old photos by using my new laptop DELL WIDOWS 7 HOME PREMIUM.no such luck.My laptop will not recognise or connect to it.I have followed...
Hi alistair49,
Firstly, is your laptop connected to the internet when trying to install your scanner?
Windows 7 will automatically browse Microsoft's online database of drivers if it's not found in your laptop database.
If you are in fact having driver issues, have you checked the following web page to locate your scanner software?
http://www.medion.com/gb/service/download/driver.php
If, however, you have the drivers, make sure that these are compatible with Windows 7 as your scanner was manufactured before Windows 7 existed. In this case try using Windows 7 compatibility wizard to install your scanner software.
You can do this by right-clicking on the installation file & selecting "troubleshoot compatibility" from the drop-down menu. Simply follow the on-screen directions step by step to check if Windows 7 has compatibility issues with your scanner software. In most cases this procedure should solve your problem.
Best wishes,
Graeme.
Mar 23, 2011 | Computers & Internet
My laptop wont turn on at once when i press the power button, i have to press it a couple of times then it starts, what do u think might be the problem?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 19, 2010 | ASUS Black 156" K50IJJ1 Laptop PC with...
I have a medion MD98300 laptop . Last night went to power up with both battery and mains connected seemed to want to start (mains light was on, battery light came on and then immediately went off motor...
3. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
4. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Medion md40298 Notebook
Battery wont charge and laptop wont start using
Check the pin inside the connection (end of the cord) which you put into your machine, or check if the power connection on the circuitboard is damaged (you are able to wiggle it a little bit around)
Dell computer use the pin inside the connection from the adapter to recognise if the adapter you are using is a dell adapter or not. If the pin is damaged, or you are using an adapter from another brand. You will not be able to charge, but only power your pc.
Jan 04, 2010 | Medion Computers & Internet
Medion akoya will power on but not boot windows.sometimes switches itself off.start up screen is f10 bootmode f2 b1os settings f12 lanboot i have...
I am an Medion specialist. These computer suffer with problem motherboards which often cause random restarts and shutdowns. The same applies to all Advent and Emachine computers sold via the high street stores. Need help to repair, email me me at compdoctor2005@btinternet.com or ring me on 07926-106150
Jun 03, 2009 | Medion (40010998)
Medion 2080 notebook battery wont charge
Time for a new battery. If you have a batteries plus in your area or order online.
Aug 13, 2008 | Medion MD-40954 Notebook
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
