Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
How do i hook up my ice maker on a 1994 fridgidaire refridgarator
    President:
  • 3,113 Answers
If it already has one just run a water supply line to it.
Posted on Jun 02, 2010
How to install water line in side by side refridgarator
What is the water line that you would like to install is it attaching to the refrigerator your question or is it a water line that goes under the refrigerator and to the dispenser or the ice maker? Is the model number of the refrigerator correct within your post?
Appliance 911 Sea Breeze
Jul 19, 2016 | Frigidaire FRS3R5EMB Side by Side...
Ice maker making loud noise for exrended times on fridgidaire
water will condense and then freeze in the fan area. Need to remove freezer inside back panel and remove ice from fan area. Fan is located abot @/3 down on right side. No permanent fix I have to do it about every three months.
May 11, 2014 | Frigidaire FRS26R4A Side by Side...
Frigidaire professional refrigerator
Sounds like you have a problem with water valve/triple solenoid assembly. It controls the flow of water to the door and ice maker. I believe it comes as a complete unit.
Dec 28, 2013 | Refrigerators
Fridgidaire gallery refrigerator ice maker Ice maker seems to freeze up and won't drop the ice.
Hi, The ice is clogging up the despenser. You need to open it and free it up.. Good luck.
Jun 28, 2011 | Frigidaire Refrigerators
We have a Fridgidaire side by side m#FRS6LF7GS4 The ice maker is not making ice. I'm assuming the water is still flowing to it because we can get water from the door still and we do have the medal arm down...
It sounds like the ice maker has burnt out and needs replacing, Try raising the metal bar to shut it off and then turn it back on, you can also remove the front cover from the ice maker and make sure the small motor inside is turning(this should always be turning when the ice maker is on)
Aug 21, 2010 | Refrigerators
I need a new auger for the ice maker but can't
First I will need a model number for your Fridgidair.
Jul 25, 2009 | Refrigerators
The ice maker on my Fridgidaire will only give crushed ice, even though we've never pushed that button. We only want cubes.
check to see if your ice solenoid on the rear of the ice maker bracket is seized up with ice. if so you can remove this and run warm water over to unseize solenoid. remove ice bucket and u should be able to see the solenoid close to rear wall. it is attached to the metal bracket that holds the ice bucket in place. usually two quarter in screws holds it in place
Jun 21, 2009 | Electrolux Refrigerators
Slow Ice maker
How much ice does it make per day?
There are several things that affect ice making capability, such as -
1) How often the doors are opened
2) Leaky door gaskets
3) Bad ice mold thermostat
4) Light in refrigerator does not go off when doors are closed (easy to test).
Jan 23, 2009 | Frigidaire FRT21H8 Top Freezer...
Fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Jan 17, 2009 | Frigidaire FRS26R4A Side by Side...
Ice dispenser crushes ice when cube is pushed
the little gate/door, is a common issue, its a solenoid htat either burns out, or merelt freezes over. if you put your finger into where teh "shepard hook" supposed otgo, can you freely lift it ip and down???i would assum not, .the entire ***,bly lifts out of freezer( remove 2 1/4 inch scres under each corner and diconnect apower plug behind the ice maker. from ther you can try to defrost teh piston,if not rplace it.
Jan 02, 2009 | Frigidaire GLRS267ZA Side by Side...
Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
54 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
