Question about Sony VAIO PCV-RS510 PC Desktop
I have a pcv-rs510 vaio desk top with DMA/ATA-100, 120 GB HDD can I install a slave 2nd HDD ATA-100 500 GB HDD, Or can I replace the ATA-100 with a ATA-300 1 TB HDD
  • Sony Master
  • 4,924 Answers
You can do either way ..the ide port will support them both ..the first one has the advantage that the operation system may be left on the first one .and the data stored on the second.this way large amound of data can be protected from hdd failure ..cause if it happens usually it is affected the one with operation system ..also you can move them easy just moving the hdd...
The second will be faster cause it will be all in one .and the data transfer from a partition to another faster ..also the bus has aa larger transfer rate and communication speed..but ..just see what is the most convenient for you ..price ..and function ...depends on what you want to do ..
Posted on May 31, 2010
After system recovery of my sony Vaio PCV-RS510, I did a Vaio updates and now computer will not boot. None of the buttons or keys working. Displaying "Sony" only.
If you have an install disc boot to it, restart your PC hold down F12 and select the CD/DVD Drive. If it boots to disc, go to the command prompt then run SFC /scannow. This will run the system file checker and repair your files as well.
Sep 05, 2011 | Sony VAIO PCV-RS510 PC Desktop
Hi can Sony Vaio PCV-RS602 mother board support a sata hhd
Yes,Specs says that it has SATA controller:
Product Description: Sony VAIO PCV-RS602 - P4 3.2 GHz
  • Type: Personal computer
  • Form Factor: Tower
  • Processor: 1 x Intel Pentium 4 3.2 GHz
  • Processor Main Features: Hyper-Threading Technology
  • Cache Memory: 1 MB L2 Cache
  • Cache Per Processor: 1 MB
  • RAM: 512 MB (installed) / 2 GB (max) - DDR SDRAM
  • Storage Controller: Serial ATA ( Serial ATA-150 ) ; IDE ( ATA-100 )
  • Floppy Drive: 3.5" 1.44 MB floppy
  • Hard Drive: 1 x 160 GB - standard - ATA-100
  • Optical Storage: DVD±RW
  • Optical Storage (2nd): DVD-ROM
  • Card Reader: Yes
  • Monitor: None.
  • Graphics Controller: AGP 8x - ATI Radeon 9600 XT
  • Video Memory: 128 MB
  • TV Tuner Type: Analogue TV
  • Audio Output: Sound card - 5.1 channel surround
  • Communications: Fax / modem - 56 Kbps
  • Networking: Network adapter - Ethernet, Fast Ethernet
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
    Thanks, Joe
    Feb 06, 2011 | Sony VAIO RS602 (PCV-RS602) PC Desktop
    What is the slave patern for 500 gig hard drive
    The BIOS is AMI. Under ADVANCED SETUP:
    The options listed for 1st,2nd ,3rd Boot device include:
    IDE-0 means Pri master ?
    IDE-1 means Pri slave ?
    IDE-2 means Sec master ?
    IDE-3 means Sec slave ?
    hope this helps
    Dec 10, 2010 | Western Digital WD Scorpio Blue WD5000BEVT...
    Looking for hard disk 320GB for my asus matherboard p5gd2-x which HDD sopport this matherboard help!!!!!
    pretty much any brand will work. looking at the specs tho get a sata type drive as it appears you have 4 on that motherboard
    Storage Controller Type(s) DMA/ATA-100 (Ultra) x 1, Serial ATA x 4
    Dec 02, 2009 | Computers & Internet
    Installing 500 GB EIDE HD in a SONY PCV-RX560
    what are the jumper setting on the hard drive. make sure the old one is the master and the new one the slave.
    Jun 13, 2009 | Sony VAIO Digital Studio PCV-RX560 PC...
    Sony vaio pcv-rs510 fails to fully boot. Goes past initial windows screen then blanks out.... safe mode fails to boot as well... command lines just pile the screen.. need help plzz
    reinstall os.bios should be preset to boot from cd/dvd but if not power on then press delete key or escape key till bios loads-in boot opt. select cd/dvd drive first boot.put os disk in drive and restart when asked to press key to boot from cd do so.follow inst. instructions.after insall detects previous version of xp select repair (r key) and follow inst. should solve startup problem without losing data.if not reinstall os but select leave files intact instead of format or you will lose all files.
    May 31, 2009 | Sony VAIO PCV-RS510 PC Desktop
    How to upgrde sony pcv-rx470ds desk top hard drive; what is the max gb?
    Looks like this unit is a couple of years old by the specs.
    160 to 200 GB would ba a good size to install in the unit.
    It is easy to replace the hard drive. Just remove the old one and install the new by reversing the procedure. Just make sure that the jumper is set to master( which is how the new ones come jumpered)
  • Intel® Pentium® 4 processor 1.50 GHz (2)
  • 128 MB PC-800 RDRAM (expandable to 512 MB)
  • 400 MHz Front Side Bus
  • 60 GB (3) Ultra ATA/100 hard drive
  • 16X max. DVD-ROM/40X max. CD-ROM
  • 12X8X32X max. CD-RW Drive
  • High-speed Internet ready with 10 Base-T/100Base-TX Fast Ethernet
  • 4X AGP 3D Graphics Hardware Acceleration (NVIDIA® GeForce2 MXTM )
  • 32 MB Video Memory (SDRAM)
  • i.LINK® (IEEE 1394) chipset on motherboard (1)
  • Front accessible i.LINK (IEEE 1394) interface and USB connections (1)
  • Programmable VAIO SmartTM Keyboard
  • V.90 compatible data/fax modem
  • Wheel mouse
  • External stereo speakers
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Feb 20, 2009 | Sony VAIO PCV-RX470DS PC Desktop
    Failing install of PCI SATA Drive
    You need to load the SATA Controller driver for the XP install to access the HDD.
    The driver will need to be downloaded and extracted to a floppy diskette, then loaded during the XP install.
    If your system doesn't have a floppy drive, you'll either need a USB floppy drive or create a slipstreamed XP CD with the driver added to the CD.
    Aug 12, 2008 | Sony VAIO PCV-RZ44 (PCV-RZ44G) PC Desktop
    Sony VAIO PCV-RS510 PC Desktop Logo
    117 people viewed this question
    Top Sony Computers & Internet Experts
    Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
