Question about Sony XM-404EQX Car Audio Amplifier
Overheating? it is turning itself off
    President:
  • 1,099 Answers
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the repairer shop or the manufacturer to be diagnosed. Good Luck
Posted on May 31, 2010
Why does my Hisense F46K20E tv shut off by itself?
try to see if the sleep mode is activated (turn it off if it does), or there are overheating issue.
Aug 07, 2014 | Hisense Televison & Video
My car keep turn off after 15 mins. And it take 20mins to turn back on than it would turn back off like 10 mins
If you have a coil or distributor that has a module in the base of it then it may be the coil is overheating of the module is faulty and overheating the coil or both the coil and itself.
Mar 01, 2014 | 2000 Cadillac Catera
My receiver turns off and on by itself and becomes very hot
Hello, Daniel Busa with Dish Network customer service here. if your 622 is overheating you should get an errpr message stating its overheated. At that point you will need a replacement, if its turning off and on by itself sporadicly then that may be remote interference. Try this link to readdress the remote.
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
Nov 23, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Turning off in 2 minutes automatically
My guess is that the fans inside the computer have stopped working, thus leading to the overheating. AMD processors generally run "hot" (50 to 60 degrees Celsius) even with proper fans.
Take your computer to a qualified technician, for a cleaning, and proper trouble-shooting, and repair, before the overheating causes permanent damage.
Jul 27, 2010 | HP Compaq Presario 2100US Notebook
Ps3 keeps turning itself off when i turn the console on the green light comes on but then changes to red, if i try to turn it on manually the red light starts flashing
it has overheated and needs to be serviced by SONY sorry I could not provide a quick solution to this overheating problem. thanks and please rate AJ
Oct 22, 2009 | Sony Playstation 3 (PS3) Console
Keeps turning itself off. Reckon its an overheating issue.
LCD TV turning itself off is not necessarily overheating.
Often, because of a faulty component, capacitors can accumulate electrostatic charge until an error is detected, or a fault condition can last for a while, until a problem is detected, and the protection circuit will force the TV to shutdown.
The only temp sensor that can shut down because of overheating is placed on the main board, and TV shutdown after a while is often not caused by overheating on LCDs.
Parts that often cause shutdown after a time are Power Supply Unit, Inverter, and main controller board. Parts must be tested to find the fault. The technician can follow the diagrams detailed on service manual to find the fault.
Regards.
Jul 04, 2009 | Televison & Video
The system or DVD recorder turns off itself
It could be because your unit is overheating. Shutting itself off is your player's way of protecting itself. Causes can be form anything to direct exposure to sunlight, Something heavy is on top of the player, to disk speed being to fast.
Mar 31, 2009 | GoVideo Go Video DVD/VCR Combo
Fan on laptop intermittent Avent 7110
That can be normal. Normally cpu fans start up only when cpu reach a determined temperature. After it cools down it stops until temperature reaches starting point again.
Generally, when the fan is not working properly, the computer turns itself off after a while because of overheating.
If you have this problem, laptop turning itself off because of overheating (check it is not hibernating etc.), then you usually solve it by replacing the laptop cooling fan.
Generally, 'fan on laptop intermittent' is not a symptom of malfunction.
Apr 25, 2008 | Computers & Internet
Overheat?
It sounds like an overheating problem. When it is booted, does it run ok other than just being slow? Check your cooling fan and make sure it is running and not stopped up. That is a number one symtom of overheating is freezing and rebooting by itself. There is a free program called "Motherboard Monitor 5" that will monitor the temp for you and set off an alarm when it is getting to hot. Check that problem first. Hopes this helps!
Nov 27, 2007 | Computers & Internet
Sony XM-404EQX Car Audio Amplifier Logo
62 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
