Question about Craftsman 25cc Gas Line Trimmer
Weedwacker won't start
1.Recently it had become very difficult to keep unit running under normal speed. If throttle max'd out weedwacker (WW) would stay running.
2. Then symptom changed to impossible to start at all. WW would start up, and then die out in about 10-15 sec. It seemed like it wanted to run but couldn't;.
3. Pulled off fuel tank and inspected feed tubing. Found fuel filter laying loose in tank, and feed line? (small dia tubing) was sliced in half lengthwise.
4. Replaced both fuel lines (and fuel filter), and now unit will not start at all!
5. Replaced spark plug
6. *When checking to see if new fuel lines were bringing fuel to the carb, noticed both lines had pressure. Both lines were supplying fuel at the same time. I thought one was a fuel pressure line, and the other was a return line....but both have fuel going to carb.
    Problem Solver:
  • 15 Answers
Is there an air lock in the line. Remove the lines and insert only one at a time and see if one will take fuel and the other none? Also, check carb float to make sure its not stuck open intaking fuel constantly flooding bowl
Posted on May 31, 2010
Weedwacker has fire to the sparkplug and new gas to the primer bulb but will not start
sad these little gas engines always fail when we don't want them to . requires a lot of compression to run and if not properly oiled thru the gas will fail .
Aug 08, 2015 | Craftsman 27cc 2 Cycle Crank Straight...
Why does it keep running out of fuel?
needs new gas lines and carb,go to ebay and get them it is about 25 bucks,or you can rebuild the carb and buy a new line and fuel filter,ethanol kills weed eaters,use non ethanol gas from a marina
Jul 11, 2015 | Craftsman 27cc 2Cycle Full Crank Curved...
My 32cc 4 cycle craftsman weedwacker won't run off choke
MORE THAN LIKELY YOU HAVE BEEN USEING ETHANOL FUEL NEED A METANOLE FUELCLEANER AT MOST AUTO PARTS SUPLYER THEY SELL A FUEL CLEANER FOR SMALL ENG. IF NOT THAT MAKE SURE FUEL LINE IS NOT CRACKED
Nov 15, 2011 | Garden
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Craftsman 25cc weedwacker (358.791030). Zama carburator (C1U-W19) Just rebuilt carb but did not adjust low speed/high speed screws. Starts on first pull (with choke lever actuated), and after warm up,...
need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
Sep 17, 2010 | Craftsman 25cc Gas Line Trimmer
Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
May 10, 2010 | Garden
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
I have a craftmens 25 cc weedwacker thats about 3
it sounds like your carb is out of adjustment and you need to adjust it. Look at the carb on your weedwacker, there is an idle adjustment screw somewhere on it and using either phillips or strait screw head and then carefully turning it clockwise go 1/8 of a turn at a time until the engine idles smoothly.
Sep 05, 2009 | Craftsman Convertible 25cc. Gas Line...
Craftsman 25cc Gas Line Trimmer Logo
461 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
