Question about Garden
MY LAWNMOWER DOES NOT STAY ON. ONLY STAYS ON AS MUCH AS I PRIME IT
    Problem Solver:
  • 15 Answers
Check fuel filter, probably plugged with debris or air filter is fuel of dust and grass
Posted on May 31, 2010
Will start but will only stay running if you prim it until its warm then runs fine
Lawn Mower Repair pt.1: starts & dies, Tecumseh/Craftsman ...
? 2:10
https://www.youtube.com/watch?v=IVYYYpAviPA
Mar 7, 2011 - Uploaded by Alameda Repair Shop
Spray with starting fluid and the engine runs a bit longer but dies.... I especially like how you use the gas can to hold up the mower, Classic :) ... After I started it up, it would only stay running for a few seconds before dying. .... LAWNMOWER REPAIR: briggsand stratton pulsa prime carb overhaul - Duration: ...
How to fix a gas lawnmower that starts then dies - YouTube
? 7:37
https://www.youtube.com/watch?v=caa0WrpxqyU
May 3, 2011 - Uploaded by SmallEngineRepairGuy
This is a how to video on what to do if your gas mower starts up then dies after a ... I have a different lawnmower and not very mechanical but this got my ... Got the job done and now i can do a thorough cleanout of it when i run it dry of gas. .... How to FixBriggs & Stratton Small Engine that Only Runs Off the ...
Craftsman 5.3hp starts but won't stay running... - DoItYourself ...
Dec 09, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Sears lawnmower kills after mowing for 10 minutes doesn't restart till rested a long time. Repair man says nothing wrong with it.
That is the symptom of a failing ignition module. With the airbox cover and air filter removed run the unit till it fails. Immediately squirt a shot of carb cleaner into the carb and try to restart. If it restarts see if you can keep it running on the carb cleaner for a few seconds. If it wont restart or stay running then its likely an ignition module. If it does restart and keeps running on hte prime then you have a fuel issue.
Other things to check: spark plugs can fail when they get hot, checkt o make sure the engine stop cable is pulling the bail off ground sufficiently. If the cable has stretched it may not pull the bail completely off ground causing intermitent spark.
Nov 17, 2012 | Garden
Lawnmower repair
clean out the carb
Apr 11, 2012 | Garden
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
I can start my 4.75 HP Briggs & Stratton Lawnmower but it dies after a few minutes. I replaced the armature but the same thing happens. I can keep it running if I press the prime bulb a couple of times...
Try replacing the float and needle. The float (floats) and pulls the needle up to let gas through to the carb. It will stay running as long as you press the prime bulb because this sends gas straight to the carb without going through the gas bowl. It's best to remove the carb and clean it then replace the float and needle
Sep 05, 2010 | Craftsman Garden
Wont stay running
Bad fuel or check for water in your fuel! Clean your carb and float bowl. Empty gas into a clear container, if there is two levels of liquid one of them is water. Of course make sure you have good spark plug.
Apr 17, 2010 | Toro Lawn Mower With Toro Power Tools
Poulan Pro lawnmower (Briggs and Stratton 128 cc engine) will start when primed but will not stay running. New Lawnmovewr, < 3 months since purchased at Walmart
IF IT IS A BRIGG & STRATTON ENGINE YOU CAN GO ONLINE TO BRIGGS & STRATTON.COM AND ASK THEIR TECH SECTION ABOUT THE PROBLEM. FOR 3 MONTHS OLD SOUNDS LIKE DIRT OR WATER MAY HAVE GOTTEN INTO THE TANK. WHEN YOU PRIME THE MOWER YOU ARE FORCING GAS INTO THE CARB AND ENGINE AFTER THAT THE ENGINE SHOULD PULL THE GAS IN THE ENGINE, I WOULD SAY THE CARB MITE NEED REBUILDING BUT NOT AT 3 MONTHS
Sep 17, 2009 | Poulan Garden
My 550 series Bolens lawnmower won't start. When
keep pushing the prime button
Aug 08, 2009 | Garden
Craftman lawnmower start and turn off and do not stay running .
your carb needs to be rebuilt. there is a rubber seat that swells over time and then your float will not allow any gas through. so it will start and run briefly when you prime it. take it to a mower shop for a tune-up.
Mar 11, 2009 | Craftsman Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
