Question about Fisher and Paykel GWL11 Top Load Washer
Machine does not power on. Control panel does not light up. Machine does not beep when plugged in.
  • luisa_sgro May 31, 2010
    have you checked the power point for power with a small appliance eg toaster , hairdryer? if there is power at the power point and your machine does not light up or beep then either your pump is open circuit or your control module is faulty.has your machine got an efficency button? please reply for further help.
  • jean_mandevi May 31, 2010
    Thank you for your reply. I've verified there is power at the plug by plugging in a portable light. This model does not have an efficiency button. Is there an easy way to check the pump and control module for failure? Thanks again.
  • 159 Answers
Hi there,I'm afraid it sounds as though the main computer board is dead or the display panel where the buttons are is dead.Also i'm not sure with this model but with some of them the power runs thru the water pump before powering the the main board,if the pump is open circuited or dead then it may not be providing power to the main board.With a multi meter the pump can be tested for a circuit,it should read around 34ohms.or take the pump out (its quite easy) & take it somewhere & have this test done to it.this could be the cheapest way out & a good starting point. Ps if you recently had a bad electrical storm or power surge then that might be it..dead main board..In my tips section i mention the importance of unplugging these types of machine after washing to keep them safe.I hope i have been helpful in some way.Ide be glad to hear how you went.cheers Chris
Posted on Jun 01, 2010
  • danny gates Jul 21, 2013
    I found 2.1 ohms on the water pump motor. I believe this was caused by a water leak that might be on the water pump seal. I'm still investigating.
Replaced water pump and control panel, have power, but just beeps.
Fisher and Paykel GWL11 Top Loading Washer
ths.gardenweb.com > Home Forums > Laundry Room
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... 4) (Rinse Phase) Drain the water, then lock the lid for spin. ..... I plug the power cord in and I have nothing on the control panel. ..... As the controller was only replaced early in January, I've flicked F&P NZ an email to see if it's still under ...
How to repair a Fisher Paykel Washing Machine
www.instructables.com/.../How-to-repair-a-Fisher-Paykel-W...
InstructablesI removed the pump and control panel, found no blockage in the pump, so far ... Ihave just tried to fill my F/P machine but the water is just dripping in. ... I have aFisher Paykel washer have replaced the control module and now it .... washing machine MW612, stopped working and displayed beeping sound every second.
Jan 16, 2016 | Fisher and Paykel GWL11 Top Load Washer
How do I reset control panel on km Elite mod #11022032100 top load washing machine?
did you check to see if the power is working first and didn't blow the breaker. then try plugging it back in. and is the machine loaded, if you can empty the machine see if it does anything
Feb 12, 2015 | Washing Machines
Does not seem to want to lock and a code F1 comes up and it just keeps beeping
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 14, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Same problem as other customers, F1 comes on and washers STOPS and beeps. Looking to set up a repair appt.
Jun 16, 2010 | Whirlpool WTW6400SW Cabrio Washer
Starting washer it beeps and flashes a F1 sign how do u fix
Jun 11, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows F1 top load cabrio whirlpool washer
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
May 10, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Keeps beeping F1
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#%
Apr 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My whirlpool cabrio washing machine keeps flashing F1?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$%^
Mar 28, 2009 | Whirlpool WTW6400SW Cabrio Washer
Fisher and Paykel GWL11 Top Load Washer Logo
195 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
