Question about Whirlpool Duet GHW9150P Front Load Washer
The door will not unlock
The machine will not run a cycle and the door will not unlock.
  • 327 Answers
Hello,For the washer, hold the End of Cycle button for 5 seconds. For the dryer, press "More time", "Less time", "More time", "Less time" buttons in that sequence within 5 seconds.
Thanks
Posted on May 31, 2010
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
WFW94HEXW door won't unlock and Door Lock isn't lit
if you machine is warranty you must call to the whirlpool, and get the assistance via online chat. However you must wait about 180 seconds since you did the command STOP, and stop the motor, fi the water level is higher must be drain before the latch door unlock.
2) if do not obey press and hold END OF CYCLE, wait about 10seconds
3) reset the machine unplugged from wall by 45 minutes, and then plug again, and turn on and unlock the door
God bless you
Jun 21, 2012 | Washing Machines
If you get the FL how do you get the door to open??
  1. Your Maytag Neptune washing machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
  2. Do
  3. Your Maytag Neptune washer displays the "do" help code when the washing machine is trying to start a cycle, but the door is open or not locked properly. If this message is displayed, close the door securely and restart the washing cycle.
  4. FL
  5. The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
  6. Sd
  7. The "Sd" code indicates that you have added too much detergent to the washing machine and your laundry has too many suds. The machine will stop displaying this code if it has successfully run the suds recovery cycle, which removes the excess suds from the wash load. If the code remains, reduce the amount of detergent in the load. Use less detergent for similar loads of laundry in the future.
  8. PF
  9. The "PF" code indicates that a power failure has occurred. Restart the wash cycle. If the code still appears, check that the washing machine is still plugged in to the electrical outlet.
  10. Nd
  11. The "nd" code indicates that your Maytag Neptune is not draining as it should. Check that the drain hose isn't kinked and that the stand pipe isn't clogged. If you find either of these problems, fix them before restarting the washing cycle.
  12. LO
  13. The "LO" code appears when the washing machine has finished the selected wash cycle, but cannot unlock the door. Verify that the door is closed properly, push the "Off" button, and wait two minutes. The door should unlock and the error code will disappear. If the error code remains, unplug the washing machine, wait two minutes and plug it back into the electrical outlet.
  14. Lr
  15. The "Lr" code indicates that the washing machine's motor is not running as it should. Have your Maytag Neptune washing machine serviced by a certified Maytag repair professional.
Dec 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer won't stop running/or shut off after cycle
clean the small presser hose out and check the pump sump make shur there is no obstruction
Nov 25, 2008 | Maytag Neptune MAH5500B Front Load Washer
Lid switch won't unlock at end of cycle
Yes! The lid/door WILL UNLOCK after a 45 to 60 second delay, This is for YOUR SAFETY this action prevents you from opening the lid/door to a coasting washbasket. You CAN or WILL be seriously injured if you insert your hand(s) into the machine before the washbasket stops!
Mar 26, 2008 | Frigidaire FWS833A Top Load Washer
Cycle runs normally but the washer does not stop after spin
I don't know specifically about your machine but I think the problem is with the door lock. Again, on most machines with a shakeout it can go on and on until the door unlocks. Does your machine have a door UNLOCKING solenoid or does the door lock just lose power at the end of the cycle. It may be that you just have a very weak solenoid to unlock the door.
Feb 18, 2008 | Maytag Neptune MAH6500A Front Load Washer
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
52 people viewed this question
Dan Webster
Dan Webster
Sal De
