You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
SOURCE: Cannot burn CD from Kodak Easyshare Software
If you are using the Pro version of XP, it will burn your photos to the CD itself. As I recall, this didn't work in the Home version of XP, but you could try it. Simply drag and drop the photos onto the burner drive from within Windows Explorer. Once they are all there, I think there's a menu item which tells XP to perform the burn and eject the disk. All that assumes that the burner is working OK on your machine
SOURCE: CAMERA ISSUES--KODAK easyshare C613
Easier Way:
Turn on the camera without the cord plugged in, and push the Menu button in back, scroll down to the SET ALBUM (STILL) which is probably in the OFF mode. When you hit OK it will probably tell you to connect to the computer. Then you plug in your cord.
You may have to put your Easy Share disk in at that time and load or reload the software but it should then allow you to download all your photos into into a Kodak folder. Then you can burn them to a DVD or select as many as you want and move to a regular folder on your computer.
SOURCE: can i use my "kodak easyshare c613" as web cam?thx
the c613 will not stream anything through camera-mostly only some camcorder models will act as webcams also
SOURCE: Kodak EasyShare C613 not able to connect through USB
IT TELLS ME CANT LOCATE MY DRIVER FOR MY KODAK C613 CAMERA
SOURCE: kodak c613
Try Easyshare 6. 45MB d/l though
http://www.kodak.com/global/en/service/downloads/dln_ekn030260.jhtml?operatingSystem=windows_2000&downloadLanguage=en
