Question about Broderbund PrintMaster Platinum 16
Need a patch for printmaster platinum 10 for windows 7
My wife has a dell computer with window 7 professional operation sistom and i have printmaster platinum 10 only for Windows 95/98/200 NT 4 how i cann install this program in the new computer?
Posted on Oct 29, 2010
3 Suggested Answers
  • 2340 Answers
SOURCE: will Printmaster Platinum 16 run on windows 7 I
Printmaster Platinum 16 is not compatible with Vista or windows 7.
Posted on Oct 24, 2010
SOURCE: IS THERE A PATCH TO MAKE PRINTMASTER PLATINUM 16
yes can be, just follow these steps:
Not compatible or not working well with windows 7?
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:))
Posted on Dec 06, 2010
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I have Print Master Platinum 10 and my Windows operating system is Windows 7 are they compatiable? I tried installing the program but it doesn't install. Is this program too old for this operating...
I don't think Printer Master Platinum 10 will run on Windows 7. However, solution #3 on this page (http://www.fixya.com/support/t2129564-printmaster_platinum_10_version_will_not) references how to make it run on Windows Vista. The same is true for Windows 7. You can run almost any software in compatibility mode. Since they're up to version 18, I doubt it will work with Windows 7.
Hope this helps.
May 29, 2011 | Broderbund PrintMaster Platinum
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
I tried to put print master 16 gold on windows vista and i got a message that i need a print driver where can i get it andwill it work then
Printmaster Platinum 16 is not compatible with Vista or Windows 7.
Presently there are not "patches" to make it works.
Your options is to use the newer version eg. version 18.1
Hope it helps.
Nov 14, 2010 | Broderbund PrintMaster Platinum 16
Is there a patch to have Printmaster Platinum 17 work on Windows 7
There is no patch/update available from Broderbund, to make PrintMaster® Platinum 17 Full Version compatible Win7.
Oct 27, 2010 | Broderbund PrintMaster® Platinum 17 Full...
Will Printmaster Platinum 16 run on windows 7 I
Oct 24, 2010 | Broderbund PrintMaster Platinum 16
IS THERE A PATCH TO MAKE PRINTMASTER PLATINUM 16 COMPATIBLE WITH WINDOWS 7
Mar 14, 2010 | Broderbund PrintMaster Platinum 16
Can i install the print master platinum 16 on my new computer with windows 7
ypu cannot use print master platinum 16 with windows 7 or for that matter vista
Mar 05, 2010 | Broderbund PrintMaster Platinum 16
Can I load Printmaster 16 on Windows 7?
Printmaster 16 will work with Vista and Windows 7, you need to run setup.exe as administrator.
Jan 10, 2010 | Broderbund PrintMaster Platinum 16
My printmaster Platinum 10 version will not install on Vista.
downgrade too XP 10 is not compatible with Vista
May 02, 2009 | Computers & Internet
Computers & Internet Logo
802 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
