Question about Shuttle AV42 Motherboard
Connections Hi! Here is a link to pic of my motherboard: AV42.jpg Wires to connect: Power Led +/- HHD Led +/- M/B SW Reset SW Thank you!
  • zage89 Apr 09, 2008
    Hi. I sent the pic just checking if u got it?
    Yes! I cant thank you enough! Fixed my problem!
  • 655 Answers
Sorry friend its not accessible here.
send it to my mail
Posted on Apr 08, 2008
  • Iqbal Husain
    Iqbal Husain Apr 09, 2008
    Yaa zage i got it.
    here is your connection detail. See picture
    So make connection and finally...............:)) lol
    and don't forget to rate it fixya..
  • Iqbal Husain
    gaze you can connect power led to MSG LED
How to connect reset power and leds
Okay, look at your motherboard from this orientation so we're both looking at the same thing in the same way.
On the bottom of the motherboard, just above and to the right of the notation "MADE IN CHINA", is a group of pins with the notation above that reads "PANEL 1". That's where your Power switch, Reset Switch and LED lines will plug into.
Look at the eight pins in the nine pin panel that form a box of two rows of four pins each. Those are the actual pins you'll be using. Ignore the one on the bottom row that's off by itself. Shuttle does, so we should as well.
Now, to the right and down of PANEL 1 is a little drawing on the motherboard of PANEL 1 with little lines and numbers and such. This little drawing shows you which pins are used for which lines. It looks kind of like this...
2 4 6 8
'MSG ' PWR '
'LED ' BTN '
'HDD ' RST '
'LED ' '
1 3 5 7
Lastly, as PANEL 1 has a little "+" right next to Pin #2, and we don't have a manual handy because Shuttle seems to have all the information available on the web except a copy of the bloody manual, we're going to take an educated guess that for each two-pin part of the box, when plugging in the individual plugs, make sure the black wire is the one on the right, and the colored ones will be on the left.
So, plug the Power button into the upper-right two pins, black wire on the right, Reset on the lower-right, HDD LED on the lower-left and the Power LED on the upper-left. (I'm guessing that's what "MSG LED" means. There are no "Power LED" pins anywhere that I could find.
This should take you only a couple of minutes, so post back if you have any difficulty. If you need a hi-res image of this motherboard, go to the below link.
Jan 06, 2014 | VIA Shuttle Av49vn Av49v Socket 478...
I need to figure out where to plug in the Power LED and the power SW wires to the mother board
The link for the motherboard manual can be found here, on which there will be a pinout diagram of the Fpanel pin headers
USUALLY the wires are marked as:
Power switch: PW
Power led = Pled
On the motherboard you will see (bottom right corner I think), a group of about 8 pins in a block, this is the Fpanel pinset. on the motherboard next to each pin SHOULD show the wire connections as described above, but consult the manual to be sure.. this is a VERY old mobo
Dec 28, 2010 | Abit KT7A Motherboard
I put a motherboard in my pc and i dont know where 2 put POWER SW,RESET SW,HDD LED,POWER LED....please help
ok man on this picture in the bottom of the pic there will be a sort of black rectangle with nine pins, 5 on bottom, four on top. This is where all your POWER SW,RESET SW,HDD LED,POWER LED will be plugged in. I could not find instructions for your board but for mine it is
Looking at the pins from the side where there are 5 pins on the bottom and 4 on top. The top two sould be the power led the two next to that should be the power switch, the bottom two to the left should be the hard drive led and the two next to that should be reset.
This is not the guaranteed position seeing as we have two completely different models.
Hope this helps.
Jun 17, 2009 | Ultra Computers & Internet
Case wire two mother board
Here is your front Audio guide:
Here is your USB guide:
And here is your front Panel guide:
Let me know how that works out. The front panel guide is rotated 180 degrees however.
May 02, 2009 | Foxconn 661FX7MF-S Motherboard
HDD,power led connections
see on the motherboard, there will be athor wire connected from the cabinet.
Read care-fully you can find, HDLED, SPKR, PWS, RSET written on motherboard. and also on the wires you can find like this.
So connect HDD Led wire to HDLED position on the board.
If any problem just Ask me
Apr 06, 2008 | Shuttle AV42 Motherboard
Motherboard Shuttle AV42
Follow this link and get whatever you need about your AV42
THANKS for your trust
Don't forget to rate plz
Apr 06, 2008 | Computers & Internet
I need to know how to hook up some mother board wires
Hi swiftty6, you can download the manual for this board from this link.
Than go to pg. 2-18 for a better picture showing these case connections.
Like this.
4b15236.jpg Enjoy!
Apr 03, 2008 | Computers & Internet
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Shuttle AV42 Motherboard Logo
373 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
