Question about Maytag Washing Machines
Maytag washing machine will rum for a few minutes then stops and it smells like something iis burning, and we see faint smoke when we open the lid
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
Probably two main things can be the cause…pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.Also pump pulley spot welds break causing pulley to drag.
Check the following steps....
1.Switch off the machine and disconnect the mains power and Turn off the water supply to the machine.
2.Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
The smell may well be coming from the motor if it is overleaded or has a problem. If the above does not solve the issue then you may be looking at the replacement of the motor.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
Maytag Neptune frontloader washer smoking last few minutes of spin cycle
I need more information can you tell me if the smoke smells like rubber burning or if it smells like electricity burning like the wires burning?
Oct 01, 2012 | Washing Machines
White smoke coming from the machine, it was in the middle of the extended cycle. stopped machine and unplugged. Smells as though something burned.
Usually the first repair a Maytag washer needs is to replace the belts. They can wear out and smell.
The belts are located on the very bottom of the machine. They are not covered. If you pull out the washer about 2 feet and lean it back against the wall you will see the belts on the bottom.
If they have shiny parts, or one of them was sticking. You will be able to see if it is burned.
I've made a diagram to help.
The "main drive pully" is the belt that is most likely to be burned. It is also possible for a clothing item such as a baby's sock, to get caught in the pump. That being the case, the pump belt can burn.
If you replace the belts, which you should do if the machine is 10 years old. You must replace them with Maytag belts. This is important, because they are designed to allow some slippage. If you replaced them with belts of the correct size but not the right type, the machine will not work properly.
Of course, the machine can have electrical problems, but it is rare. Let me know what you find and I can advise you further. Happy New Year, Mark
Jan 02, 2011 | Maytag MAV3855A Top Load Washer
I have a Maytag topload 1412 series 4. I recently tried to wash a comforter far too big for it. About ten minutes into the first cycle I checked on it and smelled something burning. I did not see any...
lo mas combeniente en estos casos es revisar el bobinado del motor obiamente esta quemado pero puede ser renplasado por un motor nuebo instalado por un experto en la materia
Oct 05, 2010 | Maytag PAV2300 Top Load Washer
My Maytag A105 Washing Machine made a weird noise just as it started the spin cycle. When I opened the top lid, there was a burning smell and I could see some smoke coming out. I shut the lid again and...
This sounds like a belt burning. Something may have got caught in the pump and the belt is slipping and burning. You will need to drain all the water out first. Then remove the front panel. Tilt the machine back a little so you can reach the pump pulley and see if it turns freely. Your model has 2 belts and they both should be replaced at the same time. Adjustment on the pump belt is critical so the drive belt doesn't slip. If something is caught in the pump, whatever it is needs to be removed, or replace the pump.
Jan 03, 2010 | Maytag Washing Machines
Agitator no longer moving
sounds like you may have burned out the lid switch. if it is not working the timer thinks the lid is not closed and will not advance.
Oct 04, 2009 | KitchenAid KAWS850L Top Load Washer
Maytag neptune smoking
it could be the seal on the drum or it could be the belt getting too warm
Jan 12, 2009 | Maytag Neptune Washer
Maytag washer stop spining and smell burned
two main things pump and motor pulley.the motor pulley on admiral designed maytags is plastic and melts and causes belt to burn.also pump pulley spot welds break causing pulley to drag.tip machine so rests on wall in back and you can inspect from there.hope that helps God bless ,tom
Jan 04, 2009 | Maytag Washing Machines
WASHER STARTS MAKING LOUD NOISES WHEN SPINNING SOUNDS LIKE IT IS OFF BALANCE BUT NOT. ALSO FAINT SMELL OF BURNT RUBBER.
The washing machine will do this if the load is unbalanced. Usually due to either an excessively heavy and/or large load. The burning rubber smell is just the drive belt dealing with the imbalance. Often the washing machine will self-balance itself, but it's a good idea to open the lid and re-distribute the load. Or remove some stuff if it seems too heavy.
Sep 06, 2008 | Maytag Washing Machines
Washing machine stopped midcycle
It seems like the engine of the washing machine has burned out. If you are still in your warrenty period (and you used the machine conform operating instructions) you can contact the store you bought it from and ask for a replacement or repair. Otherwise you'll have to ask a repair man to come but these can be quite expensive.
Aug 08, 2007 | Maytag Performa PAV2200
Washing Machines Logo
14 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
