Question about Mitsubishi WS-55819 55" Rear Projection Television
Ws-55819 code 22 how do i find the problem and fix it
ctf1800
  • 4402 Answers
SOURCE: mitsubishi ws 55819
Bad convergence ic and should replace caps also
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
caps:
· http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm · http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
· http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
· http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Posted on Jan 16, 2008
Slinteriors
  • 8617 Answers
SOURCE: WS-65809 ERROR CODE 22
look on the center circuit board and you will see two green Pico fuses they look like resistors but they dont have any bands on them . They will have F9A04 and F9A05 on the board next to them. Check with a ohms meter if those fuses are open you will ned new convergence ICs. Thats the first thing to check are those two pico fuses when you get a 22 error on your model.
Posted on Sep 10, 2008
  • 556 Answers
SOURCE: Mitsubishi WS-55819 TV Wont turn on.
code stands for loss of vertical. I had one of these if you can check pico fuses, check the ones on the main power board the one with the 2 convergence amps if any of them are blown then most likely the convergence amps have shorted out.
Posted on Aug 11, 2009
SD Tech
  • 14553 Answers
SOURCE: Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Posted on Oct 28, 2009
Testimonial: "Helped narrow down where the problem is."
SD Tech
  • 14553 Answers
SOURCE: I have an mitsubishi medallion hd1080 big screen
Try to unplug set and try it again as if the set was unplugged and then the self check done it will be 1,2 which means NO ERROR detected.
Let me know also what the set does?
SD TECH
Posted on Feb 17, 2010
Testimonial: "yes you were right I plugged the tv in tried to turn on shut right down then checked code (menu, input) now 2,2 is the code. thanks"
How do I fix the 2,2 error on the ws-55819?
install the convergence repair kit for your model. The 22 error is almost always caused by shorted Convergence ICs and blown picos. You can get the convergence repair kit for your model at www.tvrepairworld.com
Aug 05, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 turns off after about one second upon power up. Help
try the self test: when it goes off press and hold the menu and input buttons at same time for about seven seconds and release both.
power light blinks two digit code like, one blink, two blink, a pause and repeats it several times, this code will indicate area of problem.
sj
May 17, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Ws-55819 has code 22. It will power off within seconds.
Error code 22 on this model is most freguently a problem with convergence. Error code 21 is usualy the DM module.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Convergece problem - Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some images of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Or goto the site www.TvRepairKits.com for the parts and instructions on how to fix it yourself
Apr 23, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Getting codes of 2 flashes then pause and then two more flashes. What does this mean
Error Code Operational Check
Pressing the front panel "INPUT" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occurred since the last Initialization
An error code of 22 indicates a shorted component or shorted power supply line.
Mar 01, 2011 | Mitsubishi WS-55819 55" Rear Projection...
Inputs randomly stop registering, screen goes blank
Code 12 indicates no error. Push the Menu and Device buttons after the TV has shut off to get the proper code, not after you unplug and plug it back.
It seems your set is not Mitsubishi WS-55819 so it will help if you can give the exact model.
Dec 12, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws-55819
Code 22 indicates that your set is in shut down due to what is called Short Protect. The most likely cause is the Converge Ic's drawing too much current and opening one or 2 fuses. Normal repair cost varies by area and servicer. Expect 250 to 350 plus the service call. I normally do this on site.
Nov 16, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Can the WS-55819 be reset through a reset button?
Code 22 is short protect. Recheck your work. Did you check and replace open fuses and/or Convergence IC's. The Conv. IC's normally open at least one fuse when they go out.
Nov 02, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi ws 55819
caps:
replace DM
Nov 10, 2007 | Mitsubishi WS-55819 55" Rear Projection...
Mitsubishi WS-55819 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
