Horizontal Lines and smeared color
I have a 32" RCA F3263256 that was working fine one day and then the next day it had horizontal lines and the colors seem to smear across the screen especially the red. Please tell me it is an easy fix :)
Thank you in advance and have a nice day -Renee
  • Gypsy_60 Apr 08, 2008
    Hello crikett - Thanks for your reply. I kind of thought the tv was toast but I had to try anyway. I do have another tv but I just thought that it was a waste just to toss this one without doing some research.
    Thank you and have wonderful day :) -Renee
    President:
  • 1,779 Answers
No its not a cheap repair Renee, please don't invest your hard earned money into an old 32". If you can buy a newer LCD or Plasma set. LCD's are cheaper and have the smaller sizes that you may want.
Posted on Apr 08, 2008
Screen has gone grey and has fine horizontal lines on entire screen. Blue screen is out.
Either the screen voltage to picture tube is more than normal, or the video processor IC has damaged. There is an other possibility that there is no voltage at the video output card, plugged on to the neck of the picture tube. Anyway, your set need a through checkup, and the work is somewhat skilled one. Just check this site. Soemtimes you might get some details about this fault. The fault is called vertical retrace lines. Thin horizontal lines all across the screen with an inch apart. One among the posts published in the following site have details about this fault.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1250 posts to different brand TVs now. Pull up older posts there.
Nov 23, 2012 | RCA F32672SB 32" TV
Has back light and partial video seperated by horizontal lines. Between the lines you can see snow and the other lines are a pinkish color. At first we had some bad caps in the power supply because lcd...
If you do get the backlights OK, then the next place to look will be the LCD panel driver board (T-CON), you will have to look at the board itself for the correct one for you TV. The worst case will be the panel itsef, very expensive. http://www.shopjimmy.com/catalogsearch/result/index/?q=RCA+L32WD12+&p=1
Nov 18, 2009 | RCA L32WD12 32 in. LCD HDTV
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Horizontal Lines On Screen
horizontal lines = horizontal sync off . mitsbishi always seemed to have this problem .. on the older sets I would take the back off and inside deep on the board i would adjust a pot and sync it right .... and never had a recall, maybe your newer model has this too .. this little control,
but its a horizontal sync problem.
if no change the horizontal processing ic.
Jan 11, 2008 | Mitsubishi WD-52725 52". Rear Projection...
RCA pix tearing horizontal lines
Get an ESR meter and check all the electrolytic capacitors in the set! I am sure you will find many decoupler and coupling capacitors that are on the edge or too high in ESR.
Jerry G.
Nov 30, 2007 | RCA 32F531T 32" TV
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
Horizontal bands
you may have a problem with the vertical output IC.
May 26, 2007 | RCA F27442 27" TV
Televison & Video Logo
119 people viewed this question
Top Televison & Video Experts
