Question about Samsung 460PN 46 in TV
LN46C630K1F Jittery I just bought a Samsung LN46C630K1F and love the picture but in fast motion or after a certain amount of time the picture stutter, almost like it's catching up. Switching the "auto picture" mode from "standard" to "clear" helps, but the picture isn't as good. Any ideas what's going on?
THIS LOOKS LIKE A LOGIC BOARD PROBLEM ABOUT 225 DOLLARS
Posted on May 31, 2010
Tv comes up every night with a pop up saying the tv will go off in 60 seconds looked at the settings sleep & power save are off
Is there anything in front of the tv? Some of the new tv's have motion sensors in them that will turn the tv off if it does not sense motion for a certain amount of time.
Jan 25, 2013 | Samsung Hl-r4266w 42-inch Widescreen Hdtv...
Samsung LCD LN46C630K1F no red light and wont power on please help!
Check its main power regulator board. Replace it. Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to the latest updates. It will make search easy. There are more than 1300 posts to different brand TVs now. Pull up older posts there.
Nov 27, 2012 | Samsung LN46C630K1F 46in 1080p 120Hz Flat...
I recently purchased a Samsung 46" LCD TV from Best Buy, model LN46C630K1F. I love the tv except for one issue -- intermittent jerky picture. Samsung, Best Buy and Cox Cable (Omaha, NE) have not yet...
Where ever your signal is going into, it is not tune to the right frequency and that is why your picture is not right, and the TV needs to be replace, The TV has to be tune exactly right to receive a clear signal. There is one more thing I wold try before replacing the TV, that is replace the cables or cable, or what you are using from the cable to the TV replace it and see if that is the problem, if it is the same then it is the TV that has a problem.
Jan 05, 2011 | Samsung Televison & Video
Picture Stutters on HD Channels
Hi my name is Roety,
I can help you with your issue ,
 Sounds like a bad signal issue , check it on other inputs to confirm
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 20, 2009 | Vizio GV52LF 52 in. LCD TV
I have a problem with samsung sp 50 l7h a 50 inch dlp tv
I can see you have a Samsung TV, well the issue seems to be your ballast which doesn't have enough voltage to keep on with your lamp. This is why you keep losing the picture every certain amount of minutes. The thing with Samsung Tv's is that they have issues with the ballast and the color wheel, they tend to go bad pretty fast.
Jul 27, 2009 | Samsung Televison & Video
DVD picture looks odd
Most high end and larger Samsung TV's are equipped with what is called auto motion detection, more or less the TV tries to anticipate where the movement is going to be. The reason your getting the trippy pictures is because the tv's refresh rate is probably twice as fast than the source feeding the video.
To turn this off just go to your menu and scroll down and choose picture option and find auto motion and turn it off there it is problem solved! It won't hurt anything and can be turned back on as easily
Mar 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Motion problems
You need to contact cable company, first for this.
Because of tyhe picture quality is related cable box, cables ,connectors & etc.
Jan 22, 2009 | Samsung LN46A650 46 in. LCD HDTV
Playback is Jittery at certain parts, but not on my Panasonic camcorder
TRY A DRY TAPE CLEANER. A GOOD ONE DONT BE SKIMPY. OR YOU MIGHT NEED TO GET THIS CLEANED BY A PRO. SOUNDS LIKE YOUR HEAD IS DIRTY.
Jan 09, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
When i dont use the flash on a nikon it is blured
When taking a picture the camera needs a certain amount of light to hit the sensor before it can record a good image. If you are outdoors in the sun and the camera still takes blurred pictures due to a long exposure time then there is a malfunction. In bright lighting situations the camera should decide on its own not to use the flash. For indoor situations the camera has to either supplament the available light with the flash, or increase the duration of exposure to collect more of the existing light. There is no way around it - the sensor needs a certain amount of light to create a quality image. On some cameras you can override the shutter speed setting and force a fast exposure but without proper lighting you will just end up with dark images. You might also be able to override the F setting to the lowest possible value which would let in the most light. However, these cameras are generally very good at deciding how much light they need to take a quality image. If the flash is set to auto and the camera decides to use it then there is simply not enough light to get an exposure with a fast shutter time. This is one of the factors that gets better the more expensive the equipment is. Higher end point and shoot units and SLR units can collect more of the available light with their larger lenses and thus get good exposures in lower light conditions while still maintaining fast shutter speeds. Additionally "image stabilized" cameras help compensate for this situation by electronically assisting the photographer in stabilizing the image - allowing longer exposure times to be shot hand-held. You could also try a tripod if that is appropriate to your needs, that would help you shoot longer exposures in low light without so much image-wide blurring. Of course anything in motion will still blur. David Millier Advance Camera Repair
Feb 18, 2007 | Nikon COOLPIX S6 Digital Camera
Jittery picture
the jittering will get worse with on time this tv needs a hyper module and some are still available for replacement id get a new hyper module or have it rebuilt needs caps in the module forget about doing this repair yourself just like the guy on csi miami "they never listen"
Dec 06, 2006 | Toshiba 42H82 42" Rear Projection...
Samsung 460PN 46 in TV Logo
823 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
