Question about IO Magic Corporation (I35USBEN) ATA-133, USB 2.0 External Drive Case
My IO magic 250 GB external harddrive is not working
I can hear the "tick" sound. any hope I can recover the data from it?
  • 6,831 Answers
Body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 27, 2010
My computer wont read my harddrive... I have too much stuff on there that can't be lost
try it on another system if it boots backup your data if it does not only option is data recovery company very expensive
Feb 03, 2011 | IO Magic Corporation GigaBank (I250HD35)...
My drive wont show on my computer and it makes a sound like dropping a ball bearing inside it. I cant access the drive to move my data off from it. it is an IOMAGICK external Sata high speed USB 2.0 250 GB...
Sounds like it has the "Click Of Death" if you have something on there that you really need it may be possible to run it for a short while after freezing it (wrapped in plastic film) if you're lucky. More than likely though it is destined for the bin.
Jan 05, 2011 | IO Magic Corporation GigaBank (I250HD35)...
Simpletech 250 GB Pininfarina was knocked on the floor
oped it, maybe loose cables or connections. or the worst case, a faulty hd. ticking sound means bad drive, cannot read disks. retrieve data? the better chance will be a recover technician, dont try anything else, will turn a worst problem.
Jun 02, 2010 | SimpleTech SimpleDrive Pininfarina 500GB...
External Harddrive does not work
Hi:
Hitachi hard drive are junk they are poorly made, but here is an option the could by a bigger hard drive and install it in the External case they are all the same, first take out the old HD from the case and take it with you to the store and purchse the same connection type wether its IDE or Sata and install it in the case, the cases are universal and all most all 5-1/4 inch HD will fit in the case is does not have to be A Hitachi Brand any brand will fit, I recommend a Seagate HD.
Apr 21, 2010 | IO Magic Corporation GigaBank (I250HD35)...
Not recognizing external harddrive in "my computer". I/O magic blue light continually flashes blue instead of staying solid light
There are a few possibilities, the fact the light is blinking generally means the power adapter is fine.
The options left are a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
Oct 26, 2009 | IO Magic Corporation GigaBank (I250HD35)...
I can't remove the HD from the case
It took me a bit to figure it out, so here it is.
1. Pry off the aluminum plate from the back side. Its held on with a rubber cement like glue. Use a thin blade to get under the plate and work it around the perimeter and it will lift off easily.
2. Remove the two screws that are now exposed. The back cover or "end plug" can be pulled off now.
3. Grab the front "plug"and pull and the drive tray will slide out. The Drive is attached with 4 screws to the tray. With the drive screws removed, the drive can be rocked out gently ..lifting the front of the drive up and out of the tray. Now you can get access to the power and data cables so that they can be unplugged. The drive is now free.
I have 2 of these drives and both have poor power connections at the drive enclosure back connector. One finally failed completly, so I removed the drive form the I/O Magic enclosure and directly connected it to an IDE port in my desktop. The hard drive worked perfectly,so I was able to get my data recovered. I plan to cut off the power cord connector and directly wire it to the enclosure, to eliminate the bad connector design.
I bet most all the trouble that people are having with this series external drive is caused by the bad power connection.
Hope this has helped.
Mar 13, 2009 | IO Magic Corporation GigaBank (I250HD35)...
My computer will not read my io magic giga bank 6 gb
Was your computer ever able to recognize your GigaBank, or is it new?
The most common problem people have with a new drive not showing up in My Computer are:
1) The drive is not formatted
2) The drive letter is mapped incorrectly
You can check both of these things in Disk Management by right-clicking on My Computer and choosing Manage, then clicking on Disk Management on the left hand side.
If your drive doesn't show up in Disk Management, and you are also unable to see the drive on multiple computers, then you may be experiencing a hardware malfunction.
If you are still within your warranty period and you are experiencing a hardware malfunction, we will be happy to replace your unit for you. Specific warranty and replacement information is available at www.iomagic.com, by clicking on Support.
Have a nice day,
I/O Magic Technical Support
Aug 14, 2008 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic 250gig external hard drive
Unfortunately the hard drive within the external case has died. The clicking noise you can hear is the read / write heads trying to find anything on the platter and failing, this means that any files that were on the drive are lost. There are many tricks on the net that give hope of recovering data off a dead hard drive but most just corrupt the data completely. If you have files that you must have and can afford the extremely high price for data recovery there are services available through most hard drive manufactures, most notably through Seagate.
May 07, 2008 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic Corporation (I35USBEN) ATA-133, USB 2.0 External Drive Case Logo
106 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
Falling star
nuhu ibrahim
nuhu ibrahim
Level 1 Expert
Robert Henderson
Robert Henderson
Level 1 Expert
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
