Question about Kodak EasyShare SV811 (8858946) Digital Picture Frame
I want to dowload some picture from usb on the picture frame
  • 4,924 Answers
You probably have 2 possibilities..
1st ) is to insert the stick ..(card with the picture on ...and choose to play the slide show from it )
2nd) is to connect it to the computer ...and after that the computer will recognize it ..and you will find it in my computer folder by its name or as a removable device (this mostly in case it has a card attached)
Open the folder and inside you will be able to see the pictures that are already there ...top Load pictures just drag and drop pictures in this folder or copy and paste them..after that you will be able to see them on the frame ...make some slide shows with different folders ..or just play all..and it will change them on a preset time ..
Same thing for Mac..bu the frame will be visible on desktop..and same just copy pictures into it(be sure you do not cut them cause you will loose from computer this way ..so ..just copy ..and paste into the frame's folder
Posted on May 31, 2010
How do I copy pictures from a USB port to the memory in the Digital Picture frame?
it depends on your digital frame becuase some frame cannot be save the picture on the internal memory. if the manual says that you can save or upload try to go setting and look for copy then choose from( memory card to internal or internal to memory card)
goodluck my friend
Jul 13, 2010 | Smart Parts Digital Picture Frame
Uploading photos
Both the thumb drive and the picture frame are USB slave devices, not USB masters. They both need to be connected to a USB master in order to transfer files.
Do you have a standard USB cable from some other device, any other device? If so, that should fit into the picture frame. If not, you'll have to buy one.
Connect the thumb drive to your computer. Create a folder on the computer and copy your photos to that folder. Then connect the picture frame to the computer and copy the photos from the folder to the frame.
If you have two or more USB ports, you can skip the folder and just copy photos from the thumb drive directly to the frame.
Jun 04, 2010 | Pacific Digital MemoryVue MV-800 Digital...
I am having a problem with my digital photo frame DP-352 do you have to keep the usb or memory card from your camera in the the frame at all time to see pictures or can you download them
you can move them to another card (i recomend a cheap usb stick) just move from the camera card to a folder in your computer and then copy them to the usb drive/stick and plug it in the picture frame
Aug 14, 2009 | Coby DP-772 Digital Picture Frame
Cant copy any pictures from computer
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw )
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Feb 03, 2009 | Kodak EasyShare SV811 (8858946) Digital...
I do i get pictures from my camera to my digital from with my usb
hi you can plug in your secure digital card into the digital frame,or if your camera does not use a secure digital card,you will need to buy a memory pen stick where you can store any picture you want on it,they are very cheap and they just plug into your usb port,hope this helps
Jan 04, 2009 | Coby DP-768 7-Inch Widescreen Digital...
I can't transfer pictures from my computer to my digital frame. When I connect my usb cable to my computer from my digital frame , the frame displays "Connected to computer. Use PC interface to copy files....
Dec 26, 2008 | Kodak EasyShare SV811 (8858946) Digital...
I'm trying to transfer pictures from my computer to the picture f
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Transferring photos from computer to picture frame
3 Doing more with your frame
Copying between your frame and computer Copy pictures, videos, and music via the included USB cable. For wireless copying (EX models only), see Picture transfer software—copying wirelessly.
Connecting to your computer autourg00722003id1479308.jpg Copying pictures to/from your computer Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools. See info.jpg for applicable file formats.
spacer.gif spacer.gif spacer.gif spacer.gif 1. Connect the USB cable from the frame to your computer (Connecting to your computer).
autourg00722003id1967406.jpg 2. On your computer, open My Computer or Windows Explorer.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, USB devices.
See your computer documentation for more information on copying files.
Copying pictures from EasyShare software It's easy to copy pictures/videos from My Collection to your frame.
  1. Install EasyShare software from the CD included with your frame (Installing the software).
  2. Connect the USB cable (Connecting to your computer).
  4. In the menu bar, select File ® Copy to.
  6. Select Best For Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
  8. Unplug the USB cable and press autourg00722003id1974433.jpg to navigate to your copied pictures.
Dec 16, 2008 | Kodak EasyShare EX1011 Digital Picture...
Have a kodak ex811 digital frame
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Once you connected your EX811 to your computer, and get the message “Use PC interface to copy files.” That means you can start copying files. Here are the steps:
Oct 27, 2008 | Coby DP-888 8-Inch Digital Photo Frame...
Import videos from handycam to computer
i am unable to import videos from my mini dv digital handycam to my laptop with vista as operating system.is a i-link cable required or usb cable will do? i have the picture motion software and import from handycam software dowloaded through net. can u help me out???
Jul 20, 2008 | Sony Handycam DCR-HC36 Mini DV Digital...
Kodak EasyShare SV811 (8858946) Digital Picture Frame Logo
93 people viewed this question
Top Kodak Photography Experts
Michael Galve
Michael Galve
Bill Eager
micky dee
Are you a Kodak Photography Expert? Answer questions, earn points and help others
