Question about Whirlpool Duet GHW9150P Front Load Washer
Red light is on - indicating controls locked and I cannot get it off???
  • 327 Answers
Hello,To turn off the control light... select and hold the End of Cycle signal for 3 seconds. It will turn off and the machine will work properly!
Thanks
Posted on May 31, 2010
  • projeff74 Nov 02, 2010
    also worked for a whirlpool gas dryer thanks
Red indicator light on the cycle dial stuck blinking
Chek that the door lock is activated if not replace the door lock the other possibility is the anti flood device is activated so chek for a leak in the bottom of the machine
Jul 06, 2014 | Whirlpool duet Washing Machines
Schematic to driver side fuse box
Cavity Fuse Description
1) 15 Amp Blue Horn Relay, Power Sunroof
Relay, Power Window Relay
2) 10 Amp Red Rear Fog Lights (Export Only)
3) 20 Amp Yellow Cigar Lighter
4) 10 Amp Red Headlight Low Beam Right
5) 10 Amp Red Headlight Low Beam Left
6) 20 Amp Yellow Body Control Module/Power Door Locks
7 )10 Amp Red Left Park Light/Left Tail Lamp/License Plate Lamp
8) Spare
9) 10 Amp Red Right Park Light/RightTail Lamp/License Plate Lamp/Cluster
10) Spare Cavity Fuse Description
11) 15 Amp Blue Flasher
12) 15 Amp Blue Stop Lights
13) 10 Amp Red Body Control Module/CMTC/Cluster/Pass. Airbag On,Off Indicator, Auto Daylight
Mirror/Light Bar Switch (Renegade Only)
14) 10 Amp Red PDC Fuel Pump/AC Clutch,
Starter Relay/Engine
Controller/Transmission
Controller (Diesel Only)
15) Spare
16) 20 Amp Yellow Power Outlet (Rear)
17) 15 Amp Blue Rear Wiper
18) 20 Amp Yellow Radio Choke & Relay
19 20 Amp Yellow
Frt Fog Lights/Trailer Tow
Stop and Turn Lights
20 Spare
21 10 Amp Red Radio
22 20 Amp Yellow
Power Sunroof Relay/
Antenna Module (Export
Only)
23 Spare
24 10 Amp Red PDC Blower Motor
25 10 Amp Red Heated Seat Switches/HVAC
Control Head/Trailer Tow
Battery Charge
26 10 Amp Red Headlight High Beam Right
27 10 Amp Red Headlight High Beam Left
28 Spare
29 10 Amp Red Heated Mirrors/Rear Window
Defroster Indicator
30 15 Amp Blue Heated Seat Module
31 Spare
32 10 Amp Red Wiper Switch/Front and
Rear Wipers
33 10 Amp Red SKIM Module/Data Link
Connector
34 15 Amp Blue Body Control Module/
Cluster/Interior Lights,
Hands Free Module/Radio/
CMTC/ITM Module & Siren
(Export Only)
35 Spare
36 10 Amp Red Airbag Control Module/
Occupation Classification
Module (Right Front Seat)
37 10 Amp Red Airbag Control Module
38 10 Amp Red ABS Controller/Shifter Assembly
39 10 Amp Red Hazard Flasher (Turn
Signals)/Backup Lamp
Switch (Manual Transmission
Only)/Transmission Range
Switch (Automatic Transmis
May 23, 2011 | 2005 Jeep Liberty
The locked control indicator has a red light and won't allow the machine to do anything; what should I do?
To unlock the controls Select and hold END OF CYCLE SIGNAL for 3 seconds until the CONTROL LOCKED Status light turns off.
Jan 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
2007 BMW 525i warning light (red) looks like a steering wheel with a lock attached car not starting
Its the "EML" warning light in a BMW indicates a problem with the "drive by wire" throttle control system."
That red light indicates u have loss BRAKE FLUiD in ur system and needs to TOP UP the brake master. It also indicates s pressure loss in the brake system and u have to check the FLUiD, LEAK and ur BRAKE PADS!
Check all of these and tell us wut happened!
Nov 16, 2010 | 2007 BMW 335i Coupe
The contol lock red light is lit and I can't get it to work
Press any of the buttons on the control panel to see if the buttons are operational or check to see if the "Control Locked" indicator light is lit. If the control panel is operational, you may mistakenly lock the door.
Press and hold the "End of Cycle Signal" button for approximately three seconds until the "Control Locked" indicator light shuts off.
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Trying to reset filer light after changing filter-locked up
Here is a link to the manual for your unit. Copy paste into your browser.
http://shop.amana.com/assets/pdfs/literature/12591321.PDF
Page 20 shows how to unlock the dispenser and reset the filter light and I have pasted them here.
There are products at Lowes or Home Depot near the appliance for odor removal, I like to put a bowl of cotton balls on a couple of shelves, soak the cotton in vanilla once a day. The odors will be gone in a couple of days.
DISPENSER LOCK
(SELECT MODELS)
This feature prevents ice or water from
being dispensed.
To lock dispenser:
➢ Press and hold DISPENSER LOCK
button for 3 seconds. A green
indicator light above button confirms
dispenser is locked.
To unlock dispenser:
➢ Hold DISPENSER LOCK button for 3
seconds. Green indicator light above
button will go out.
Filter reset
The filter status indicator light
serves as a reminder to replace the
water filter. A green light indicates that
the filter is in good condition. A red light
indicates the filter should be changed.
Once light turns red, it will remain red
until function is reset.
To reset indicator:
➢ Press and hold both DISPENSER
LOCK and WATER buttons
simultaneously for 4 seconds. The
green filter status indicator light will
flash 3 times when the function has
successfully reset.
Apr 18, 2010 | Amana ARS266ZBS Side by Side Refrigerator
A child lock is flashing with a red light and i do not remember setting it to lock. How do I unlock?
To prevent children from accidently changing the dishwasher cycle or starting the dishwasher, lock the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. An indicator light on the lock graphic touchpad will illuminate when the controls are locked and no new selections can be made until the lock is released. To unlock
please furnish the brand and model no of your dishwasher to be more sopecific
please rate this answer the controls, press the DELAY TIME icon until the indicator light goes out.
Jul 07, 2009 | Dishwashers
Whirlpool duet washer dryer, Dryer is stuck on control lock
look to the far right buttons labled control lock, hold it in for 3-5 secs, to unlock
Mar 23, 2009 | Whirlpool ET8CHEXSQ Dryer
1989 Mercury Tracer Sta. Wgn.
your owner manaul has it. your fuse cover should have chart too.
here is 96 tracer. You also have main fuses under hood.
INTERIOR FUSE JUNCTION PANEL REFERENCE CHART Fuse Fuse Rating Color Protected Components (REAR WIPER) 10A Red Rear wiper and washer motors, heater and A/C relays, daytime running lamps control (Canada), climate control assembly panel illumination HAZARD 15A Blue Front and rear turn signal lamps, turn signal indicator lamp, indicator flasher ROOM 10A (1.9L)
15A (1.8L) Red
Blue Dome and map lamps, safety belt warning chime, ignition key illumination, luggage compartment lamp, vanity mirror lamp, radio chassis (memory), power door lock relay, shift interlock system, powertrain control module (PCM), radio amplifier (memory) ENGINE 15A Blue Fan control (FC) relays, PCM relay RADIO 15A Blue Radio chassis, radio amplifier, remote control mirror, instrument panel illumination (DOOR LOCK) 30A Light Green Power door lock actuators BELT 30A Light Green Passive restraint control module, passive restraint motors (POWER WINDOW) 30A Light Green Window regulator electric drives METER 15A Blue Instrument cluster, backup lamps, rear lamps, speed control system, shift interlock system, safety belt warning chime, passive restraint control module, hazard flasher, PCM (1.8L Canada) WIPER 20A Yellow Windshield wiper motor and windshield washer pump STOP 20A Yellow Stoplamp, horn (1.9L only), rear hi-mount lamp TAIL 15A Blue Parking lamps, cornering lamps, rear lamps, license lamps, compartment lamp, instrument panel illumination (SUN ROOF) 15A Blue Sliding roof panel motor ABS 10A Red Anti-lock brake system (ABS) (1.8L only) (DEFOG) 20A Yellow Rear window defroster HEATER 30A
circuit breaker — A/C blower motor HO2S
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 10A (1.9L)
20A (1.8L) Red
Yellow Heated oxygen sensor (HO2S) CIGAR
(ON INTERIOR FUSE JUNCTION PANEL SIDE) 20A Yellow Cigar lighter knob and element CIGAR 20A Yellow Cigar lighter OBD II 10A Red Data link connector #2 BLOWER 30A Light Green Blower motor relay HORN 20A Yellow Horn (1.8L only)
Aug 10, 2008 | 1989 Mercury Tracer
How do i!
make sure the batteries are good and installed correctly. turn on device(manually) press and hold (setup) button until the red indicator stays on. then release the set up button. press and release device button(tv,vcr ect) the red indicator light will blink, then stay lit. press channel up until the device changes channel.The red indicator light blinks and stays lit.if you over shoot the code required press channel down to back track. now press and release the mute button to lock in the code.
Jan 13, 2007 | GE RM24912 Universal Remote Control
Whirlpool Duet GHW9150P Front Load Washer Logo
65 people viewed this question
Dan Webster
Dan Webster
Sal De
