Question about Sony Playstation 3 (PS3) Console
I HAVE ONE OF THE VERY FIRST PLAYSTATION 3 AND MOST SOLUTIONS I HAVE FOUND DO NOT WORK. MY PLAYSTATION SAYS HARD DRIVE DISK ERROR SYSTEM WILL BE RESTORED. HELP ME
    President:
  • 1,099 Answers
When you get the dreaded Disk Read Error, it normally occurs for one of two reasons. Either dust has built up on the lens of the laser mechanism, or the operating voltage of the laser has drifted off slightly due to heat and age. Of course, occasionally there are actual failures of components, which cause this, but these are the main two reasons.
Cleaning the laser lens
1) Remove any CDs from the unit and unplug all leads and memory cards. Turn the unit upside down and use the small, flat screwdriver to pop out all the little plastic and rubber screw covers.
2) Take your normal sized Phillips screwdriver and unscrew all the screws.
BE CAREFUL not to damage the eject/power button ribbon cable, as these are very fragile.
Take a cotton bud and careful place some of the alcohol on it (but not so much that it is dripping everywhere). This alcohol is the same (or similar) to the small bottle of alcohol which is in audio and video cassette cleaning kits. This is probably the best way to locate a source. Locate the lens (the circular glass part) and very gently rub the cotton bud around the lens in circular motions for about 30 seconds, being very gentle. Once done, flip the cotton bud over and dry the lens with the other end for about 10 seconds.
The spin rod controls the movement of the laser and is greased to allow smooth frictionless movement. Clean the surface of the spin rod. If you have some grease to replace with then remove all the dusty grease (or as much as you can) and then apply some fresh grease. If you have no grease to replace with then just remove any excess dirt but try to leave a little grease, as it is required for the mechanism to work.
You have now completed the cleaning process. This often cures read errors and should always be attempted first. Reverse the dismantling process and put the machine back together, making sure you DON’T TRAP the eject / power button ribbon cable, as this can cause serious problems for you if it happens. Power on the unit and try to load both a CD and a DVD game. If all works fine then CONGRATULATIONS on completing the guide successfully. If however there is no change then you should proceed to the next step - Adjust the Disk Mechanism.
Hope this will help...
Posted on May 31, 2010
Getting a hard disk file system is coruppted, go to restore and error message still come up
Your HARD DRIVE (aka: Hard Disk), located on the left side of the unit, has crashed. You will need to replace the HD.
When you replace your hard drive, you will need to have the latest firmware on a
usb stick. Download the firmware from the playstation official website onto a usb
stick. Once prompted by your system you will need to insert the usb stick into the
PS3. Good luck..
You will need 2.5" Sata Hard Drive.
Jan 21, 2011 | Sony Playstation 3 (PS3) Console
My ps3 shut off and says ... can not start the correct hard disk was not found
Have you recently upgraded the hard drive on the PS3? If so, this could be giving you a problem and a solution is posted here:
http://community.eu.playstation.com/t5/PlayStation-3-Media/Startup-Problems-After-Upgrading-To-320GB-Sometimes-Cannot-Start/m-p/4958411?view=by_date_ascending
Nov 11, 2010 | Sony Playstation 3 (PS3) Console
The following message is displayed: "System hard disk file system is corrupted." What does this mean.
It means that your hard disk drive needs to be reformatted. You get this error when the system shut off while data is being saved on the hard disk drive.
Nov 27, 2009 | Sony Playstation 3 (PS3) Console
PLAYSTATION 3 CANNOT START THE CORRECT HARD DISK WAS NOT FOUND. DOES ANY ONE KNOW WHAT THIS MEANS. AND IS HARD DISK THE SAME AS HARD DRIVE ?
Go to the bios setup menu to the boot option. When there, scroll down to the Hard Drive2.gif Priority area and make sure you have the boot disk listed FIRST.
Oct 20, 2009 | Video Game Consoles & Games
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
The correct hard disk was not found
Ok there is only 1 500gb drive that is compatible with the ps3 and thats the Samsung spinpoint, go here to find out
http://www.1800blogger.com/2008/08/31/how-to-install-a-500gb-hard-drive-in-your-playstation-3/
Jun 20, 2009 | Sony Playstation 3 (PS3) Console
Ps3 hard disk problem
i replaced the hard drive and now it works fine. thanks for your help
Jan 02, 2009 | Sony Playstation 3 (PS3) Console
Hard disk
remove your hard drive, power on teh console, power off the console, install the hard disk again and power again the console.
Hope this will make the system recognize the hard drive again.
Sep 01, 2008 | Sony Playstation 3 (PS3) Console
Ps3 hard disk
these both need the hard drives reformat,or take them back and get a replacements as it may have an error in the file system......
Jun 20, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
