Question about Nintendo Wii Console
I have turned my wii on so the console is fine just when i go to use the remote in wont work usually i press a button and all lights flash then i get one light on and yep it starts working but now when i press the a button the lights do flash but dont want to link up with the console, what should i do?
    President:
  • 1,099 Answers
The local remote sensor panel may probably death or damaged, or the brain box component of the console has damaged. it can be fixed up by taking this to a well specialized personnel on it. Hope this will help
Posted on May 31, 2010
Bought a new will remote but it doesn't work.
Check the battery levels. You can do this by pressing A. If all 4 lights flash on and off, your batteries are completely charged. 3 lights, 2 lights, and 1 light signify 3/4, 1/2, and 1/4 battery levels. If lights don't flash, replace/insert batteries.
If it's not working with your console, open up the battery cover and the flip lid on the front of the console. (If it's a Wii U, you don't need to open the flip lid.) In both places, there is a red button. (On Wii U, it's next to the flip lid.) Press both red buttons at the same time. (Your Wii will need to be powered on.) The Wii Remote will continuously flash lights until it either receives a sync signal or about a minute has passed; whichever comes first. If you've pressed the buttons and your remote is still flashing, press the button on the console again. Once the remote is synced, the flashing lights will turn into a single light; the placement of the light will vary depending on how many remotes are signed into the Wii.
*Note* Once your remote is synced, you simply need to press A to sign back in if your remote turns off.
If all of the above steps were followed, and your remote is still not functioning, contact the manufacturer. Brands such as Nintendo and Nyko are usually okay, but generics like GameStop aren't the best. It's often easiest to return it and buy a different brand.
Apr 29, 2014 | Nintendo Wii Console
After pressing the red sync button on the console for about 10-15 seconds, and syncronizing the remote, the remote stars to work, but when I start a game the remote is no longer working. Then when I...
There are two ways to sync the Wii remote with the Wii console after pressing the red sync button like you did:
1) Press the "1" and "2" buttons on the Wii remote until the lights begin to flash. This method provides a temporary connection to the Wii.
2) Open the battery cover on the Wii remote and press the red button next to the batteries. This creates a permanent connection or "pair" between the Wii remote and the Wii console.
Based on your description, it sounds like you are using method #1. In order to power on the Wii when the Wii's red light is on (meaning the machine is turned off) and start playing games like you want, method #2 must be used.
Imagine method #1 as "guest mode". If a friend comes over with their Wii remote and wants to play a game, you would open up the game first, use method #1, and your friend would temporarily be connected to the Wii. Using method #1 is like "owner mode" that lets the Wii remote turn the console on and off and always stay connected to it.
Hope this helps!
Mar 10, 2011 | Nintendo Wii Console
Remotes wont work light up but wont stay on ,hit
The red button, is a sync button and not a reset button. You can try resyncing your wii remotes to your wii follow these steps:
  1. Press the Power button on the Wii console to turn it on.
  2. Open the SD Card Slot cover on the front of the Wii console. Remove the battery cover on the back of the Wii Remote you wish to sync up.
  3. Press and release the SYNC button on the inside of the SD Card compartment on the console. Press and release the SYNC button just below the batteries on the Wii Remote.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 through 4).
You must have batteries in when pressing the red sync button on the wii remote, if your using the wii remote charger system, you must remove it and use batteries until this step is done
Hope this helps. Owen
Apr 20, 2010 | Nintendo Wii Console
Our wii remote wont turn on. we tried new batteries and all it does is the blue lights flashes and turns off. What is wrong and how can we fix it
Sounds like it's not synchronizing with the infrared bar. That might've come loose. Double check to make sure that's plugged into the Wii. If that's not connected the Wii Remote will not stay on because it's not connecting.
Oct 14, 2009 | Nintendo Wii Console
I have a nintendo wii the remote will not work
First open the SD card lid on the wii then take battery cover off wii remote. Turn the console on and press and release the small red button on the remote. (You must do this as you are on the Health and Safety page). Now the light will start to flash. Press the red sync. button in the wii console and release. Hope this work =)
Oct 02, 2009 | Nintendo Wii Console
My wii remotes wont pick up signal blue lights flash then just go back out again
Hi, check the batter level and then try re-synching the remote's.
Here's instructions for both:
f4bc8924da.gif A fresh set of alkaline batteries should last, depending on amount and type of use, up to 35 hours. This can vary greatly based on certain factors, such as Wii Remote Speaker Volume, Rumble, battery quality and age, and type of game being played.
Important Note: If you are using rechargeable batteries, the only type of battery recommended are Nickel Metal Hydride batteries. When it comes to using rechargeable batteries, you must follow manufacturer guidelines for safety and proper usage. Failure to do so could cause damage to the Wii Remote and void the warranty.
There are two ways to check the Wii Remote's battery levels:
  • Remove the battery cover and press the Red "Sync" button. The number of lights flashing indicates the Wii Remote's battery strength. Four flashing lights indicates full strength, with one light flashing indicating the lowest level.
    or
  • Use the HOME Menu to check battery level of each Wii Remote:
    1. Press the HOME Button on a Wii Remote that is synchronized with the Wii console.
    2. Select the Wii Remote Settings option from the Home Menu.
    3. The battery level of all synced Wii Remotes is displayed along the bottom. Four bars indicates a full charge, with one being the lowest charge.
55851daefd.gif Note: Make sure you have placed batteries in the Wii Remote.
  2. Remove the battery cover on the back of the Wii Remote you wish to sync up, and press the SYNC button just below the batteries. The Player LED will blink.
  3. Open the SD Card Slot cover on the front of the Wii console and press the SYNC button on the inside of the compartment.
  4. When the Player LED blinking stops, the syncing is complete. The LED that is illuminated indicates the player number (1 to 4).
This procedure must be followed for each additional Wii Remote added to your system.
I hope this helps
Mike
Jul 30, 2009 | Nintendo Video Game Consoles & Games
Remote dont work. lights just flash. tried to sync did not work. Bought a new remote and went to sync it now it is doing the same thing the other remote did> Any suggesions?
Basic Question: Did you set up the sensor bar?
I'm assuming you follow the instructions to plug in the Wii and to attach the sensor bar to the console and position the sensor bar so it is either below or above the television.
The Wii remote flashes (more specifically the bottom row of four lights that indicate which player each remote belong to flashes) when a button is pushed on the control while the Wii is off.
If the Wii is on and simply sleeping (as evident by a blinking yellow light on the power button on the console) pushing the power button the control should turn on both the console and the remote. Be sure to aim the remote at the console when "waking" the Wii up and at the sensor bar once the Wii Menu loads. The remotes automatically turn off with lack of interaction.
To recap: Your remotes sound to be working fine. I would assume it might be a problem with the interaction between your console and the remotes or the setup of the console. The Wii Information Guide has pictures and pretty clear connection instructions that should help fix your problem.
If everything is set up correctly as per the instructions and your system still does not interact your sensor bar may be faulty or your console as I believe you're remotes work fine.
Jun 26, 2009 | Nintendo Video Game Consoles & Games
Can't sync wii remotes to console
When you sync the wii motes you have to do it in proper order!!!
There are 2 ways to sync one is minor out of sync stuff. You push red button on the wii briefly then quickly press the red button on the wiimote.
Second one is what you need to do. First remove any disk then hold in the power button until the light turns red. (not yellow or orange). Release it then unplug the Wii. Do not remove the batteries but if they are low replace them before you turn it back on. Wait at least 2 minutes.
Have the backs off the Wiimotes.
Plug the Wii in.
Turn the power on.
As the Health and Safety screen appears push in the red button on the Wii.
Hold it there a min. of 15 seconds. 25-30 is better.
When you release it right away push the red button on the first Wii mote. It flashes all the lights.
Immediately press then release the red button on the Wiimote while lights are flashing. When they stop flashing it will be synched.
a.Then press the button on the Wii again (this time only hold for 2-3 seconds) then press the red button on the second wiimote and while lights flash press the button on the Wii again.
Repeat a. for any other wiimotes.
Jan 01, 2009 | Nintendo Wii Console
Remote not working
press the red button under the front door then press the button under the battery compartment of the remote.
good luck
please mark the post with a fixya
Feb 12, 2008 | Nintendo Wii Console
Discs wont register on wii system, remote wont work either
You need to sync the remote with the console.
Remove the battery cover from the remote and press the red
button until the blue lights start to blink. At the same time,
press the the red button to the front of the console.  You
can access this button by removing a small cover on the front
of the console. This will reset the machine and you should
start to see th cursor in the tv screen. Repeat this if necessary
and you should be on your way. Good luck
Sep 25, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
