Question about Sharp Aquos LC-PD50U 50 in. Plasma Television
Luminous My 52 inch aquos experiences a shift in value from cut to cut. When the picture cuts to a darker scene the image will always fade darker immediately for about a second and if it cuts to a brighter scene it will fade brighter (not as noticeable). Could I have it on some obscure setting that I can fix? It is really annoying. thanks for any help [email protected]
  • babyj4jj Apr 08, 2008
    I'll give it a shot and see what happens tonight. Is this a common problem?
    How often should I be resetting the codes?
    thanks
    Jay
  • Anonymous Mar 16, 2014
    MyRCA HD50LPW162YX4s picture has gotten darker .I set the lamp to the brighter setting. It helped a bit.Do I need a new lamp
    Genius:
  • 3,422 Answers
HI,
The control system has gone bad. Try a hard reset and see if that will cure it.
Unplug the power cord for 4 hours or more. Then try it again. This will reset the internal operational codes to the factory default settings.
If this doesn't help then the only solution to fix this problem is to get it repaired.
Goodluck,
Please don't forget to rate the solution as fixya.
Posted on Apr 08, 2008
  • Priya darshan Apr 08, 2008
    You should do the hard reset only once.If that makes any difference then give it another try.If this helps you fix your problem then no need to call a tech.
    And if doesn't fix then im sad to say that you will have too call the tech and get it serviced.
    Goodluck,
    Genius:
  • 1,142 Answers
Please provide the model and make details
  • Anonymous Apr 08, 2008
    Reset it to the factory setting, refer the manual or the on screen menu
SOURCE:
Our LG tv has started making a vibrating whistling sound when you first cut it on, you can hear it get faster and faster then slowly goes away.. Also over the past few months I've notices the picture
the picture getting darker means the lamp has aged and u need to replace it another thing u need ti replace the mirrors in the light tunnel of the light engine they have faded secondly the noise means the colour wheel has aged you need to replace it u will have to replace the whole light engine cos the color wheel comes inbuilt the light engine and u will be ok ontact lg dealer in your area
Jul 19, 2013 | Televison & Video
My 50 inch plasma tv the color and brightess is gone
This means you have lost the luminance input to the chroma decoder or final video chip. A failure of the brightness limiter may result in similar symptoms.
A few common causes are:
Check the service switch (if any). Its contacts may be dirty and moving it back and forth a few times or using contact cleaner may be all that is needed.
Check for open high value resistors around the chroma decoder IC.
Check for open high value resistors in the brightness limiter circuit.
With a scope and schematic (or even just a pinout for the chip), you should be able to trace the luminance signal to see where it is getting lost.
I have had several TVs and monitors where the delay line in the luminance circuitry has failed. Usually it's made out of glass, and inherently is fragile. Sometimes whacking the monitor would make it come back, leading to the thought of connectoritis or a cold solder joint -- where in fact it was the delay line (long rectangular unit with two to four leads). Replacing the delay line was the solution, but to check it first it'd be a good idea to look for 'in' and 'out' on the line and short the pins. The picture may be shifted, colours may not line up, but it'll tell you that it's the delay line if the picture comes back at all. It's better than looking at a saturated picture with no luminance! :)
May 26, 2010 | Televison & Video
Hannspree HF 257 25'' monitor only stays on fo a few seconds and then gradually fades to black, another monitor works fine so the computer is not the problem. The computer was just moved to a new...
Is the power light staying on or does that go out as well?
If the power light stays on and if you darken the room, can you see a faint image still on the screen by shining a flashlight at it (close). If there is a faint image it is either the inverter or the backlight tube.
JC
Jan 31, 2010 | Hannspree HH251H 25" LCD Monitor
Sony bravia dims randomly
There should be a setting in the menu of the TV to turn off the auto dim feature (used for adjusting the brightness of the picture depending on ambient room lighting) I don't have a Sony LCD here with me to walk you through the menu settings, but I am certain it is there somewhere. (Chased this issue for the wife who had the same displeasure you're having)
May 04, 2009 | Televison & Video
TV Screen Dims during dark Scenes
Most likely you have the opc feture on. go to the menu under picture setting first option should be to turn on or off the opc. turn it of and should solve the problem.
Mar 18, 2009 | Sharp Televison & Video
Picture has a red "haze"
the color in my tv is a little faded when theres dark scenes on cant really see picture. Red and Blue really fade into picture
Feb 21, 2009 | Philips Magnavox 9P6034C 60" Rear...
No image only sound
Hi
This sounds like the tube is losing power. The luminance circuit, the B+ or possibly the Flyback.
Ken
Aug 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 inch aquos sharp tv
Just bought a 52" Aquos TV 27000/1 newest model for 2008 my husband is putting it up and said the non HD channels don't look real good. Is there anything we can do to improve the picture on the non HD channels?
thanks,
Cathy
Dec 06, 2007 | Sharp Televison & Video
Pictures are underexposed
When you are photographing scenes with mostly light objects (for example, snow, water, and sand), the picture is usually underexposed (darker than it really is). The camera meter registers the brightness of the scene and tries to set the camera lens and aperture for an exposure based on average brightness levels (18% reflectance) causing it to underexpose, as in the following picture. When you are photographing scenes with mostly dark objects (for example, shade, shadow, and overcast skies), and very few light objects, the camera may overexpose the image, causing it to be too light. If you have a flash on your camera, you can compensate by adding "fill flash" for some extra light. If your camera has an exposure compensation adjustment, you can increase or decrease the exposure to correct for these exposure problems. Increase the number to make the image lighter, and decrease the number to make the image darker. You may want to try a series of shots with different exposure compensation adjustments to get a feel for how much difference these adjustments make.
Aug 29, 2005 | Kodak EasyShare CX7530 Digital Camera
Sharp Aquos LC-PD50U 50 in. Plasma Television Logo
170 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
