Question about Samson C01U Consumer Microphone
Extrememly low volume while using on camtasia
You can probably solve your problem by plugging your mic into a powered USB hub, then plug your hub into the computer.
Posted on Aug 26, 2010
Need a product key for camtasia studio 8.0
You can download a free trial here, and if you like it, you can buy the code here too.
Capture Edit amp Share your ideas with the world using Camtasia Studio
Jun 04, 2014 | Computers & Internet
Camasia 8 Recorder won't work on Windows 7
Delete 7 and 8 but then only reinstall 8 and see if that works because they might be screwing with each other.
Mar 18, 2014 | TechSmith Camtasia Studio for PC
Camtasia Studio 8 Only Opens Once per Start-up
what u need to do is if you have windows press ctrl shift esc and the task manager should pop up go to processes then on the list you would see Camtasia studio right click and select end process or if u see the name more than once end the process of them all the reason you have to do this is because for some reason the first time you open and close it it dos not actually completely close witch then gets in a glitchy state to where you can not open in again but by ending the process u should be able to open it again
Jun 17, 2013 | TechSmith Camtasia Studio for PC
Clock runs slow. Is there a button battery to change?
the cpu's in these units use extrememly little power for the clock, unlikely that low battery voltage is the cause, unless the battery is extrememly low, then yes it would be the battery, but also the unit might not use a battery but instead use a "super cap", which is a special high capacity capacitor that can hold a charge for weeks before needing to be recharged...they are usually rated for approximately .47 farads at 5 volts and they look like button batteries but are not....if yours uses super caps instead, then it might be on its way out, not able to hold a charge any longer because of deterioration....you might need the super cap changed.....also have the unit checked for bad connections....all solder joints, etc...which is always a big problem with any electronics...sometimes, solder looks good mechanically but electrically not good so it's a good idea to have the board resoldered.
hope that helps.
silvio
Jun 28, 2009 | Teac MC-D95 CD Shelf System
Using Camtasia
You have 3 Audio source options when you record using Camtasia,
1) Speaker audio
2) line in
3) Microphone
You won't be able to record using line out.
Apr 03, 2009 | Dell OptiPlex 360 Desktop Computer
Camtasia runs really slow in editing mode. I am using the PIP feature also and the web cam part gets really slow while the capture part is going at regluar speed
I am using camtasia studio 7 from techsmith. But, when I try to render my projects, its very very slow.Sometimes it slows my PC too. My Pc hardware info:- Ram :- 1 GB HDD :- 320 GB
please help me....thanx in advance
Jan 20, 2009 | TechSmith Camtasia Studio for PC
Extremely slow to update changes on timeline...
This is a known issue when too many edits are made. Supposedly Camtasia Studio 6 (recently released) will decrease your editing time by 30%. I have not been able to verify this yet. The best way to resolve the issue is produce what you have as an AVI and start editing that, and so on, and so on.
Oct 02, 2008 | TechSmith Camtasia Studio for PC
Memory Problems
The clip can be recovered if you open the temporary directory where Camtasia stores the raw captures in AVI format. The path to the temporary directory can be found by opening the Camtasia Recorder > Tools > Options > Program > Temporary file folder (I'm using v.5 so it may be a little different in other versions).
I've found that there's a certain workflow that seems to work best and you can avoid accidentally erasing your temporary files and having to start your capture session over from the beginning...
  1. Stop Camtasia Recorder - Pressing the Stop button on the Recorder likely won't work, so open the Task Manager (CTRL+ALT+DELETE) and select "CamRecorder.exe" from the Processes tab and click "End Process". Don't open Camtasia Studio right away after doing this step - You'll likely be prompted to recover the recording and in my experience Camtasia hasn't done a very good job at being able to do this successfully and you may end up losing your temp files.
  2. Recover your raw capture files - Navigate to the path where Camtasia stores its Temp files (look above for instructions). Typically, there will be a folder titled "CamCapture{random string of numbers/letters}" - look for a folder with a date modified attribute of the date/time you were working on your project. In that folder, there will likely be several audio and video files as well as an XML data file. The video files will all be 1GB apiece as Camtasia splits the capture into chunks and then pieces them back together to create one continuous file. Cut and paste the files from this folder into a new location outside of the Temp directory. The most important one is the FileWriter{random string}.avi as this is the pieced together file - It will have the largest file size.
  3. Add your media files to the clip bin/timeline - Start a new Camtasia project and import the FileWriter{xxx}.avi clip into the Clip Bin and drag it onto the timeline. Now all of your video/audio should be recovered and available for you to edit. If you have particularly long clips, you may want to check how the audio syncs with the the video towards the end of the clip. If it's messed up at all, you may want to try adding the smaller, chunked recording segments sequentially onto the timeline to see if that helps. If the FileWrite{xxx}.avi clip is good though, you can delete all of the other smaller audio and video clips associated with the capture from your pc to save space - just keep the FileWriter{xxx}.avi clip - the XML can be deleted too.
Good luck - We've had the same trouble here and we use Camtasia almost everyday. In my experience, this seems to happen more frequently when we capture larger dimensions - especially if the capture contains full motion video (as opposed to just screen captures of a product demo or something) and we always seem to have trouble when capturing things that play back FLV or SWF clips at a higher bitrate. This issue is also described in TechSmith's Camtasia knowledge base.
Apr 22, 2008 | TechSmith CAMTASIA STU V1.0 5-9U for PC
Recording sound
What operating system/ computer are you using>?
Oct 17, 2007 | Edirol UA-25 External Sound System
Uploading Camtasia video to web page
If you are using a Flash then you can create your own flash play, pause, stop and exit button by flash using action script so that when you upload video through website it will work. if no idea with action script then refer to this site www.actionscript.org .... Thank you
Apr 11, 2007 | TechSmith Camtasia Studio for PC
Samson C01U Consumer Microphone Logo
186 people viewed this question
Top Samson Audio Players & Recorders Experts
 Grubhead
Grubhead
Jerry Umali
Vito Vacirca Jr.
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
