Question about Rinnai EnergySaver 556 Air Conditioner
Rinnai DV Propain Heater 556F
My onlight is red instead of green. The heater still heats but will not turn off, just continually runs. What is the problem?
Jennifer Thorne
  • 3 more comments
  • Jenn37 Apr 10, 2008
    I noticed yesterday evening that the onlight is red when the temp is set to 68 degrees but works some of the time if I lower the temp setting to 64 degrees.
    That thread is not my problem. My heater is not turning off and the on off light is red instead of green.
    What relya are you referring to? Where is it located. Would this cause the on off light to be red instread of green.
    I called that phone number and it is the recall line for Rinnai. My unit is not in the recall database. They could not help me further.
  • Jenn37 Apr 11, 2008
    Thanks for the manual help. I did read that when the on light is red the burner is running. When the burner shuts down it goes green again and the blower keeps running.
    I checked this against my other rinnai and this holds true so the only thing that now is wrong is that it doesn't shut off when it is at a 68 degree setting.
    I won't have time to get inside the beast until next week. for now I'll just keep it at the lower setting.
    Thanks
    Guru:
  • 1,342 Answers
Read this thread.
May work for you also.
Posted on Apr 10, 2008
  • Georgia B
    Georgia B Apr 10, 2008
    Here's a link to Rinnai for your heater
    Here's a link to the service manual
    Here's their Contact Link
    Sorry I couldn't be more helpful. I have never serviced one of these units.
    Just trying to help.
  • 3,037 Answers
Sounds like the relay might be going bad and needs to be replaced
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Apr 10, 2008
    Contact Rinnai toll-free at (866) 746-8344 anytime about your problem and about getting a replacement part.
    Let me know if you need further help
  • Benjamin Patri
    They couldn't even transfer you or give you a different number to call? What kind of company is that?
    Alright found their other number
    Contact Rinnai
    Freephone 0800 RINNAI
    0800 746 624
    Basically the control switch connecting to what it controls, I believe has gone back, something in between the control and the main board needs to be replaced, I usually call it a relay, but I am not familiar so much with this brand but If you open it up and follow the switch to the main board, something may look wrong, or even if it looks ok, then it still might have a problem. Look for broken or loose connections or anything that may smell burnt.
    Let me know what you find if you choose to open it and please keep me updated. thanks
  • Benjamin Patri
    possibly post a picture or two after you have opened it up
  • Benjamin Patri
    Benjamin Patri Apr 11, 2008
    Please let us know if you need any further help
  • Benjamin Patri
    Benjamin Patri Apr 17, 2008
    Please don't forget to let us know how this goes and please rate my solution.
    Thank you for using Fixya
Green light will not come on. red light continues flashing
I have experience in Dolce Gusto melody 3. I think that means that the machine warms up the heater. If it continues giving red flasher, i expect that no electricity reaches to the heater or there is something wrong with the heater sensor. In my machine there is Triac (BTB08-600CW) that drives the heater. Please check and show us what is happen.
Dec 30, 2013 | De'Longhi EDG200T Nescafe Dolce Gusto...
Green red antifreeze
the green and the red will jell up in the heater core and will give you no heat
Jul 07, 2012 | 2000 Saturn SL
I have a purex triton 300 pool heater that will not turn on. The power is on and there are no red lights. It is all green. The AUX green LED light is also on (don't know if this will help). I tried...
red light is calling for heat check control unit for heat enabled if ok see if heater runs with firemans switch jumped if ok control if not check safety circuit
Sep 11, 2017 | Pentair Pool & Spa
My wife said the pump timed off and the heater was heating. She shut the heater off and restarted the pump and now the heater won't ignite. The red light blinks three times and I am not sure how to get it...
The fan will continue to run for a few minutes after the pump turns off to purge exhaust gasses.If it was still heating you have a problem. To reset the heater,turn off the pump breaker for 30 seconds. After that you need a repairman.
Sep 27, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
My goodman air handle is run on e-heat only and will not turn off ,also the outside unit will not turn on , I put a new themostat this didn't help I have a goodman heatpump
Heat-Pumps can be temper mental. Sounds to me like your air handler is running on emergency heat, due to a problem with the condensing unit.You have heat strips in the air handler in case the outdoor temp. gets to cold and the heat pump cant keep you're home warm.Also, if you loose a compressor, it will go into emergency heat. If you have lost the compressor for one reason or another, lets say a locked rotor, the compressor would draw L.R.A. (Locked rotor amps) and cause the circuit breaker to trip. Check this.As for the air handler running all the time, you said you replaced the stat? When you removed the control wiring from the stat, did the fan shut off? I wish I were on site to help you, but all I can do is offer you some advice. With the power off to the air handler, go to the stat and remove the red and green wires. Turn power back on and see if it stops running. If it stops, then it sounds like the new stat is also faulty? If it continues to run, check the wiring in the air handler to make sure the red and green are not touching somewhere, and also check the control wiring on the outdoor unit for the same problem. Do you have any dogs that may have chewed into wiring? If so, check all outdoor t-stat wiring. There are so many things it could be and I hope very much I have helped you with solving this online, which can be difficult. You may also have a faulty defrost board. Try to do what I have asked of you.
Good Luck, Sincerely, shastalaker7
Oct 16, 2009 | Goodman GMS90703BXA Heater
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Aug 20, 2007 | Roper REK2950W Electric Dryer
PRINTER LIGHTS BLINKING RED THEN GREEN
Either you have ran out of an ink, because some epsons wont run until you replace cartridge, you have a document pending a print, or you need to disconnect printer, uninstall drivers from Add/emove programmes. Re-install driver then re connect printer when prompted
Nov 10, 2006 | Epson Stylus Color 760 InkJet Printer
Rinnai EnergySaver 556 Air Conditioner Logo
485 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
