Where Dell Flat screen 15" monitor has not been used for a period of time or on boot up the screen displays for a seond then goes black (although in a certain light you can see the icons and programs in use). If you switch the monitor off and back on again the display appears for a second and goes black again. If you complete this around 30 to 40 times then the display appears fully lit up. Throughout this time, where the monitor is switched on, the power button appears green
  • 4,234 Answers
You most likely have a bad connection inside the unit. Specifically, there are a couple of "backlights" that provide the light that will pass thru the LCD panel. If you can open up the unit, with the screen facing up, there should be a small PC board on the right. Check the connections on that board. Be careful as there is high voltage there.
Keep us posted.
Dan
Posted on Apr 08, 2008
I have the same problem as this one does. my monitor goes black when windows boots. I can see the computer load at fist, then when the window icon shows. the screen goes black. WHY ?? im thinking there is...
you can try Fn + F8 and see if the display was toggled for external (Wait about 15 seconds before pressing a 2nd time) that is the keystroke from (LCD, External, LCD and External)
If no go, see if your system keeps video displayed in the safe mode (F8 at boot, select Safe mode from the boot menu)
you can also run diags on the LCD (Power button + D) or PSA diagnostics and see if the video stays on out of the operating system (Power +Fn)
Jul 21, 2011 | Dell Latitude D520 Notebook
I have a Dell 15"
You need a new driver for the monitor. Are you now using a new Operating System? Perhaps Windows 7? Go to the http://dell.com websit and look up your monitor under downloads and drivers. Fidn the compatible driver for your operating system and download it.
Dec 31, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
Dell Dimension 3000 Video problem
There may be a problem with your windows installation. Search Google for Hirens boot CD, it is a free download and should contain a live XP installation. When you turn on the computer tap the appropriate button to reach the boot menu, then insert the CD and select your CD drive. Once booted it should display a live XP.
Alternatively you may have your monitor set to an incompatible resolution. If tapping F8 won't display the advanced boot menu then try finding an auto setup on your monitor or change the resolution using the monitors controls. If the advanced boot menu does display then select low resolution mode.
Hope this helps,
www.PuterCare.com
Jul 02, 2010 | Dell Dimension 3000 PC Desktop
At start up screen goes black and get message can
Native/max resolution for this Dell is 1280x1024, try this setting.
Feb 19, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
ViewSonic 19" flat screen monitor goes black - intermittently
There could be a problem with your display card settings or the display card itself. If you are using Windows operating system, make sure that you have the monitor driver installed for that specific monitor. This is to ensure that Windows only allows settings for which your particular monitor was designed.
Let me know if I can assist you any further regarding this.
Best wishes,
Graemevm
Jun 12, 2009 | ViewSonic Optiquest Q9b 19" Flat Panel LCD...
My monitor goes black for about 2 seconds then goes back to pict.
Sounds asif the Xenon tubes that backlight the LCD are losing power. Probable cause, a power invertor or PSU fault.
It can be repaired by a hardware specialist, but best written off.
The cost of repair will be better spent on a new monitor.
Mar 19, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
PC monitor not lighting up for around 10 mins
Check the capacitors on the power supply board inside the monitor. They malfunction, heat up, leak or pop and stop doing what they are designed to do, smooth out the power supply to the inverter and display board. You can replace these simply by buying the correct farrad, voltage and temperature rated replacements online for about .30 a piece or go to radio shack and spend 1.50 a piece. You can use a higher voltage like 35V instead of 25V but try and get the 105c rated ones to last longer in the hot P/S environment. My bad ones were 470 micro farrad, 25V and 105c rated and I had 4 out of 8 pop or bulge.
Apr 08, 2008 | Computers & Internet
Monitor problem
It sounds as if you have a resolution set that the display does not support. Restart your machine in safe/VGA mode by holding down F8 while the machine boots. Once in safe mode, set the resolution (Right click--> properties--> Settings--> Screen Resolution) to one that your display supports.
Jun 18, 2007 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Monitor (Dell 1701FP) flickers, flashes and goes black
Just to check - when the screen is black- can you see any image- in its un-illuminated state. To do this look sideways along the screen not straight at it. I suspect this is an inverter problem. Whether or not this is repairable I know not- depending on your local repair facilities Perhaps DELL can suggest a local agent.
May 16, 2007 | Dell UltraSharp 1701FP 17" Flat Panel LCD...
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
