Question about Kenmore 43142 Front Load Washer
What causes a whistling noise when it is drawing
What causes a front load washer to make a whistling noise when it is drawing water
    Brigadier General:
  • 4,090 Answers
This can be caused by a restriction in the hose. Check for kinks or that the tap is fully open. Depending on water hardness the problem may actually be in your pipes rather than the machine. Not until its connected to a semi restriction will you realise that the pipes are clogged.
Depending on age of the machine the inlet valve may be partially closed or open as the case may be.
Please rate my help++++Thanks for using FIXYA
Posted on May 31, 2010
Hums andwill not drain and do final spin
Probability is you have a blocked pump. That humming noise you are hearing on the spin, is the pump motor polling as it cannot turn. The machine will not spin until the water is out. This is the safety function of the pressure switch. Centrifugal force would otherwise cause the water to be forced out of the machine from places like the dispenser draw and flood your laundry.
Regards
John
Jan 30, 2014 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
My LG front loading washer makes a train noise during the rinse cycle. What could be the cause?
if it is right after the drain cycle; it then goes into a spin. It then starts to fill with water for the rinse while the tub is still turning. The water entering the tub while the tub is spinning, cleans the tub of soap and the water going through the holes in the tub are causing the noise. It is normal if only in the rinse cycle.
Aug 29, 2010 | Frigidaire GLTF1670A Front Load Washer
Maytag Neptune model # mah6500aww: makes banging noise and causes machine to move
A loud banging sound in the pipes is usually caused by a water hammer effect. Water hammer sounds are caused by a valve closing in the system, and yet the water in the pipe is still flowing because of its kinetic energy. The banging happens as the water hits the valve that prevents it from going any further. If the kinetic energy is great enough, it can actually cause a pipe to burst or explode at the end. If a valve is closed near the beginning or in the middle of a system, the water keeps flowing after that point, and it can actually create a vacuum. This vacuum can cause a pipe to implode if the stress is too great. Roaring type noises may be coming from a spin bearing. This bearing probably had the grease washed from it because of a tub seal leak.
Squeaking sounds in a new washer are usually caused by the new parts getting broken in, and will usually go away after several washes.
The sounds of water gurgling, slurping, or sloshing during a spin cycle are usually caused by the drain pump pushing the water out of the washer tub.
Too much water pressure can cause a whistling or squealing sound. Adjust the hot and cold intake water valves to relieve this sound.
Metallic clinking sounds during spin or agitation may be the result of drive train components meshing during speed changes or after a pause.
Swishing or swooshing type of sounds may be caused by water and suds trapped between the tub and basket during a spin cycle, and will usually clear up as the water is drained from the washer
Jul 29, 2008 | Maytag MAH6500 Neptune Front Loading...
Kenmore washer machine heavy duty 70 series
most likely a water pressure issue try adj shut off valve off slowly until noise stops if water flow not enough ckd fill screens in back of valve for sediment and trash
Apr 29, 2008 | Kenmore 22422 Top Load Washer
LG Electric Front Load Dryer door whistles!
under warrenty call serv tech they ussally know whats wrong from svc bullitans
Dec 22, 2007 | LG DLE2532W Electric Dryer
Hotpoint aquarius wm63
hi in the powder tray is the conditioner tray there is usually a plastic part that the water runs up into so it can pass to the machine this plastic part gets blocked,pull it out and give it a good clean,if ther are two small plastic pipes make sure water goes up one side and down the other
Oct 19, 2007 | Hotpoint Aquarius WD63 Front Load...
Kenmore 43142 Front Load Washer Logo
829 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
