I am trying to connect a new phillips dvd recorder to a mitsubishi WT-42315 tv and can not locate the external input channel to begin setup for the dvd player recorder. It is connected via a digital cable box and to the tv via a DVI/HDMI cable. What I'm I missing?
    Genius:
  • 1,142 Answers
Have you tried a hard reset ?
Posted on Apr 08, 2008
SOURCE:
I have a mitsubishi wt-42315. when i turn it on it shuts down right away. any thoughts?
Do the self check this model has.
When you turn it on and green power light goes out:
on front of set press and hold both the menu and input (or device) buttons at the same time for at least 5 seconds and release both buttons.
The power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will tell you what problem is.
If this helped rate this solution as very helpful as I do this here for free.
SD TECH
Sep 20, 2010 | Mitsubishi WT-42315 42" TV
I GET TO THE WINDOW TO PROGRAM A RECORDING BUT FOR CHANNEL SELECTION I ONLY GET L- L-2 OR L3 I NEED TO BE ABLE TO SELECT THE CHANNEL LIKE 6 THIS IS A NEW HD TV. I AM ABLE TO PLAY EXISTING SHOW ON THE DVD...
Hi.
You will need to connect an antenna and program channels to internal tuner if you want to use the built in tuner.
It is not clear if your problem is with the HDTV or with the DVD recorder.
Both have an internal tuner, and both can tune channels , L2 and L3 are the input lines used when you connect for example to an external receiver.
Regards.
Nov 14, 2009 | Panasonic DMR-E80H DVD Recorder
I have installed a converter box we have a rooftop antenna, now I cannot record, it does not seem to find channel 9.1, 12.1 etc only 9, 12 etc I went from antenna to converter to DVD MWR10D6 to TV. My tv...
If you have the converter connected to the recorder by composite or s-video(line inputs), you will need to specify which jacks from within the setup menu of the recorder. There are 2 sets of line inputs into the recorder, so you have to select the right ones. They are called L-1 and L-2. The L-1 jacks are in the rear and the L-2 jacks are in the front. The channel selection should also be on L-1 or L-2. If you are using the
RF input(fat cable) to the recorder, you should have the recorder on the channel number that matches the output of the converter (channel 3 or 4). The converter RF output is selected by a switch in back of the converter or by the setup menu of the converter.
Menu path for setting L-1 or L-2 inputs:
Setup > General Setting > Video > Video Input > L-1 or L-2 > Video In or S-Video In
Jul 08, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Need the remote code for a phillips dvd player
These are the codes printed in the owners manual for your dvd/vcr player.If they do not work you will have to contact Emerson and ask them for help getting the code. The contact number should have come with the instructions for the remote. Just give them the model number of you remote and the units model number and they should be able to help you. I hope this information helps you with your problem. Switch the input selector on your TV to an appropriate external input channel (usually near channel 0).
Press a button on the TV’s original remote control that selects an external input channel until the DVD
recorder’s picture appears. Check your TV owner’s manual for details.
Admiral
Curtis Mathis
GE
Hitachi
JVC
Kenwood
LXI-Series
Magnavox
AUX
LINE1, LINE2, 00, 90, 91, 92, 93
INPUT, TV/VCR, 00, 90, 91, 92, 93
INPUT, AUX
VIDEO, VIDEO 1, VIDEO 2, VIDEO 3
AUX
00
AUX CHANNEL
Input Mode Names for Common TV Brands (Example)
Panasonic
RCA
Samsung
Sanyo
Sharp
Sony
Toshiba
Zenith
TV/VIDEO
TV/VIDEO
VIDEO
00
VIDEO1, VIDEO2, VIDEO3
TV/GAME
00
Apr 25, 2009 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Mitsubishi WT-42315 42" TV has a red/Green color seperation
you need to replace the convergence chips, i had this done about a year ago and costs 450.00 usd
good luck
Jan 10, 2009 | Mitsubishi WT-42315 42" TV
Connecting to a DVD/VCR player/recorder
In the menu of the Philips dual unit,select set-up then look for channel auto-program instructions. Be sure to hook-up a tv channel signal source before beginning auto-search.Hope this helps.
Oct 03, 2007 | Mitsubishi CS-27205 TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Ekse
