Question about Dell Inspiron 6400 Notebook
Dell inspiron e1505.....one day i didnt charge my computer and left it running until it shut off my its self. when i turn it back on my toolbar and start window was changed from blue to white. my background now sayd "active desktop recovery". when i try to open itunes it says that itunes has detected a problem with your audio configuration and audio/vido playback may not operate properly..which means my sound doesnt work. when i try to connect to the internet it says a problem occurred because the network did not assign a neetwork addressto the computer. i checked my modem and it works fine. when i try to repair my connection, it fails stating that it couldnt complete repair because i cant renew my IP addresshow can i fix all of these problems?
  • grantmartin7 Jun 01, 2010
    thank you very much man :) seriously your added to my list of super heros :D
  • Dell Master
  • 4,924 Answers
Ok ..it seams that your computer had recovered from a serious issue ..and now it is either into a safe mode...or something like that ...the devices needs drivers that's the reason that they do not work ..and the best way to do that is to use the recovery disk and reinstall it practically (or the recovery partition if it has one ..)
if not ..just go to bios (press F2 on start ) and choose the optimal factory defaults...and save the changes by pressing F10...restart and see what happens ..it will start to install all the devices that are not installed..if it asks for drivers insert the drivers Cd .or download them from here ..http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
before doing this ..and have them in the computer to run them when asked..
Like I said ..be sure that your computer do not runs in safe mode..cause in that mode the color is changed and the drivers are not activated...
if you suspect that (also the icons are larger ) try to do first a recovery by following this steps...and only if it do not work ..install it again normal way and the drivers to be sure ..
Here is the recovery procedure if it is still with the factory partition for restore..or use the recovery disks..
If your operating system is XP, CTRL and F11 key simultaneously when you see the dell logo after turning on the Laptop and follow the screen instructions.
* Power the computer on.
* When the Dell screen appears press and hold the CTRL and F11 key simultaneously on the keyboard, then release them both at the same time.
The Dell PC Restore by Symantec window appears.
* Click the Restore button or press the key to highlight Restore and press the key.
A caution message appears advising that all data will be lost.
* Click the Confirm button or press the key to highlight Confirm and press the key.
The Progress window appears. Once the process is begun, Dell PC Restore usually takes only 8 to 10 minutes to complete.
When the restore is complete, the message The system recovery process was successful appears.
* Click the Finish button or press the key to highlight Finish and press the key.
The computer will restart.
2. If your operating system is VISTA / Win 7, tap F8 key when you see the dell logo. It will take you to advanced boot menu options under which you will see Repair your Computer, Select that option and enter your password if it asked, then you will be seeing list of options like system restore, command promt, etc., In that the last option says Dell PC restore or some thing like that. Select that option and follow the screens .. Thats it.
* Start the computer.
* As the computer starts, press the F8 key until the Advanced Boot Options menu appears on the screen.
* Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter.
* Specify the language settings that you want, and then click Next.
* Log in as a user who has administrative credentials, and then click OK.
* Click Dell Factory Image Restore.
* In the Dell Factory Image Restore window, click Next.
* Click to select the check box for Yes, reformat hard drive and restore system software to factory condition.
* Click Next. The computer is restored to the default factory configuration.
* When the restore operation is completed, click Finish to restart the computer.
3. If in both case, the Factory default didn't work, then your laptop's factory image defaults partition have vanished (i.e. Corrupted / Deleted). So you have to do Operating System re installation with the Operating System CD / DVD shipped along with laptop. Follow the below link to install windows XP Pro on your own.
either way you do it ...be careful that recovery will erase all data from the computer ..(at least the C partition) ...or ..if you choose just to restore defaults and reinstall drivers ..than be download them from where I linked you ..
Posted on May 31, 2010
  • 1 more comment
  • Catalin Turcu
    Catalin Turcu May 31, 2010
    If your computers starts in safe mode...and shows the mode menu ...than you have to choose the start computer normally ..and enter to start it the normal way ..(or last known configuration that worked..)
  • Catalin Turcu
    I gave it a thought and if you think that you might not manage well..I can assist you on IM if you want to ..Im not allowed t ..but I guess no one will read this post but you :d look for me on YM (yahooo) .. catalin_yo_vlad and we will do it together ..
  • Catalin Turcu
    Catalin Turcu Jun 01, 2010
    Ivan ...did you forgot about me??/I dont like ending the month without you ..:D
Stop c00002la {Fatal system Error} The windows Logon process terminated unexpectantly with a status of (0x000000000 0x00000000) The system has shut down fix for Dell inspiron E1505
Call up Dell or go to the web site and talk or chat with technical support. They can look up the error code and pin point the problem. Your laptop might still be under warranty so don't wait until it runs out you better act now.
Good Luck
Proteus
Nov 19, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron E1505 shorting out adapter
I would replace the battery if you had for some time. Over time charging a battery will slowly not take a charge. If you tried two adapters, about the only thing is left is the battery.
Aug 18, 2009 | Dell Computers & Internet
Dell Inspiron E1505 won't recognize new battery
It won't charge or work correctly if it's not the correct one and of the right voltage etc.I don't know how the battery even went in if it's not the Dell specified battery.If it went in and looked to fit maybe the battery itself is bad but its hard to say.
Aug 04, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron e1505 Backlight issue
when you leave the computer for a long time inactivity it goes to hibernate or standby
you can change it on control panel power options
Jul 10, 2009 | Dell Inspiron E1505 Notebook
LOOSE LEFT CTRL AND SHIFT KEYS
Generally, the keys on a portable keyboard are non-repairable. The keyboard is a Customer Replaceable Unit (CRU) and if under warranty, Dell should send a replacement, If out of warranty, Ebay is a good source for a keyboard and they generally run about $20
http://cgi.ebay.com/New-DELL-inspiron-Keyboard-630M-640M-E1405-E1505-6400_W0QQitemZ260372955660QQihZ016QQcategoryZ31512QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Apr 23, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 Notebook Logo
Alun Cox
