Boating Logo
Posted on May 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Firing order diagram for Chev 350 reverse marine engine. Do I bring the # 1 up the same as the other engine? If I am looking down at the engine, with the distributor towards the front of the boat and I am standing in the back looking toward the front, which is the # 1 cylinder ?
Anonymous
Level 3:
  • Master 2,926 Answers
  • Posted on May 31, 2010
Anonymous
Master
Level 3:
Answers
2926
Questions
0
Helped
1005459
Points
9623
While looking at the engine from the side or from an overhead view, the #1 cylinder will always protrude slightly further to the front. In other words, the valve cover and head that has less room behind the water pump and sticks out further is #1. Firing order 1-8-4-3-6-5-7-2 is the same.
Diagram for 1993 chev 350 thruttle body for spark plugs
Firing order is clock wise rotation. You can see firing order in picture. You can see how cylinders are numbered. I did show number one terminal on distributor cap, according to my database. I don't like to do that because I've seen many pictures that were wrong. If you put number one piston on tdc of compression stroke, which ever spark plug tower the rotor is leading into is number one, then follow firing order around cap in direction of rotation. Just my opinion.
I looked at 93 chevy pickup, 350 engine.
Firing order diagram and timing degrees 1989 gmc 1500 series 350 engine
    How to set ignition timing 88-95 GM fullsize truck Silverado ...
    ? 10:56
    https://www.youtube.com/watch?v=y5NuS-G-cKI
    Dec 5, 2013 - Uploaded by Ghetto Wagon
    I thought the parts when the engine was running would come out better, but its just too loud. ... How to set ...
    1995 GMC Sierra V8 5.7 Distributor Timing - YouTube
    ? 3:14
    https://www.youtube.com/watch?v=mK5N5mCmyok
    Jul 28, 2013 - Uploaded by sprek2
    I had to time a distibutor on a 1995 GMC Sierra V8 5.7L and was having trouble finding the wire that you have ...
    Info on V8 Engine Firing Order - Offroaders.com
    www.offroaders.com/tech/V8-engine-firing-order.htm
    Firing Order of Most Domestic V8 Engines by Diagram.
    Chevy Engine Firing Orders 283, 327, 350, 400, 427, 454 ...
    www.mre-books.com/chevy/engines/firing_order.html
    At this site you can find the firing orders for Chevrolet engines. ... 1987-1989 ... 283, 302, 307, 350, 396, 400 and 454 Engines Firing Order, 307 Engine Firing ...Missing: degrees images for Firing order diagram and timing degrees
1994 350 chevy diagram firing order whereis number 1 on the cap
dont go by that..do this.. bring the 1 cylinder to top dead center by matching the timing marks on the engine..then take off the cap.. look at where the rotor is facing..thats your 1 plug spot..then the rest follow one at a time all around the top of the cap..1-8-4-3-6-5-7-2..
1helpful
2answers
Firing order diagram 1997 chevy k1500 5.7
18436572 normaly #1 is5 oclock position when looking from the belt or fan end of the engine and rotates clockwise
Im looking for a spark plug wirng diagram for a 1966 corette 427
1966 - 1969 with 4 Barrel Carb (L36)
(Low Compression Model)
Max Brake Horsepower - 390 @ 5200 rpm
Max Torque - 470 @ 3600 rpm
Stroke - 3.76
Bore - 4.251
Compression - 10.25
Firing Order - 18436572
1966 with 4 Barrel Carb (L72)
(High Compression Model)
Max Brake Horsepower - 425 @ 5600 rpm
Max Torque - 460 @ 4000 rpm
Stroke - 3.76
Bore - 4.251
Compression - 11.0
283, 327, 396, 409 and 427 CID Engine 1965-1966
Firing Order 1-8-4-3-6-5-7-2
350 CID Engine 1969-1974 Corvette, 427 CID Engine 1969 Corvette
Hope this helps (remember to rate this answer)
1helpful
2answers
I need a spark plug wire diagram for a 1985 gmc jimmy 350 engine
Most all Chev or GMC v8 engines use the firing order of 1-8-4-3-6-5-7-2. You have to find where #1 is on the distributor cap which is usually closest to #1 cylinder then looking toward the back of the engine go clock-wise to install the rest. Don't get too close to the headers. Plastic melts!
22helpful
3answers
1990 chevy 350 distributor wiring diagram and firing order
The firing order is 1-8-4-3-6-5-7-2.
The distributor rotates in a clockwise direction. The engine must be on the compression stroke on the #1 cylinder. Line up the timing marks. Remove the cap and the rotor should be pointing to approximately the 5 o'clock position.
Good Luck
2helpful
3answers
5helpful
2answers
E350 frod van
On your Ford E 350.
Are 3 Engine sizes available. 5.0L, 5.8L and 7.5L.
On Gasoline.
The Firing Order for 5.0L and 7.5L are the same.
But diferent on 5.8L.
Here is a Picture if the firing order and cylinder number.
e911241.jpg tHIS IS THE FIRST FIRING ORDER FOR 5.8L.
The CIRCLE mark is for the cylinder # 1 on the distributor cap.
e0ba3c1.jpg This is for the 5.0L and 7.5L
The Circle mark is for the cylinder # 1 on the distributor cap.
The ROTOR turn Clock wise.
I hope this help on your problem.
Thank you for use fixya......
Top Boating Experts
ADMIN Andrew
ADMIN Andrew
jws1013
Kardoc
Are you a Boating Expert? Answer questions, earn points and help others
