Question about Insignia IS-LCDTV32 32 in. Television
Screen seems to dim and there is flickering while watching
I don't know if this went through the first time.
THe screen on our TV would flicker when you turn it on and then in about 3-5 seconds it went away and the unit worked great and is great viewing. Last night while watching the big game, the screen seemed to dim in contrast and then the screen started flickering. The flickering was not off and on, but the screen was fairly clear to watch.
  • grm2 Dec 16, 2008
    I have the same model TV, but in a 27" size. I'd like to replace the capacitors on the power supply board, but I think this board is different than the one you wrote about above, there are no E919 - 921 caps on my board. Most of my board notations start with the letters C or R, followed by numbers in the 500 range.
    I do see 4 caps labelled "+105 deg C", might these be the ones? If so, I need to know the ratings of a cap to replace them. I don't see any color coded rings, just labels like "CD286" and "CD263". Any tips?
  • 934 Answers
This is both a common and fairly easy repair in this unit. Remove the back, but not all of the back needs to be removed to access the power supply area and locate the power supply board. You might find that all three E919,E920,E921 of the 35v/680uf caps in the upper left of the PS board are bowed and/or vented. Replace all three of them even if they test good...
Next, esr the remaining caps. Last one we did here in the shop there were 16 total that we replaced, many were orange in color but I don't have any notes on their value. The orange color of the cap is a lesser temp range we used 105 degree or better as replacements. Some we used a higher rated cap (higher voltage) same uf rating. Gave it a greater reliability.
Good Luck!
Bill
Posted on Apr 08, 2008
Need fixs how do i make it stop flickering?
How do i stop my vizio from flickering? - YouTube
? 2:18
https://www.youtube.com/watch?v=RD2PwPFpbrE
Jul 19, 2013 - Uploaded by colguon38
Please help me stop my TV from flickering. ... 1080p. the monitor will momentarily change resolutions. that is the "flicker" you see. unfortunately i ...
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY ... I have this exact make and model. .... and theflickering didn't stop. any ideas as to which JP I should cut . please help not ready to buy a new TV.
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
this might work for other tv's too. ... If your not sure you can dothis repair your self please take it to a tv repair shop. The repairshould be ...
Jan 04, 2016 | Televison & Video
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
Ustvnow dvr tv shows unable to watch recorded shows when press play without causing tv screen to flicker twice and not able to watch tv program
It appears it is not your fault. I contacted ustvnow and they said they are "working on it" but currently the DVR service is not available on roku. If you find an answer elsewhere, I'd love to hear it
Dec 01, 2012 | Televison & Video
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
Laptop screen flickers and goes off .
You could have a faulty inverter but
You most likely have a defective CCFL backlight, it may have the following symptom:
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 13, 2009 | Sony VAIO VGN-C140G/B Notebook
Computer Monitor is dim
Time for a new flat screen monitor...The power supply is on it's last legs.
Apr 03, 2009 | Toshiba Tekbright 15" CRT Monitor
Samsung LNT4669F Pixcels Flicker
As long as you only see these artifacts while watching certain broadcasts, the TV is fine.  If these lines are present no matter what you are watching, then you have a problem. What you are seeing is signal related and there isn't much you can do to fix that. Think of it like a scratched DVD; you will see strange things on the screen at times and many think it's the TV when it's only the signal from the device to the TV that is corrupt.
I have thought of one possible solution and this will depend on your TV's ability to slightly stretch the picture in vertical/horizontal directions.  If your TV will let you, you may be able to raise the top of the picture a cm or so to hide the flickering.  Check the TV's onscreen menu for anything to do with picture alignment.  This is nothing to do with aspect ratio though so ignore that.
Mar 24, 2009 | Samsung LNT4669 TV
MacBook Screen Problem
Hi there
If I understand you correctly from start up the screen is dim but does brighten up after time? But now after start up you are getting a flicker how ever a restart solves this.
On the dimming issue. Check your energy saving settings and brightness key is working OK.
The flickering is a bit of a concern.
Just a couple of questions.
Are there any dead spots on the screen? Areas where there are no pixels.
When you tilt the screen forward and backward, does this effect the brightness or flickering?
Paul
Sep 03, 2008 | Apple MacBook Mac Notebook
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Insignia IS-LCDTV32 32 in. Television Logo
409 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
