Question about Konica Minolta bizhub 180 All-In-One Printer
I have a error C14A3 - Konica Minolta bizhub 180 All-In-One Printer
    President:
  • Konica Minolta Expert
  • 347 Answers
Call your nearest technical service representative.
Posted on Jun 18, 2010
What can I do when my Konica Minolta bizhub 160 says machine trouble, service call (C14A3)
C14A3 means IR fluorescent lamp fault. Check the Exposure Lamp (LA2) . The Scanner Exposure Lamp fails to turn ON. Test the voltage supply & the Lamp.
Nov 04, 2014 | Konica Minolta bizhub Office Equipment &...
I am getting an error message that says error C14A3. How do i fix it?
The bright that normally come on under the big glass is having issues, replace the scanner assembly can't just get the lamp.
try this web site for starters
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 07, 2014 | Konica Minolta bizhub 161f All-In-One...
Error c14A3
no such code for a c200
Apr 16, 2014 | Konica Minolta 8938413 Brand Tn-211 Black...
I have a bps904n with error code c14a3.
you need to call technical support and they will walk you through how to fix this, if it is able to be fixed. at worst you may need to send your laptop in for repairs, or get a replacement. but you won't know until you call.
Jan 18, 2013 | Computers & Internet
IM GETING A C14A3 SERVICE CALL ON TH SCREEN
This code means your scanner lamp, the one that lights up under the glass is not coming on properly. Usually this code will reset and the machine will work again. In some cases the scan lamp has gone bad and must be replaced.
Aug 17, 2010 | Konica Minolta DiALTA Di1610p Printer
C14a3 error code konica minolta bizhub 161f
Hi jdt_mk,
Sorry to hear you have a C-14a3 code.
In my experience, this code spells disaster for the 161f.
The image reader has failed. The part can be replaced, but the cost would almost outweigh the cost of replacing the machine.
I have personally had to deal with two 161f with the same code.
Both times we changed the machine (because it was on contract).
Sorry it's not good news
Jan 13, 2010 | Konica Minolta bizhub 161f All-In-One...
I have di1610 wont at all error ligth are flashing
Description
Machine may cycle ON/OFF repeatedly (keeps rebooting), will not power ON (no boot-up), no message on the operation panel, LCD displays extraneous
characters and/or error code C14A3 (C-14A3).
Solution
CAUSE: The PCL board draws too much current, causing PWB-P to fail. There is no problem with GDI versions of the machine; only machines with PCL
boards are affected.
SOLUTION: The PCL board has been modified to limit current draw. If the symptoms described above occur, replace both the PCL and PWB-P boards.
Note : The new-style PCL board can be identified by a yellow sticker. Machines that had the new-style board installed during production have a yellow
sticker near the serial number plate.
may want a service technician to check the PCL boards as above
Aug 04, 2009 | Minolta Office Equipment & Supplies
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Konica 7415 erro code C14A3
You have a blown exposure lamp or fuse. When repaired code will automaticaly reset.
Oct 15, 2007 | Office Equipment & Supplies
Konica Minolta bizhub 180 All-In-One Printer Logo
667 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
